Question about Black & Decker String Trimmer Cordless 12" 18V
Black and Decker CST1000 will not auto feed.
The unit will not auto feed. I am using Black and Decker replacement spool.
SOURCE: changing spool on weed trimmer
useless
Posted on May 10, 2008
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
  • 12 Answers
SOURCE: I am trying to spool
Yes, it does feed automatically.
Please make sure the trimming line spooled in your spool regularly.
If above does not work, please go to service center to change a lever inside spool housing.
Posted on Aug 30, 2008
SOURCE: auto feed spool doesn't work
10 to 1 yours is doing what mine is, line comes out all over... I think there is a little spocket on the center shaft under the spool... When I replaced line I lost this part and know one shows this as a part on there web sites... I don't know what to do??????
Posted on Oct 13, 2008
Hightower971
  • 183 Answers
SOURCE: auto feed will not work
It's cheapest to buy a new one. I had that problem last year.
Posted on Apr 28, 2009
How to feed a b
hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Feb 15, 2012 | Black & Decker Garden
I have a cst1000 cordless trimmer. The recharging unit has failed. Do you sell a replacement that has the red and green lights indicating charging or charged?
Try this:
http://cgi.ebay.com/NEW-B-D-12V-VOLT-CST1000-Cordless-Grass-Trimmer-Charger-/200504468177?pt=LH_DefaultDomain_0&hash=item2eaeff62d1
If this has been helpful, please leave positive feedback. Thanks!
May 02, 2011 | Black & Decker Cst2000 12 - Volt Cordless...
Battery to fit Black & Decker CST20000 Grasshog weed eater. Where can I buy just the battery or battery pack?
Unfortunately, the battery pack as a unit has been discontinued, but the battery itself (part #243213-00) can be purchased online. Amazon sells it for $35.99. You can find it here:
http://www.amazon.com/Black-Decker-243213-00-Replacement-Grasshog/dp/B0027Z7G94
May 20, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
B & D auto feed string trimmer won't advance string
Is the string spool seated on the rachet correctly? If so and all is well, it is worth noting that these trimmers auto feed fuunction is problematic at best, requiring manually unwinding some line every few minutes as the unit gets older.
Apr 21, 2010 | Black & Decker 14" Grass Hog Xp...
I have a black & decker gt701 strimmer. i recently replaced the line on the spool but now it wont feed, ??
Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit.
Replace empty spool with new full one or wind on aftermarket string. Wind in direction of
arrow on spool. Make sure spool is seated on rachet firmly.
Apr 16, 2010 | Black & Decker Garden
Blackdecker cst1000 won't advance string
Wound too tight, crossed over, or spool not engaged on rachet mechanism.
Feb 22, 2010 | Black & Decker String Trimmer Cordless 12"...
I have bleck and decker grass hog auto feed and it does not work
There is a smalll white part below the spool called a "lever". This is likely in need of replacement. Call Black and Decker at 800-544-6986 with your Model No, and Date Code (stamped on the trimmer itself near where the extension cord plugs in). If it is still under warranty they will send you the replacement part - if not, I loooked it up and it's less than $3 for the part itself.
May 25, 2009 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
Auto feed spool doesn't work
You may need to purchase a new spool housing, which may not be too hard to do, if you have one of the name brand trimmers. This replaces the whole mechanism that holds the line, the retaining ring, etc.
Sep 21, 2008 | Black & Decker Black and Decker & Grass...
Black & Decker String Trimmer Cordless 12" 18V Logo
285 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
