Question about Philips Magnavox Learning Universal Remote
Reset codes I have a Sansui TV. I can't find the manual for our Philips universal remote( Model# CL034) I need to set this remote to work with the sansui TV. Can you help?
  • 87 Answers
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Posted on Jun 14, 2009
I have a phillips CL034 universal remote need code for sharp tv
this should work:
SETTING CODES
HOLD THE CODE SEARCH BUTTON DOWN UNTIL THE RED LIGHT STAYS LIT.
PRESS THE DEVICE BUTTON (ie TV)
CHANNEL UP BUTTON UNTIL THE CHANNEL CHANGES. (300 SHOULD BE MAXIMUM)
PRESS THE MUTE BUTTON TO SET THE CODE
Oct 19, 2009 | Philips Magnavox Learning Universal Remote
My remote dont work
I have a Phillips Magnavox 5 device Universal Remote, model MRU3500 that may help.
JVC brand - including LCD, Plasma & Panal televisions Codes: 0607, 0204, 0321, 0508, 0617, 0326, 0993, 0802, 0108, 0308, 0715
Sep 03, 2008 | Philips 5-Device Universal Learning Remote...
Universal remote magnavox model # CL034
try this codes
002 006 071 128
heres the link where i got it MAGNA
Hope that helps, pls dont forget to rate as fixya
May 15, 2008 | Philips Magnavox Learning Universal Remote
Code for apex tv through philips universal remote
Try these APEX TV codes 0023 0223 0123 0741 Thats from the CL034 Code book
May 02, 2008 | Directed 434MHZ Remote Control
Philips universal remote control cl034
hey i tried this and it worked. hold code search till the light stays lit(it may take a couple of secs ) then after its lit press tv and then keep pressing channel up or down till the channel on your tv changes when does press mute to save the code. also the power button will work to during code search , but i use channel because if you accidentally skip your code you can go back the other way. you might need to take out the batteries then re-insert to reset any previous codes. hope this works for you guys as well.
Mar 08, 2008 | Philips Magnavox Learning Universal Remote
Model cl034 philips universal remote
kindly see fisrt ur remotes manual...
Jan 29, 2008 | Televison & Video
Universal remote
Which TV do you have? :)
Aug 28, 2007 | Televison & Video
Philips Magnavox Learning Universal Remote Logo
342 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
