Question about Black & Decker Hedge Hog 20-Inch 2.8-AMP Dual Action Hedge Trimmer #HS1010
How do I sharpen my trimmer
How do I sharpen my trimer
    Champion:
  • 356 Answers
WITH A FILE FRONT REAR ON BOTH SIDES.
POSITION BLADE BY ROTATING MOTOR FAN.
Posted on Jun 30, 2009
How to sharpen stihl gas power trimmer
Sharpen with a flat file. Its a long process as each tooth has 2 cutting edges. There are companies that will do this properly at cost.
Jul 15, 2014 | Stihl Hs81t 24" Double Sided Hedge Trimmer...
Brand new andis trimmer pulling hair and not cutting good
The questions about Andis T-Outliner or Andis Styliner II, about not cutting or pulling hair.
On the Andis T-Outliner trimmer if the sharpness of the blade is worn out, all the tricks and treats won't make this blade to cut hair. Before I do any kind of work to the trimmer, I first test the coil for the right amount power, I can get out of the coil, without this power, it doesn't matter how new or old the trimmer is, the trimmer will not cut hair at all. If the coil is good, I will sharpen the blade and set it according to your needs (lineups or shave setting) after the blade is sharpened and set. The trimmer will need to be, adjusted for alignment to the blade, adjust the power of the coil, and adjust the tension for the blade. All these factors are involved in the Andis T-Outliner to cut hair clean especially lineups or shaving. These adjustments work together for the trimmer to work properly. I know that we all trying to save money, which is part of life, but sometimes frustration will take over and say hell with it, I'll buy another or forget it. Manufactures make mistakes, sometimes the trimmer was not sharpened or adjusted correctly. Any case, what I'm trying to say here, if you try all the tricks & treats and can get your trimmer to work, it may be easier for you to send it to a professional to sharpen & repair the problem and set the blade according to your needs (lineups or shave setting) We specialize on Andis T-Outliner Trimmers. Our complete sharpening & repair service is $19.99 each trimmer, this includes return shipping. We sharpen the blade, adjust and set the blade according to your request (Lineup or Shave setting) make all the necessary adjustments for alignment, power, tension to make your trimmer work better than new. Our mail order service is one day turn around. We are well known throughout the United States for our service in sharpening. Check us out at www.mannys-sharpening.com or call us at 323 237-2885. Service You Can Trust Since 1990. Manny Mobile Sharpening and Clipper Parts Supplies
Nov 26, 2013 | Andis T-Outliner Hair Trimmer
Weedeater Excaliber Gas Hedge Trimmer. Is it possible to sharpen these blades? If yes, do you know the procedure?
You should be able to sharpen your hedge trimmer blades. There is a good video on how to sharpen hedge trimmer blades on youtube by ereplacementparts. He explains how to do it with a file or a grinder.
Aug 24, 2011 | Weedeater Excalibur Gas Hedge 22" Trimmer...
How do i sharpen the blades on my andis t-outliner, and give it whats called the New York, or east coast ...??
On the Andis T-Outliner trimmers I recommended sending it to a pro, these trimmer need to be adjusted correctly and the blade needs to be sharpen by an expert. at Mannys'Sharpening they have 20 years in the sharpening b's and they are experts in Andis T's they specialize on them. Manny's Sharpening has a mail order service they charge $15.00 to service & sharpening your trimmer plus the return shipping is free. the way you pay is via email via PayPal. and they will hook you up they way you want that trimmer blade to cut. check it out at Mannys-Sharpening.com also check their reviews on yahoo local.
May 10, 2011 | Andis T-Outliner Hair Trimmer
Will I be able to have my trimmer blade sharpened?
The blade can be sharpened, the problem is that these are not sharpened to ofter. Finding a person to do it will be.....difficult. I would suggest finding a knive or scissors sharpener, they would be able to handle this.
Hope this helps
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Nov 13, 2010 | Black & Decker 1 18Volt Cordless Electric...
How do I charge the battery for my cordless trimmer?
take the battery off the trimer its at the top off the trimer ann snap it into your battery charger plug it into the wall electical outlet
Jul 17, 2010 | Black & Decker String Trimmer Cordless 12"...
Can i sharpen my electic trimmers using sandpaper
Things You'll Need: Three-sided blade sharpener (coarse, medium, fine) Small flat head screwdriver step 1 Using the flat head screwdriver, unscrew the trimmer blades and remove them carefully. Wipe off any oil, grime or dirt that has built up on them as this may make it more difficult to handle and keep them in place during the manual portion of the sharpening process. Step 2 Separate the blades and re-apply only the moving blade to the tension spring. Then apply the moving blade to sharpener surface and turn the clippers or trimmers on. Hold the moving blade on the surface of the sharpener and apply light pressure while moving the blade back and forth for one to two minutes. You can also lay the blade on the sharpener first, then put the trimmer tension spring directly on the blade. Step 3 Turn off the clippers and remove the moving blade. It should look shiny and feel sharper. Step 4 Remove the guide from the guide blade by unscrewing it using the flat head screwdriver. Place the guide blade on the sharpening surface and manually run it back and forth for about one or two minutes or until it's been sharpened to your satisfaction. Screw the guide back onto the guide blade while being careful to readjust it before you tighten the screws. Step 5 Screw all the blades back on the trimmers and power them on to make sure they've been fitted correctly. Test them on your own hair to make sure they've been sharpened correctly and are set to the desired depth. Ads by Google Best Knife Sharpener Sharpen like the pros. Complete kit w/ 1x30 belt sander. Only $189.00 www.theedgemasters.com Braun® BodyGrooming Tools Try the Braun® bodycruZer? with Gillette® Fusion Razor Technology. www.Braun.com/BodyGrooming Oster ® Clipper Blades Oster ® Full Line Clipper Blades, Animal & Human Oster ® Blades. www.HouseholdAppliance.com STIHL Electric Trimmers Buy it. Plug it in. Trim it up. Depend on STIHL Electric Trimmers. www.STIHLdealers.com Tips & Warnings Which surface you choose, whether coarse, medium or fine, depends on how dull your blades are and how sharp you want to make them. If they are very dull, you will want to start with the coarse or medium side of the sharpener. If they just need a small amount of sharpening, use the fine side. If you've never sharpened electric trimmers before, you may want to visually observe and feel the sharpness of the blades with your fingers before you start to sharpen it. It may be hard to tell if the blades are sharp enough if you don't feel them just before you apply them to the sharpening surface.
May 02, 2010 | Andis T-Outliner Hair Trimmer
I need a carburator for my craftsman line trimer
You can get those online. Take the carb off and clean is so you can see the name and model of the carb. Once you have that, just go online and find the part. I sometimes use jackssmallengines.com. I get the correct part in a timely manner. Good luck...Lee
Nov 05, 2009 | Craftsman 25cc Gas Line Trimmer
My flymo hedge trimer is working but not cutting it is a eseicut 510
Probably need to sharpen the blades. Take it to a repair shop around town and they will sharpen the blades for you...............
Sep 20, 2009 | Heavy Machinery
Hedge trimmer not cutting
Try getting the blades sharpened. Also have them checked to see if they are tight together, sort of like a pair of scissors. If the screws holding the blades together are sloppy the blades can't cut.
Jun 22, 2009 | Garden
Black & Decker Hedge Hog 20-Inch 2.8-AMP Dual Action Hedge Trimmer #HS1010 Logo
983 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
