Question about Kitchen Ranges
Opening the top of electric range to clean - Kitchen Ranges
  • 5,911 Answers
MOST range cook tops will lift up by removing the mounting screws located under the front edge of the cook top. You will need top open the oven door to see them. You should have two or more screws inserted from the bottom. Use care not to lean, or put too much weight on, the oven door while it is open. You can damage the door springs or hinges. If your rage is not configured in this manner, please post back with a brand name and model number so I can verify how yours in constructed. I hope this helps you.
Posted on Jun 14, 2009
Burner replace
open on side screw and lift top support.unplug power.
Feb 28, 2013 | Frigidaire 30" Self-Cleaning Slide-In...
Open the cooktop on a frigidaire fef369cgsd range
Hi Gail Muster - Unfortunately from my research for this particular model it is not possible to open the cook-top without a certified service tech.
Jan 15, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Between glass dirty on kenmore glass top range
the door must be removed from the oven and taken apart
Oct 23, 2011 | Kitchen Ranges
Whirlpool Accubake Duo System electric range fault coes E4 F3
F3 code correlates to oven temperature. Either the oven temperature sensor is malfunctioning or the over-limit switch is open. This is usually the result of using the self-clean mode and the over-limit switch gets stuck open. It has to be replaced...not too bad of a job if you have some mechanical/electrical knowledge. Ask parts supplier for a schematic so location can be visualized (inside top cavity on oven wall with a couple of wires. Also, Sears carries parts for these ovens. Hope this helps.
Feb 27, 2009 | Whirlpool GY396 Electric Kitchen Range
Self cleaned and now latch wont open
i have a whirlpool range , and on the top part where the touch buttons are it apperas eED-F3- AND THE OVEN DOOR IS LOCKED, THANK YOU PLEAS HELP
Feb 23, 2009 | GE Spectra JBP78 Electric Kitchen Range
Oven wont work
If the sensor were bad, the unit would throw a fault code. On the back of the range, near the top, there should be a tech sheet for you to use to troubleshoot the range. It sounds like a thermal sensor may have opened up. Consult that tech sheet, it should point you in the right direction.
Dec 12, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
202 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
