Question about Fisher and Paykel IWL12 Top Load Washer
At the spin cycle the pump is coming on and off then stops and we get the 1 second continuous beep. We have five lights on. I was told by the operator that it meant the balance switch is not working or is on so it doesn't work. There was a blanket in the washer when it happened. I have replaced the main board and the temp sensor in the past. Is the balance switch the one with the long white rod sticking down? This was the only thing not replaced when the temp sensor leaked and damaged the board. Can this be by-passed to check if this is the problem?
  • 1,959 Answers
I've got a F + P washer and had the same problem. It usually occurs when there's very little in the tub, like you described, just a blanket. The balance on the machine is very fussy and will trip at the slightest sense of an overload on one side or another. With the lid open, grasp the tub on either side and move it side to side while lifting ( don't be afraid to use a little bit of force). This will rebalance the tub and it should advance to the spin cycle. If it doesn't work the first time, it make take a few attempts. Best of luck and please post back with any other questions.
Greg
Posted on Jun 14, 2009
It was on the last cycle spin it stopped had pumped the water out but stopped spinning.
Expert Tips, Troubleshooting & FAQs - Fisher & Paykel ...
https://www.fisherpaykel.com/us/support/expert-tips/Fisher & PaykelFind Tips, Troubleshooting Information, How-tos, FAQs and Answers to Commonly Asked Questions about Fisher & Paykel Appliances.
also on Youtube
Aug 17, 2015 | Fisher and Paykel Washing Machines
Why my washing machine will start the wash cycle but will not spin or rinse?
the drain pump is probably blocked or overheating, when it starts beeping which lights are flashing reading from right to left e.g. 1,3,5 also what is the model number?
Aug 17, 2014 | Fisher and Paykel Washing Machines
Simpson ezi 950 9.5 will not empty, rinse, spin dry.
That sounds like the pump is jammed. Have you checked for hair slides or similar? Once the pump is free to operate, your Simpson should resume normal service.
Feb 20, 2014 | Washing Machines
GWL15 fisher and paykel stops mid spin
If the only light on was the spin when it was beeping,
That is fault code 1
1. (00000001) Motor Control Module Fault
The Motor Control Module has encountered an error when writing to an EEPROM address.
Primary Source: Motor Control Module.
Action: Replace Motor Control Module.
Mar 18, 2013 | Fisher Paykel EcoSmart GWL15
The alarm beep which tells you to close refrigerator or freezer door now beeps even after either door has been closed. It beeps three times at approx twenty second intervals, then beeps continuously for...
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
Good luck......
Aug 15, 2010 | Fisher and Paykel Active Smart® E522BR...
Machine stops and will not move to next cycle--spin
Sounds like it it not recognizing that the lid is closed, could be a bad lid switch.
Apr 14, 2009 | Fisher and Paykel Fisher & Paykel Washer
GLW10US won't do anything but beep
well i don't have any experience with this brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
Feb 16, 2008 | Washing Machines
1 beep per second and odd light sequence
there some simple solutions but may not always work but everyone should try. underneath when the water pump engage with the tub. there;s a white plastic clip press it out and turn the water pump. it will come off the tub. before doing this you should have the washer disconnected. have someone or put something under so the washer won;t fell on you while reaching down. sometimes debris gets stucks on the way from the tub to the pump. it insert your fingers inside once the pump is taken out and if you find debris take it out. put back the pump and connect the washer again. this can be a very simple solution it won;t work all the times. but what if it does. :)
Jun 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel IWL12 Top Load Washer Logo
54 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
