Question about Lasko 3723 Floor / Box Fan
Lasko 3723 burnt motor
I bought a lasko box fan (model 3723) a month ago and when I started it the first time it didn't sound right. When switched it to the high setting, it seemed to be laboring to move. Turned it off, then back on, and it was fine. After using it about half a dozen times, the last time it was switched on my wife found it about 20 min later, it was off and smelling burnt. It hasn't worked since. I took it apart and there's not much to it, no fuses to burn out, just internal exposed wiring and motor parts, plus one capacitor. Could it be that the capacitor burnt out? I guess what I'm asking is - how do electric motors burn out? Is there arcing that occurs between the copper wire coils? If I replace that capacitor, will that fix it? I lost the receipt (bought it at Sears) and threw out the box, so I doubt I can get it replaced...
  • 90 Answers
Sorry but you need to purchase a new fan.
some times the motor is not aline correctly and the rotor "part that spins the blade" rubs on the stator "the part with the copper wire:" the motor
over heat with the friction, then smoke followed by the coil burning.
Posted on Aug 01, 2009
My Lasko 2517 tower fan won't turn on. Have tried
Here is my problem. MY Lasko 4820 Model, is having issues with starting up. Example I turned it on and the rotation stand that moves the tower works. But the fan motor or something realetted is not moving. The fan itself won't move on setting 3, 2, or 1. I don't use the ionizer (I have a smoke detector that picks ionized things and smoke) in my room. I've looked at similar issues or the same and a is different in some way or issue. I've never taken it apart, and one more thing I don't have any solutions because I bought it atva Thrift Store for $29.99 and dident know if someone broke it possibly in the past. No remote either. It has 5 buttons. Middle: Power. Top right: Ion. Botten right: Fan speed/setting (3, 2, 1) Top left: Timer (1hr, 2 hr, 4 hr.) Bottem left: Rotation for whole tower. Please Post anything that may help. Please do NOT respond with "Thats you're fault for buying it at a cheap junk sore" and something related to Criticizing me for getting it at a place that has used items. I know that, just give anything that Will help this issue.
May 16, 2012 | Lasko Dryers
A couple months ago, I had a Lasko box fan that shorted out. It had been rattling for months, and toward the end it became a lot quieter. The fan was old. There was a weird smell and I saw a spark inside...
Howdy,
If your fan is older, it may require oiling. On the motor you should see a hump, or a hole in the center of the housing, and then a small hole on the top side of the center of the housing. Inside is a wicking material which holds oil. When this dries out, you will notice the fan stops quicker and may take a while to get up to speed when you start it cold. Here's a video from a friend of mine on how to oil a fan. Yours should be similar to this.
Sep 23, 2010 | Lasko 2 Pack of 3733 3SPD 20 BOX FAN
My lasko fan stopped working after a power outage. the motor hums but blades dont spin
check the capacitor usually found beside the motor winding or inside the switch box of the stand fan
Aug 26, 2009 | Lasko 3135 Stand (Pedestal) Fan
Lasko Box Fan Stinks!
same thing with my lasko box fan awful oil smell
Aug 05, 2009 | Lasko 3720 Floor / Box Fan
Problem with a Lasko 3440 Floor/Box Fan.
light is on ,but there is no movement from the fan. I think I need a fan motor.Lasko 20" fan motor part #3440.
Mar 30, 2009 | Lasko 3440 Wind Tunnel Floor / Box Fan
Lasko fan
I can tell you how to take the fan blades off your Lasko Model 3723 fan, but you might not be able to use it on your other fan. The reason why is that the motors, although similar, may not have the same diameter shaft.
Of course, you should have the power cord unplugged from the AC outlet before removing the front fan grille and placing your hands on the blades. Safety first!
The fan blades and hub are a single unit that stretches to fit onto the motor shaft. There is no setscrew at all. Take any sort of metal bar or tool such as a screwdriver or pry bar and carefully lever the hub off the shaft by pressing your lever to lift the hub a small fraction of an inch on each side, working the hub slowly upwards against the long vertical bars that support the motor. If you have reasonably strong hands, you may be able to pull the hub toward you by placing your fingertips under the edge of the hub and pressing with your thumbs against the vertical support bars as needed. It's not too difficult to do.
Aug 15, 2008 | Lasko 3723 Floor / Box Fan
LASKO fan problem
Check for a loose wire in the wiring harness
Sep 01, 2007 | Lasko 2530 Elite WindTower Fan
Lasko 3723 Floor / Box Fan Logo
851 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
