Question about Insignia 600W Bridgeable Amplifier with 12" Subwoofer
Which is better to run my power wire to?
Is it better to run my power wire from my amp to my fuse box, or straight to my battery?
  • 39 Answers
Run it straight to your battery!!!
DO NOT hang it off your fuse box.
Use good cable (depending on the length of run needed and size of amp not in watts, but in current draw. Use at least 6mm2) use a grommit through the fire wall, and you must fuse it near to the battery. Also use the same size wire for the ground. What goes in must come out!
Posted on Jun 14, 2009
  • 47 Answers
To your amp so you wont kill you battery
2007 Polaris sportsman 700 EFI and am trying to install a superwinch t2000 on it. I have the winch on already but my problem is it had one on that was wrecked and the switch was gone. My question is on the...
This winch should simple straight foward hook up. Your big red & black wires should hook straight to your battery. Red (+) black (-) if there is no fuse on the wires put at least a 20 amp.fuse close to your battery. These are the main power suply. They will go in a.small black box. Also coming out of the black box will be the wires that run to the cable in & out switch.and there should be one heavy ga. Wire going to the winch motor. Make sure the wire is good and clean when you hook it to the winch motor. Do not over tighten the nut . Just give a good snuging down. As for your solenoid box. That should be the little black box that your main power wires go into and controle wires come out of..
Nov 23, 2014 | ATVs
How to install jensen 40w+40w a-80
I have one of these new, in the box, with no instructions.
Specifications:
Power Output: 40W/Chan Maximum, 18W/Chan RMS
(20hz-20khz into 4 ohms at less than 1% THD)
Freq. Responce: 20hz-30khz, +/-3dB
Signal to noise ratio: 80dB, A-weighted
Input Sensitivity:
Low Level, 100-500 mV
High Level, 1-5v
Input Impedence:
Low Level, 10k ohms
High Level, 27 ohms
Load Impedence: 4-8 ohms allowable (4-8 ohm speakers)
Power Requirement: 14.4v DC (10.8-15.6 allowable)
As you can see the RMS wattage output of these units is only about 18W maximum.
I am planning on using the amp I have on a low power factory car radio. A low power factory radio output should be somewhere between 6-12 watts rms/channel. I will be using the "High Level" inputs for this. DO NOT connect a radio with a higher output power. If your radio says "High Power", 25W/channel, etc, do not connect to this amp. (exception: you can use the "line out" connectors, if so equipped, See Below). I don't have the connector for the high level input so i don't know what I'll do to hook up to it. I'll probably just run wires out of the amp, in lieu of the connector.
The "Low Level" inputs are for an unamplified, line level signal ("line out" connection of a radio, portable CD player, etc). Do Not connect a greatly amplified signal to these connections.
I don't know much about the "Input Sensitivity" control (pot). I'll be leaving it on "Low" for my initial test.
The grey wires are the right speaker wires and the white wires are the left speaker wires. The grey wire with a black tracer mark is the right speaker positive (+) wire. The white wire with a black tracer is the left speaker positive (+) wire.
The blue/white wire is for attachment to your radio's "Auto Ant" (power antenna) connection (usually a orange wire, I said USUALLY). If you have a power antenna on your car, simply splice into the wire running from your radio to the antenna. This blue/white wire activates a relay in the amp which, in turn, completes the circuit through the yellow (+) power wire (See Below). - Alternative 1: You could run this wire directly to your battery with a switch to turn the amp on. You would need to place an in-line fuse of 2amp. - Alternative 2: You could connect this wire to the accessory fuse in your fuse box. If this is done, again, attach a 2amp in-line fuse for extra protection. (Note: if attached to your fuse box accessory fuse, the amp will be on even if you're not using the radio. You could have a switch here also). These are just suggestions. The most common way to connect the blue/white wire is the "Auto Antenna" wire of your radio.
The large black wire is main Ground (-) for the amp. The large yellow wire is Positive (+) power to the amp. Ideally, these should be connected straight to your battery's (+) and (-) terminals. The yellow wire on your amp should have an integral in-line fuse holder with a 7amp fuse. If not, add one. Of course, the black ground wire could simply be attached under a screw, into the body of the vehicle.
Hope this helps !
Aug 12, 2012 | Jensen Car Audio & Video
Xterra car quit running. had no spark @ distributor. replaced crank sensor and got spark. no gas pressure. replaced fuel pump, new one do not work. no power to it. checked fuses/relays, no luck. ran...
the fuel pump fuse is fuse #1 15amp in the inside fuse box ( left side of dash behind fuse box cover ) the fuel pump relay is behind left side of dash ------- cavity #2 & #5 at the relay should have battery voltage in start and run cavity # 3 is the power out to fuel pump and cavity #1 is the ground that is turned on by the on board commputer.
Jan 15, 2011 | Nissan Xterra Cars & Trucks
Maystar MX2200 200 watt Mofset Amp. Single Sub Car wiring
The inline fuse goes on the power wire (as close to battery as possible), and is there for a sfety feature to keep from sending to much power to the amp. All it does, is simply blow if the power gets over the specified amperage. For your amp, I would use a 40-60 amp fuse.
The remote power line, is simply an 18 gauge wire, running from the headunit to the amp. All it does is tell the amp when to power up. Since the amp is straight to the battery, it is possible to be on at all times, so you run it to the amp so it knows when to be on. If your headunit doesnt have a remote turn on wire, then tou need to run it from the ingnition to the amp.
For a signal cable, I recommend getting an rca cable to run to the amp from the headunit. Make sure when you run it that you run it away from the power wire to prevent from having engine noise.
You also need a ground wire, wich should be to a stud on the frame of your car, as close to the amp as possible.
When hooking up your amp to the sub, you need to run the negative to the negative (black to black) and the positive to the positive (red to red).
Oct 23, 2009 | Car Audio & Video
I need to know how to wire the power cables and other wires to the amp and then to the subwoofer plz can you help me nath
hey dennis if you have a standard car amplifier all you need to do is run a wire from the battery post straight from the battery to amp batt+ post, then negative side can also be run straight from battery negative, than the remote post on your amp. you can either utilize the power antenae circuit coming out of the stereo unit or an ignition power from your ignition power fuse box so you don't draw battery power when key is off, please reply back if your stereo unit has rca output and does your amp. have rca connection(rca connections are red and white audio cable style connection).
Sep 28, 2009 | Car Audio & Video
2007 galant factory radio amp instal
Run a fused wire from your battery to your amp location. Ground amp to chassis, let ground be no longer than 20 in. For remote turn on wire, run a wire from your fuse box, to your amp and plug it into the R.E.M. slot on the amp. remember to put a switch in the wire somewhere easily accessible from drivers seat so you can easily turn your amp on, and off. If the switch isn't off it'll drain your battery when your car's not on. To attach signal wires, make sure your amp has highlevel inputs, splice wires from your speaker wires, and hook them up to the H.L. inputs on your amp. However, my advice as an audio enthusiast, and experienced installer is get an aftermarket unit. Sound quality is much, much better. Less distortion, better radio reception, much better music tuning ability. A good unit can run you a lot of money but, if your planning on driving this car for a long time, invest in an after market unit, you will not regret it. But if you don't want to then there's your instructions, if you have any more questions, please ask..
Sep 20, 2009 | Stingpro ST444 1850 Watts Complete...
Using 12 gague wire on a 250 watt amp blowing fuse
Oh my yes. I would recommend number 4 as a minimum. Use the same size for the ground. Bond it to the body in the best way you can. Use a CAD welder if you know anyone in the pipeline industry.
But ideally, run the biggest guage you can afford. and FUSE IT!! Zero Guage or better, and buy a fuse block and put it at the battery. Otherwise your crash could be a crash and burn.
Apr 15, 2009 | Car Audio & Video
F 450 instrument cluster has no power and is inop need to trace wires to power source
Interior fuse box fuse no.33(15amp) supplies power in run/acc postion to BK/PK wire pin 19 of cluster.
Interior fuse box fuse no. 45(10 amp) supplies power in the start or run postion on the RD/YE wire pin 20 of cluster.
Interior fuse panel fuse no. 41(10amp) supplies power to the battery saver relay on LG/OG wire pin 11.
Interior fuse panel fuse no. 35(10amp) supplies power to interior lamp relay on BK/LG wire pin 12.
The last 2 are hot at all times.
Apr 11, 2009 | 2004 Ford Super Duty F 450
Alpine v12 amp no power
its your fuse box. i would bypass the fuse box and wire this amp directly to the battery via monster cable. make sure you attach a 30wieght fuse to the monster cable that is running from the battery to your amp. ground the amp against the trunk. scrape the paint of a section and drill a hole in the trunk. use this for the ground for you amp. this will fix the no power issue.
Feb 12, 2009 | Alpine MRV-T707 Car Audio Amplifier
LED is on, but no sound
If the LED is on then that pretty much means that your remote wire is functioning properly but that does not always mean that the amp has power
The 40amp fuse connects to the main power wire that is run from the battery to the amp and must be connected at the battery end NO MORE THAN 18 INCHES from the battery but the closer you can put it to the terminal the better since this fuse protects you car from extreme damage or fire that can occur if the amp power wire should happen to short out.
TIPS:
Power wire from battery to amp needs to be at least the same size or bigger than recommended for the amp (the longer the wire the thicker it should be)
Always Run amp power wire through a rubber grommet to the engine compartment to avoid wire short that can be caused when car parts move and flex during driving
Run power wire on separate side of car away from RCA cables to avoid noise in the system
Oct 18, 2008 | Kenwood KAC-9103D Car Audio Amplifier
Open Questions:
Insignia 600W Bridgeable Amplifier with 12" Subwoofer Logo
126 people viewed this question
Top Insignia Car Audio & Video Experts
Marvin
Marvin
Mark Skinner
Frank Mangiapane
Level 1 Expert
Are you an Insignia Car Audio and Video Expert? Answer questions, earn points and help others
