Computers & Internet Logo
James Hayes Posted on Mar 17, 2014
How do I reset a computer that was in someone ele's user name and password
Santiago Hernandez
Level 1:
New Friend:
Problem Solver:
  • Contributor 16 Answers
  • Posted on Mar 17, 2014
Santiago Hernandez
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
16
Questions
0
Helped
1541
Points
18
You will need to reinstall Windows on that computer. If its an older computer, it will come with a disk to reinstall Windows and restore the computer to factory defaults.
5 Related Answers
Anonymous
  • 124 Answers
  • Posted on Dec 02, 2008
SOURCE: I set a password and
You'll need a password reset disk, such as this one:
http://home.eunet.no/pnordahl/ntpasswd/
Burn that to a cd, boot off it. It may seem a little daunting as it is a unix-based tool, but it's surprisingly simple. Just follow the onscreen instructions and select the disk and the user account and you can either change a password or blank it.
mashoodh
MUHAMMAD MASHOODH
  • 70 Answers
  • Posted on Apr 18, 2009
SOURCE: unknown user name and password for securing reset
default user name- admin default password - admin
hecongyan
hecongyan
  • 39 Answers
  • Posted on Apr 19, 2010
SOURCE: someone has reset all my login passwords to
reset windows password
Anonymous
  • 101 Answers
  • Posted on Sep 17, 2012
SOURCE: forgot user name an password
You can use Smartkey Windows Password to help you to reset computer password, and see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html
Roman
  • 6 Answers
  • Posted on Feb 17, 2014
SOURCE: forgot user-domain name and password for win xp pro
Contact your company support to reset your password...
Trying to connect new android tablet to existing netgear router but cannot find password.how can we talk to someone?
Launch a web browser from a computer.
Type http://routerlogin.net into your web browser's address bar.
The user name is admin and the default password is password.
You will be able to view or reset your WiFi Password from this interface.
tip
Methods to reset your Windows XP password
There is nothing to worry if you forgot your Windows logon password or if your password expires. You can reset your Windows password by following instructions given below.<br /><br />You cannot reset password unless you have reset disk or can log on as an administrator. You may need to reinstall your operating system before using computer again. This is an essential safety measure setup by Microsoft Windows. Without this, anyone could change a password of anyone's computer. <br /><br />Reset Windows XP Home Edition Password<br /> <br />There are two methods to reset Windows XP Home Edition password<br /><br />First Method: <br /><br />To reset password you may need to log on as an administrator. Follow steps mentioned below to log on as an administrator <br /><br />a. Reboot the PC.<br />b. Press CTRL+ALT+DELETE couple of times, and then type the name of the administrator user name or just type 'Administrator'.<br /><br />c. Type your administrator password in the password field, and click OK. If you do not know the password, leave it blank, and click OK. <br />d. Press Start button on the taskbar, and click Run.<br />e. Enter control user passwords 2, and click OK button.<br />f. Open Users tab, select the user account form the list that you want to reset the password for, and press Reset Password.<br />g. Select a new password and Enter it in the new password field and then type that password again in the confirm password field, and then press OK.<br />h. Reboot the PC, and try logging in to the computer. <br /><br />If your computer is a member of a domain then follow these steps:<br /><br />To log on to the window as an administrator: <br /><br />a. Reboot the PC, and press the F8 key during the boot until the Windows Advanced Options menu appears.<br />b. Select the Safe Mode option, and press ENTER key.<br />c. Select Microsoft Windows XP edition, and press ENTER key. <br />d. Click your user name screen button, then click Administrator, and enter the administrator password in the password field.<br />e. Press ENTER key, and click Yes. <br /><br />To reset the Microsoft windows password:<br /><br />Click Start button on the taskbar below and then click Run.<br /><br />f. Enter control user passwords 2 in the text field, and click OK.<br />g. Pick the logon user name for which you want to alter the password.<br />h. Click on Change the Password, and enter a new log on password. <br />i. Press Change Password button.<br />j. Reboot the PC, and then log on to the windows. <br /><br />The Second Method: Using a password reset disk<br />To log on to the computer by using a password reset disk, follow the steps outlined below. <br /><br />Reset password for Windows XP Professional Edition<br /><br />1. Reboot your PC.<br />2. Click the user name, you'll see an error. <br />3. Click on the Use your password reset disk. The Password Reset Wizard window will open.<br />4. Click Next.<br />5. Insert the password reset disc into the CD/DVD drive, and click Next.<br />6. Type a new password and confirm the password in the required fields, then click on Next.<br />7. Click Finish, log on to the PC again. <br /><br />
on Jan 18, 2011 • Computers & Internet
tip
How to Reset Windows Password With an Standard User Account?
When you <a href="http://www.windowsloginrecovery.com/forgot-windows-password.html">forgot Windows password</a>, did you feel confused that why you cannot reset the forgotten Windows password via standard user or guest account? The answer is very simple as the standard user and guest accounts do not have rights to reset the password of another accounts. Within the three types of Windows user accounts, only the administrator account allows you to change another accounts' password. So if you want to <a href="http://www.windowsloginrecovery.com/reset-windows-password.html">reset Windows password</a> of another accounts, you need to change your account type to administrator firstly. Moreover, if you need to give a user more access to perform tasks like installing software or other system changes, you also need to change your account type.<br /><br /><span style="font-weight: bold;">Steps to Change Windows User Account Type</span><br /><br />1. Log on your Windows machine with an administrator account.<br /><br />2. Click "Start" - "Control Panel" - "User Accounts and Family Safety" - "User Accounts".<br /><br />3. Click "Manage another account".<br /><br />4. Click on the user account that you would like to change its type.<br /><br />5. On the following window, click "Change the account type" from on the left pane.<br /><br />6. Select Administrator and click "Change Account" Type to finish your operation.<br /><br />Since the standard user account turn to an administrator one, you can reset Windows password of another accounts or do other operations without limitation through control panel.<br /><br />You can change standard user to administrator only when you can log on your computer with an available administrator account. If you forgot Windows password of all administrator accounts, you'll need to reset Windows administrator password even you can access your computer with a standard user or guest account.<br /><br />Software Windows Login Recovery allows you to create a password reset disk with blank CD/DVD or USB flash drive. With the disk you can reset Windows password to be empty in few minutes. With it, you'll never be worried when you forgot Windows password. All you need to do is just three steps.<br /><br />1. Download and install Windows Login Recovery.<br /><br />2. Burn a password reset disk with a blank CD/DVD or USB flash drive.<br /><br />3. Reset Windows password to be empty.<br /><br />Now you can log on to your computer without passwords. By the way, you can reset any account's password with this software. <br /><br /><span style="font-weight: bold;">Something about Windows User Accounts</span><br /><br /><span style="font-weight: bold;">Administrator:</span> A administrator account is intended for someone who can make system wide changes to the computer, install software, and access all non-private files on the computer. Only with administrator rights you can full access to other user accounts on the computer, change other their names, passwords, and types.<br /><br /><span style="font-weight: bold;">Standard user:</span> The standard user account can help protect your computer by preventing users from making changes that affect everyone who uses the computer. When you log on to Windows with a standard user account, you can do anything that you can do with an administrator account. But if you want to install software or hardware, reset Windows password of another accounts, etc. the computer might ask you to provide a password of an administrator account.<br /><br /><span style="font-weight: bold;">Guest:</span> A Guest account allows people to use your computer without having rights to access to any of your personal files. This can be useful if you want to quickly allow someone to use your computer. A person that log on computer with guest account cannot install software or hardware, change system settings, or create a password.
on Dec 24, 2010 • Computers & Internet
I have an acer notebook running windows 7 and someone has chnaged my user name and password how can i get past it
It is imperative you get that password!
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode. XP only.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
  • Free software option would be Hirens Boot CD. This one is command prompt only. http://www.hirensbootcd.org/ Must follow instruction exactly.
Inspiron1525 wont let me sign in
Wait at least a half hour before trying again. That is a common lock out period, though not used in home situations. Ask if someone changed it. The options are not good.
tip
Windows XP-based computer if you forget your password or if your password...
<span>To log on to a computer as the administrator to reset a password, try the following steps. <ol> <li>Log on as an administrator. <ol> <li>Restart the computer.</li> <li>Press CTRL+ALT+DELETE two times, and then type the name of the administrator user account.<br /><br /><b>Note</b> If you do not know any other administrator user account, try to type <span>Adminstrator</span> in the User name</b> box.</li> <li>In the Password</b> box, type the administrator password, and then click OK</b>. <br /><br /><b>Note</b> If you do not know the administrator password, leave it blank, and then click OK</b>.</li></ol></li> <li>Reset the password. <ol> <li>Click Start</b>, and then click Run</b>.</li> <li>Type <span>control userpasswords2</span>, and then click OK</b>.</li> <li>On the Users</b> tab, click the name of the user account that you want to reset the password for, and then click Reset Password</b>.</li> <li>Type a new password in the New password</b> box, and then type the password again in the Confirm new password</b> box, and then click OK</b>.</li> <li>Restart the computer, and then try to log on to Windows XP again.</li></ol></li></ol></span>
on Nov 23, 2010 • Computers & Internet
1helpful
I had someone set up my new NetGear Router, but the said the User name was blank and gave me the password, but I can't access the intranet settings without a use name. Can I reset this myself? I...
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
Someone knows my password and i want to change i to make it in private...
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
hope this helps
PASSWORD
If this is a new router and you have not set your own password, the login info should be: user name: user password: (leave black)
If this is not a new router or someone else has set it up and might had change it and you have no way of knowing what password the used, then reset the router (there should be a lil button on the back side labeled 'reset', you will need a pen or small thin object to press it, and make sure you hold it in/pressed for about 30 seconds). Then use the user name (user) and password (leave it black, no password by default) I stated above!
good luck!
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
