Error message SATA unplug lg bd300
Error message ''SATA unplug'' lg bd300
Dvd player will not power on
The power supply regulator board to your player has damaged. There is a protection fuse on the power supply regulator board. Check it first. If found blown, replace an other one of same rating. If the this fuse also blow out, as soon as you switch ON the set, make sure that, the poser board is damaged. It is best to replace it as card basis, rather than trying to make it repaired. In most cases, repaired boards found not last long. Contact the nearest LG service center to buy a new power supply card.
Jun 13, 2012 | LG Televison & Video
My BD300 which is just over a year old has stopped reading DVDs. It displays 'Reading' then 'Disc Error' and ejects them It still plays Blu ray
Hello
Just reset the player to its original factory settings and try. If the BIOS ic has confused with so many external commands, this type of problem will occur. By reset it to factory settings will clear the BIOS. To reset do the following.
Press and hold the POWER button for more than
five seconds. This will force the Player to power
off. Press the POWER button again to turn the
Player back on.
Unplug the power cord and then plug the power
cord again after more than five seconds
OK.
Jun 25, 2011 | LG BD300 Blu-Ray Player
LG BD300 won't play DVDs after doing LG's update
same problem either i get a message that there is a non compatible disk in the drive, or if it plays, it will crash to blue screen in about 30 seconds.
Oct 21, 2010 | LG BD300 Blu-Ray Player
My Blu Ray won't play any of my movies. It keeps saying Disc Error, check disc, and it ejects. It even won't play the Lens cleaning CD. What should I do?
i would take it back where you bought it from, if you can. If not I would take the nearest repair shop, it sounds like you need a new head.
Dec 12, 2009 | LG BD300 Blu-Ray Player
LG Blu Ray Player Disc Error for most Normal DVDs
Perhaps you may need to use a lazer cleaner in your blue ray player
Sep 18, 2009 | LG LXD5230 System
BD300 will not play a Blue Ray DVD. Do I have to
If it plays a normal DVD then the answer is maybe. If it played Blu ray before I would try cleaning the eye! If it never played Blu-ray then your unit is bad. Suggest sending it directly back to ther factory!
Rate this answer....
Jul 10, 2009 | LG BD300 Blu-Ray Player
LG BD300 dvd palyer region free code
To set DVD Region to “0”, download file “6000.zip” (often also called “LG6000.zip”) from here:
http://www.multi-region.net/_media/6000.zip
Save the file and then unzip and extract it to your hard drive.
Now burn the subdirectory RMTM0000 and its contents (not the text file) onto a CD-ROM (ISO format, “closed” CD-ROM).
Insert CD-ROM into the LG BD 370 P player, and when the Region Management System screen is displayed, set the Region Code to “0” using your remote. Once done, press “PAUSE” on you remote to save, and you’re done!
Mar 03, 2009 | LG Super Blu BH200 Blu-ray and HD-DVD...
Televison & Video Logo
385 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
