Question about Samsung LN-S4051D 40 in. LCD Television
Samsung Plasma TV 'green screen'
I have a newer Plasma TV and am now getting 'green screen'. Have checked all cables for tightness, and also tried playing a DVD...same problem....grainy green screen. Any help greatly appreciated.
3 Suggested Answers
  • 58 Answers
SOURCE: PN50A450 Samsung green screen problem
This is a problem in one or more boards in the TV.
If your TV is still under warranty please call Samsung to get if fix at not charge.
parts for your tv are not cheap and labor is not eider.
Posted on Jun 15, 2009
  • 541 Answers
SOURCE: Samsung plasma R4272, sound, but no image on
Sounds like an X or Y drive board. They are the heart beat for driving the plasma display. Without them both you won't see anything.
Posted on Oct 13, 2009
How do I fix Samsung ue40h5030ak led tv that the screen is flashing red green blue white
LCD panel fault. If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Sep 26, 2016 | Samsung Televison & Video
Green and purple vertical ribbons 2cm wide on 42 inch plasma Samsung. appear and continue after initial warm up of tv.
screen fault or screen driver fault. or even a lose cable to the screen. check and clean un clip the screen driver from the screen cables and clean them to then refit see if gone back to normal. if not it could need a new screen or driver board.
Sep 19, 2013 | Samsung Televison & Video
Screen block out with volume working
check all the input cables and make sure there in tight. also unplug the tv and then replug and ture on this should reset all settings
Mar 01, 2011 | Samsung 50 in. Plasma TV
LG Plasma Green Screen
First thing to do would be to check your cables feeding into the TV. If you're using component cables, it's likely that your red and blue cables have come unplugged and all you're feeding to the TV is the green signal. However, if you're using a different set of cables or they're all plugged in properly, I would first suggest swapping out the cable for a new one. In newer televisions, such as yours, each of the colours is transferred through separate channels regardless of the type of cable used.
If either of those don't help then I'm afraid you've got an issue with the charging of the phosphorus gas itself, either it's not receiving the power correctly or some of the gases are remaining inert and not charging. If you're at that stage, you need to seek technical assistance from a service depot or LG.
Best of luck!
Dec 08, 2009 | LG 60PC1DC 60 in. Plasma HDTV
Everytime I use hdmi the colours are mostly green
I have a panasonic th42pa 60a SD plasma and I get the same problem WHEN USING CERTAIN HDMI cables. I had a connexa brand with my samsung stb that i got with the TV and I had no problems., but i had to replace that because one of the ends "frayed" when it was accidently yanked out of the tv socket. A high quality monster cable did the same green screen you describe. The cheapest "Crest" from Big W that did HDMI standard 1b worked fine, but a Rank Arena from Target did not. So buy the cheapest HDMI 1b cable you can, the picture quality and sound is the same as the more expensive stuff. BTW I tried a HDMI 3 way splitter as well and it did the same green screen thing, but it worked on a later model panasonic plasma. I think it is Pana's poor HDMI implementation.
Dec 05, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Red blue green lines down my lcd tv screen
HP-R4252 NOT LCD TV
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
Aug 15, 2009 | Samsung HP-R4252 42 in. Plasma HDTV
Jun 15, 2009 | Samsung PN50A450 50 in. Plasma HDTV
Green and purple scrolling lines
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 27, 2017 | Samsung LN52A850 52 in. LCD HDTV
Thin green line on right side of screen when watching through HDMI cable...line goes away when watching through reg AV inputs
You should check if you could adjust the screen size or posistion. If that don't work try using another (newer) HDMI cable. If everything feals go back to your store and claim a new tv. Then it is the hardware inside the tv, you will have warrenty on that.
Dec 24, 2008 | Philips 42FD9954 42 in. Plasma HDTV
All green screen
You need to repower the cable box. That should fix it.
Good Luck
May 04, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Samsung LN-S4051D 40 in. LCD Television Logo
588 people viewed this question
Jerry Greenberg
Jerry Greenberg
