Question about Samsung WF337AA Front Load Washer
SPINNING OUT OF CONTROL MACHINE IS DANCING ACROSS THE FLOOR
Completely remove the shipping bolt that hold the power coard in place. This solved the problem for me.
Posted on Jul 16, 2009
  • 3,600 Answers
You need to adjust the legs on the bottom to get it balanced so it does not spin and cause it to bounce. fill a clear glass of water up to 1/8 inch of top place on machine on the side and then the front observe if unit is level if not adjust till level from right to left and front to back. spin outthe adusting feet on the bottom of the washer.
Posted on Jun 14, 2009
I have a Maytag Model # LA806-02, which dances across the flor when in the spin mode. Tighting the three centering spring has helped very little.
If your Maytag is dancing across the floor the most common problem is the leveling. If one or more of the feet are not level it ill wobble and walk around the floor. When you level the machine on the top both directions make sure the set nut is tightened so you will not have to retighten it again later.
May 08, 2011 | Maytag Washing Machines
We recently bought a new washing machine, front loading, and it seems to enjoy dancing across the floor when it spins, any ideas what we can do to prevent this, the floor has a laminate finish.
The adjustable feet under the machine are supposed to be fitted with rubber cups. Make sure the machine doesn't rock around when pushed and pulled in several directions--you may need to adjust the feet so that the machine sits level and firmly. If it really gets to hopping after you have checked the previous items, then the tub suspension system inside the case may hung-up in some way. That would appear to be a warranty item. Hope this helps!
Mar 28, 2010 | Tecnik TKL9260 Front Load Washer
When on spin cycle, the washing machine dances across the floor.
Try to level machine. Whe empty try to reset back legs pulling machine from rear up front leaning on front legs. Try to balance your load too.
Dec 29, 2009 | GE Energy Star WCVH6260F Front Load Washer
My washer is not quite 3 years old and has started a loud banging sound especially when it spins, it sounds like an MRI machine
One of the dampers has gone so the drum is allowed to move too far from its centre when it is spinning and is hitting the outer shell
Once it gets out of whack the machine will dance across the floor if it is allowed to.
You need a man that can
Oct 12, 2009 | Frigidaire ATF6000ES Front Load Washer
E59 Error on Frigidaire front loader - won't spin
I finally solved this same problem on mine error code E59 and the main symptom of the drum never spinning even right at the beginning of the load cycle. I did Test 12 based on the following link: (MAKE SURE THE POWER CORD IS UNPLUGGED TO THE MACHINE)http://manuals.frigidaire.com/prodinfo_pdf/Webster/134542000.pdf. I found that the motor was fine which meant the problem was with the speed control board. On my speed control board there are 3 locations that connectors plug into it. Make sure these are all firmly connected. One of the three is a very weak press fit connection clamping over the edge of the circuit board. This had wiggled loose on my machine from all the dancing across the concrete floor in the basement this machine does. I pressed this connection in firmly, put everything back together and it started working like new!
Good luck.
Jon
Sep 25, 2009 | Washing Machines
During the spin cycle, the machine shakes violently and dances across the floor. It has a loud squealing noise during this. My Performa is only about 14 months old. This is very disappointing for a Maytag.
Look in owners manual. I think these washers have a 1/2 hp. variable speed motor. make sure the washer is level from front to back and side to side, if its not that could be the problem. The motor has a lot of force, the squealing could be a bad bearing not sure.
Aug 24, 2009 | Washing Machines
Maytag LAT2500AAE- unbalanced
see if it has 4 adjustable feet on each corner on the bottom
get a bubble level from a hardware store and turn the feet to raise or lower OR you could use something else to raise the sides until it is leveled by looking at the bubble level.
hope this helps
thanks for your rating
Jan 09, 2008 | Maytag PAV2300 Top Load Washer
Washing Machine Dance
Cars, does the basket lean to one side? There might be a couple of issues. The coupler that seats between the motor and trans could be wollowed out causing vibration. Another is that one of the balance springs came off or broke. I'm going to attach a photo of the springs so you can see what this looks like. You can remove the whole cabinet to check things out or tip the washer back and take a look.
Aug 24, 2006 | Kenmore 23022 Top Load Washer
Samsung WF337AA Front Load Washer Logo
749 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
