Question about Zebra Eltron TLP 2844 Thermal Label Printer
Trying to Print USPS Labels from PayPal on TLP 2844
System:
Windows Vista
TLP Etron 2844 Printer.
I have 4x6" labels and I am trying to print labels from USPS. Through the printer settings, I have set the paper size as 4x6". However when the page prints it is a reduced size and seems to have a border of approximately an inch on all side, such that the actually print space is approximately 4x2.5" Inches.
Also Test Page prints correctly, and so I don't think that it is a page offsetting problem.
Thoughts?
  • cliterow Jun 14, 2009
    Hi jolarson,
    I am using I have set the borders to 0.00 and I am using the ZDesigner 1.5 driver. Is this where you where suggesting I set the printer preferences? Or is there another place I could set the borders?
    Thanks,
    New Friend:
Go into the zebra utilities and change the printer settings to 4"x6". This will fix your problem.
Posted on Apr 16, 2013
  • 130 Answers
See if you can set the printer preferences to borderless printing.
Posted on Jun 14, 2009
Everytime i turn on my zebra tlp 2844-z it prints 2 blank labels.anyone please help me to solve this problem
Are you using the correct labels?
Direct Thermal Printers use different labels than printers with ribbons.
If you print a label using labels from a ribbon printer in a direct thermal printer they will come out blank.
Jan 28, 2011 | Zebra TLP 2844-Z Thermal Label Printer
How to print portrait 4x6 labels from USPS using my Zebra LP2844Z
There is a much better driver to use for Zebra printers and it come free from www.seagullscientific.com. Look for the drivers download and then pick Zebra.
Hope that helps.
Mar 23, 2010 | Zebra LP 2844 Thermal Printer
Which driver to use with lp 2844-Z under windows XP to print USPS 4x6 labels in portrate mode if lpt1 is used?
Go to website below, and download the driver from there unplug device, install software and reboot, at next desktop, NOW plug in the unit and use.
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have tried to take barcode labels.From application, for each and every label i need to generate the label in PDF...
The TLP2844 can print from any windows application providing the application can use a windows printer driver.
The page size oof the .pdf needs to be the same size as the physical label size.
Nov 03, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Cant print on butterfly label with Zebra TLP 2844 printer
This is a problem of label sensing.
You are probably using the Gap sensor on the 2844, unfortunately the shape of the butterfly labels means you are sensing the wide gap between the labels in the centre, so it will not print anything in the apparent gap area on both ends of the label.
What your label or system supplier should have done is supplied you with the same labels but with a 3mm wide black mark on the underside of the label backing paper, centred between the labels. You can then change the printer sensor setting in the driver to Black Mark. You will then be able to print anywhere between the black marks.
Any problems with this contact us directly at Lancer labels Ltd
Nov 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Trying to setup a Zebra TLP 2844-Z on serial port
Two possibilities are the port configuration and the type of serial cable.
The printer has a feature that will try to match itself to the PC's configuration. Press and hold the feed button until the green status led flashes three times. While the led flashes send a ZPL format to the printer (hopefully you can do this through Design Pro by trying to adjust the printer or print labels, but the labels will not print). When the printer and PC are synchonized, the led changes to solid green.
If you can synchonize but still can't print, the problem might be the serial cable; not all serial cables will work. You should use a full null model cable (all pins connected except 1 and 8).
Sep 19, 2008 | Zebra TLP 2844-Z Thermal Label Printer
TLP 2844 skips over labels
The first thing I would do is to default the printer then run a width calibration. The instruction are in the user's manual that should have come with the printer. If the instruction did not come with the printer I can provide the instruction.
May 07, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
Dec 26, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Zebra Eltron TLP 2844 Thermal Label Printer Logo
1,564 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
