Question about Maytag Neptune FAV6800AW Top Load Washer
My washer wont spin out when it get to spin shuts off. spins then stops then spins untill the dc code comes on
  • 335 Answers
Hello pierce21706,
Common problem with the FAV6800AW/FAV9800AW see this post
for a DIY repair process. If you want to try the repair/replacement of the Clutch I will help you thru the process. Rich
Posted on Jun 14, 2009
Samsung washer has code f 103 can you tell me whats wrong wont spin trys thenstops
I could not find code f103 but u said that it tries to spin but stops. is the drain pump coming on and removing the water from the washer? if there is to much water in the tub clothing it wont spin. check all drain lines to be sure they r clear.
Jun 02, 2014 | Washing Machines
Washer front loader wont spin or unlock
Find your book that came with the washer, and it will have trouble codes. Your lights are probably flashing a code. Count the flashes then look up your code in the book. That is a good place to start.
Mar 06, 2014 | Samsung WF203ANW Front Load Washer
Washer does not finish cycle..it stops at spin and it displays a 'dc' code...what is this
The Service Manual for reference. Sears Parts Direct for reference.
dC code from the Service Manual = Distribute Clothes: The load is unbalanced, preventing high speed spin. Redistribute clothes.
Your wash tub is banging around during the spin cycle correct?
You can redistribute the wash basket load until the cows come home the issue will only continue to get worse. Maybe start throwing uC error codes to the console display for continuous unbalance error code.
Your FAV6800A or FAV9800A has a Clutch malfunction. It can be corrected if you are handy see this DIY fix Clutch Fix. post.
If you decide to dive in I will help you through the fix………Rich
Feb 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My 1998 GE washer was spinning off balance, i went to shut it off but it stopped spinning and now wont spin anymore in spin cycle
Sounds like the balance weights come off, and when this happens there is a switch that get tripped to stop it destroying itself, problem must be remedied before it will restart
Jan 31, 2010 | Washing Machines
Wont Finish Spinning stops and Flashed DC
If the machine type is a FAV6800A/FAV9800A see this Clutch repair post if you want to DIY. You will find links to the Service Manual and parts info if needed.
You can check out the TDS but I would go right to the Clutch repair post if the machine shuts down in with a error code dC or uC.
That means the TDS is producing analog voltage swings +3.5VDC to 0VDC to the input of the Control Board Conn_P3 pins 10 and 11. Those DC voltage swings are at the design limit of max Wash Tub movement and the Control Board shuts the Spin Cycle down……..so thebTDS is working as designed.
The machine will make several attempts to redistribute the load before error code generation failing with dC or uC error codes.
Post back if you have questions any DIY'er with basic skill sets can do the Cluch maintenance/repair.....Rich
Jan 04, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Codes and holes
Hi mandystreet,
I’m an owner like you; from what you describe I feel you have a clutch issue if you’re machine is a FAV6800AW or FAV9800AW. I'll bet it completes the spin cycle with no clothes in the wash basket. Here is what is happening
See this post for a step by step process to remove the clutch. Try a maintenance clean up of the One-way Roller Clutch bearing and see if that will get you back in service, if not I would do a Clutch replacement.
Your machine is shutting down the spin cycle with dc and UC errors so your Tub Displacement Sensor is working as designed.
From the Service Manual page 12;
During fill cycle – If machine tumbles and spins simultaneously replace clutch assembly.
During spin cycle – If machine tumbles and spins simultaneously replace clutch assembly.
You can check this out by turning off the water supply lines if you check during water fill cycle. Lift the washer top from the base and observe the action during water fill or spin cycle. The Service Manual will show you how to raise the washer top from the base.
This is happening because the clutch One-way Roller Bearings are sticky, slightly rusted. When the machine enters spin cycle the agitator shaft is slightly engaged because the one-way roller clutches are dragging this will cause the agitator shaft to rotate in spin cycle spinning the tumblers slightly. In this condition the wash load is tossed about while the wash basket begins to spin up. This will cause the Tub to become unbalanced and the tub starts making greater swings.
This continues until the TDS (Tub Displacement Sensor) signals an unbalance condition to the Control Board and shuts the cycle down with a dc or UC unbalance errors. If the TDS fails in this mode the machine would likely walk across the floor until it unplugged itself or ended in a self-destruct.… :)
A WD-40 clean up and re-lube may get you back in service. Just follow this posting step by step. If you are not a DIY type direct your service repair to this e-mail to help speed you to repair and control cost. You can redistribute the wash load until the cows come home and you will continue to fail with UC or dc unbalance errors…. Fix the clutch issue and your machine will be happy and so will the owner.
Rich
Sep 14, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune won't advance from Rinse to SPIN
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(@#$^
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl washer
A dc error means that the clothing is not being distributed properly in the basket. This usually happens when the machine is lightly loaded. If the load seems o.k. then the problem is probably with the sensor at the side of the basket.
Apr 26, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
122 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
