Question about Frigidaire FMV156DC Microwave Oven
Micorwave lights up, timer works but dish won't turn or heat.
  • 180 Answers
You have not mentioned the model and make of the oven. You can check if there is a fuse between the highvoltage winding of the transformer andthe capacitor. If it is blown off replace the fuse, or you have to replace the magnetron.
Posted on Jun 14, 2009
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Microwave still lights up and timer still works but it won't heat anything up
The magnetron is the most likely cause, "heats food" this part is the heart of the microwave and expensive. The other two parts to consider is the high voltage capacitor and diode, but repairs will run high depending on the nature of the problem.
Jul 09, 2011 | Emerson Microwave Ovens
I have a Salton micorwave oven (MW-2027P). The timer works but the cook setting will not start. There is also no light on the inside when I open the door.
I had this exact same problem with my salton microwave! Even tried taking it back to the store, but with no reciept there was little they could do. Anyways try jiggling the clasps on the side of the the door, the ones that connect it to the microwave. Mind you don't jiggle too hard. Now firmly close the door, you should hear a distinct click. Now try it! The light only works when the microwave is on. The microwave won't work unless the door is closed properly and my problem was the claps were stuck! I hope this helps.
May 15, 2011 | Salton RRMW1 / RRMW1A 900 Watts Microwave...
My kenmore microwave will not heat, everything seem to be functioning but the food does not heat.
Assuming all lights are functioning, etc. Is there anyway that it has been set in the timer only mode? Usually a microwave ( their little computer operating system)can be reset, by unplugging and leaving unplugged for a few minutes then replugging. Depening on the age of the micorwave, it may be simply worn out. the newer ones do not lst anywhere as long as the older ones did..but then they cost a lot less as well.
Dec 16, 2010 | Microwave Ovens
RCA Model RMW700 micorwave 1 yr old stopped working. No power, yet the outlet is live. No power to the display, no light inside, just dead. Stopped working when heating cold cup of coffee.
There is a fuse inside the cover of the microwave. You will need to remove the outer shell and follow the power cord you will see an inline fuse. This fuse can be purchased at any appliance parts house.
Hope this helped
Dave
Jan 19, 2010 | RCA Microwave Ovens
Microwave wont heat food. Everything else works.
Micorwave doesn't work when the megatron tube is out. That's probably why it won't heat up. Either replace microwave or the tube. You can get the number from Sears for the megatron tube by calling customer support.
Nov 09, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave doesn't work
There is a reset somewhere around the top or close to heating element
Mar 12, 2009 | LG Over-the-Range Microwave
18 month old Sharp1406F Micorwave won't turn on, heat or rotate. Light and time work.
to tatsukete
The problem is the primary (bottom) interlock switch, or possibly its mount may have a broken tab. The tab is hard to see, since it's on the underside of the switch.
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the free Acrobat Reader to view or print it in case you don't have it already.
The best place to order Sharp parts is Tritronics.
to Guest...
Please reply back with your brand and model number so we can help you. Better still, maybe you can make a new post with that info.
Nov 07, 2008 | Sharp R-1480 Microwave Oven
Frigidaire FMV156DC Microwave Oven Logo
313 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
