Question about Mitsubishi WD-62827 62" Television
I have a Mitsubishi WD52525. Green timer light blinking, tv won't come on. Read all directions for troubleshooting in owner's manual. Have pressed reset button, timer light never stops blinking. Unplugged tv, same problem. Thanks for your help!
  • noelf13 Jun 15, 2009
    Thank you hatman1 so very much for your response! Very fortunately we still have an extended warranty on the tv which expires in November so we won't have to pay for it. Before my girlfriend remembered that I did call Mitsubishi and they wanted me to send them an authorized dealer diagnosis and estimate which Mitsubishi would review and respond to within a few days. Again, thank you so much for your professional response!
  • 126 Answers
You are not going to like this one little bit. The reason the LED won't stop blinking is because the digital module is not booting up. I have been fighting this model Mitsubishi for over five years now and the only solid fix is to send the entire chassis back to Mitsubishi for rebuilding. Pulling the chassis is a major job and with shipping costs and Mitsubishi's charges this repair usually runs around $750 to $850. However many owners that contacted Mitsubishi about this problem have gotten that portion of the repair bill coverd. That still leaves $300 to $400 for the tv shop that pulls the chassis and reinstalls it once it is rebuilt.
Posted on Jun 14, 2009
I have a wd52525 the status light keeps blinking
There are 3 different LEDs on the front of this televison. The TIMER will blink green. The STATUS will blink orange and the LAMP will flash red or orange depending on if there is a failure or if the lamp timer is showing over 5000 hours.
If I answer your question directly and the status is blinking a steady orange light, then you have left the side filter cover or the front lamp cover off or they are loose.
Also holding the menu and device buttons together until the timer light blinks will reveal a code that will help in diagnosing your problem. Goodluck.
Jul 04, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubiushi wd52525 nstatys ligts keeps blinking green. Lost power when the TV was on and now i have a status light that just keeps blinking green.
Unplug for a minute, when pluged back in light should blink for a few then go out, should be able to power on after that!
Dec 25, 2009 | Mitsubishi WD-52525 52" Rear Projection...
AFTER A POWER FAILURE GREEN TIMER LIGHT WILL NOT STOP BLINKING. HAVE TRIED TO RESET TIMER, UNPLUGGED POWER SOURCE. THIS IS A MITSUBISHI DLP WD52525
The Capacitors on the DM board need replaceing. The V26 DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the capacitors and the CD with instructions.
Dec 14, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Blinking timer Light (Green)
Thats a common problem caused by defective capacitors on the DM PWB which prevent the set from booting up. The V26 DLP DM kit at the following link will usually repair that issue and it comes with step by step instructions on how to do the repair. Look under the repair kit category.
http://servicemanuals.vstore.ca/
Mar 14, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Green Light on Mitsubishi WD-62525 keeps blinking
Fluke solution: Press and hold Menu+Enter on front of TV...
WD-62525: My Green Blinking Fix!!!
http://www.avsforum.com/avs-vb/showthread.php?s=eb9ba9017a86fd9993de5feb77ee5f25&p=17646001#post17646001
Jan 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No picture no sound
it sounds like the chassis has gone bad. check out www.tv-techs.com
Dec 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I need the schematic for mitsubishi television wd52525
go to www.blinking-green-light-of-death.com
it shows available.
Nov 02, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Mitsubishi WD52525 DLP Projection TV
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 29, 2008 | Mitsubishi WD62628 62" Projection HDTV
Mitsubishi WD-62827 62" Television Logo
490 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
