Question about Cooper Lighting Lighted Switch
Need to know wiring diagram for cooper single pole lighted switch
Trying to install ceiling fan with light on two seperate cooper lighted single pole switches to control ceiling fan and light independently and can't figure out wiring diagram for switches.
  • Anonymous Mar 27, 2014
    Where do the wire attach on a cooper 15a lighted switch
  • 76 Answers
Well lets see on one side you should have two brass screws that would be to interupt your lead to the fixture then you either have a brass and silver screws on the other side or you have black and white wires the black or brass is always hot the silver or white is neutral does that answer your question if not hit me back with a description of what your switch looks like
Posted on Jun 27, 2009
Separate 1 switch 3 lights
You need separate wire going to each light.
Here are diagrams:
2 single pole switches, before you started to replace
http://waterheatertimer.org/images/2-single-pole-switches.jpg
Single pole and 3 pole to control each light separately: must identify black wire to each light. If each light does not have separate black wire inside the switch box, then it is not possible.
http://waterheatertimer.org/images/single-pole-and-3-pole.jpg
Add a comment
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jul 05, 2013 | Electrical Supplies
I have a new paddle light switch im trying to install and for some reason it keeps poping the breaker. im wondering if im installing it correctly
make sure you are hooking up the correct color wires to it main wire on top of switch, bottom wire of switch other color wire they should be blackor any other color , just dont hook up the white wire to it this will make your breaker pop , If your copper is touching any metal this will make it pop also,good luck
Jul 29, 2011 | Cooper Industries Cooper Wiring: Single...
I have a single pole switch that currently controls a bedroom outlet. i am installing a fan and light in the bedroom. i have a new triple switch that i want to control the existing outlet, the fan and the...
Wiring is not fully described: Location of hot wire and neutral wire from breaker box are unknown.
If Hot wire arrives in ceiling box first, the switch box will not have white neutral wires that are twisted together and covered with wire nut. Neutrals will be in ceiling box.
What is known: You are replacing single pole switch attached to one 14-2 wire going to light.
You are replacing light with a fan-light and replacing switch with a 3-pole TM8111 switch.
You have replaced 14-2 wire with 12-3 wire.
TM8111 wiring shows following link:
http://waterheatertimer.org/images/TM8111-switch-wiring-500.jpg
Fan pull-chain wiring shows following link:
http://waterheatertimer.org/images/Fan-motor-1-344.jpg
Assume neutrals in ceiling box.
Assume Hot wire in ceiling box: Connect 12-3 black wire to black Hot wire. Connect 12-3 white wire to black wire on light. Connect 12-3 red to red wire on fan.
White neutral from fan and white neutral form light connect to other white neutral wires and covered with wire nut.
Wiring at switch:
Black Hot wire from ceiling box connects to A COM terminal.
White wire to ceiling light connects to A SP2
Red wire to fan connects to A SP1
Jun 21, 2011 | Pass & Seymour Legrand TM8111 Three Single...
I"m installing a Cooper Devices
Wiring is suspect.
Black hot wire connects to dark screws.
Break off tab should be intact.
White neutral wire connects to silver screw.
Wire going to switch load connects to brass screw.
Jun 18, 2011 | Cooper Industries Cooper Wiring 274W...
I need the wiring diagram for a Cooper 277W single pole switch with pilot light. The light is to be on when the switch is on. Thanks!
I have 120Volt cooper 277 pilot light switch here in my office.
Dang instruction sheet shows wiring for all kinds of cooper devices.
EXCEPT pilot light switch.
So I tested with multimeter and came up with following:
Key to any wiring device is color of screws.
Hot from breaker box always goes to dark-colored screws.
Neutral always goes to silver-colored screws.
Brass screws are for Hot wires from breaker or Hot going to Load
Green screw - ground
Dec 03, 2010 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
Hi i have a 9501ws c aspire single pole switch i am not sure about the connection of the whites do i run both blacks to the switch and tie the whites together this is a ceiling light thanks steve
Here is a site with a simple wiring diagram for a single light switch...
http://www.ask-the-electrician.com/Pics_Diagrams/singlepoleswitchdiagram1.JPG
Nov 28, 2010 | Cooper Wiring Devices "COOPER WIRING"...
Three way switch does not work properly
Very interesting problem! But easy to fix. It's not a defective switch, just a minor wiring error, which would be very hard to solve via back and forth text. So, instead of trying to figure out exactly which wires and terminals to swap at the new switch, it would be much easier to simply swap the light and fan wires at the ceiling fixture, I hope this is helpful. Good luck, Al Kupchella
May 16, 2010 | Pass & Seymour / Legrand 1595-2SWT...
Hunter fan/light control wiring
solution depends on how many wires are in the ceiling box. was there a ceiling fan in place before? were the light and fan controlled by seperate switches or was there only one switch? if two switches, then there should be two seperate hot wires in the ceiling box. if only one switch, then only one hot wire in box. if only one, then your black and red from the fan will wire together to the single hot. green goes to the bare copper wire, if not one, then not needed
Aug 14, 2008 | Hunter Ceiling Fan Light Switch Control
Cooper Lighting Lighted Switch Logo
2,373 people viewed this question
Top Cooper Lighting Electrical Supplies Experts
Craig Butler
Craig Butler
john h
Gene Haynes
Are you a Cooper Lighting Electrical Supply Expert? Answer questions, earn points and help others
