Question about Tascam Quantegy 120 Minute Digital Audio Master for DA-88
Tascam DM-24 power supply voltage (+5v) too low for stable operation. Is there an internal adjustment for the power supply voltages?
    Problem Solver:
  • 6 Answers
Power supply needs to be replaced
Posted on Aug 16, 2009
How do i turn on a compaq ps-7231 power supply?
Pin Name Color
Description 1 3.3V Orange +3.3 VDC 2 3.3V Orange +3.3 VDC 3 COM Black Ground 4 5V Red +5 VDC 5 COM Black Ground 6 5V Red +5 VDC 7 COM Black Ground 8 PWR_OK Gray Power Ok is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation (+5 VDC when power is Ok) 9 5VSB Purple +5 VDC Standby Voltage (max 10mA, max 2A in ATX 2.2 spec) 10 12V Yellow +12 VDC 11 12V Yellow +12 VDC 12 3.3V Orange +3.3 VDC 13 3.3V Orange +3.3 VDC. ATX V2.3 / EPS12V V2.92 both define that the PSU has to use remote sensing to compensate cable drops on the 3.3V line. Because of this there is an additional brown cable crimped together with the orange cable either to pin 13 (ATX) or pin 1 (EPS12V). 14 -12V Blue -12 VDC 15 COM Black Ground 16 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF. 17 COM Black Ground 18 COM Black Ground 19 COM Black Ground 20 -5V White -5 VDC (this is optional on newer ATX-2 supplies, it is for use with older AT class expansion cards and can be omitted on newer units) 21 +5V Red +5 VDC 22 +5V Red +5 VDC 23 +5V Red +5 VDC 24 COM Black Ground /PSON activated by pressing and releasing the power button while the power supply is in standby mode. Activating /PSON connects the power supply's /PSON input to ground, thereby switching the power supply to full-on condition.
Feb 26, 2015 | Compaq Computers & Internet
I want to convert this power supply for use with a battery charger for model aircraft. I need to know the color codes for the wires and also the pinout and which wire is the power on.
Pin Name Color Description
3 COM Black Ground
4 5V Red +5 VDC
5 COM Black Ground
6 5V Red +5 VDC
7 COM Black Ground
8 PWR_OK Gray Power Ok (is a status signal generated by the power supply to notify the computer that the DC operating voltages are within the ranges required for proper computer operation)
9 5VSB Purple +5 VDC Standby Voltage (max 10mA)
11 3.3V Orange +3.3 VDC
12 -12V Blue -12 VDC
13 COM Black Ground
14 /PS_ON Green Power Supply On (active low). Short this pin to GND to switch power supply ON, disconnect from GND to switch OFF.
15 COM Black Ground
16 COM Black Ground
17 COM Black Ground
18 -5V White -5 VDC
19 5V Red +5 VDC
20 5V Red +5 VDC
18 AWG is recommended for all wires except pin 11, which should be 22 AWG. For 300W configurations 16 AWG is recommended.
There are several ATX variants.
Hope this helps.
If this helps you resolve your problem, please
consider giving me a rating of 4.It will help me as well. Thank you.
Nov 26, 2010 | Compaq (243890-001) 250-Watt Power Supply
Ws-55511 DM 5volts draged down blinking led
Did you check the caps on the DM board? They usually go bad after a period of time. Remove the DM board and the metallic cover and there should be 4 to 7 capacitors (There are different revisions of the DM board). Check these caps also, replace if needed.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc
Apr 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Yes this is a good list of the voltages to be expected from a newer power supply on just the main header
Apr 01, 2009 | HP Compaq dc7100 PC Desktop
Dp-01fx tascam
Since the unit powers up and displays an error message it means that the power supply is working to some extent. The hard drive is probably malfunctioning and needs to be replaced. The DP-01 I have uses an 40 pin IDE 3.5" hard drive so finding a replacement should be easy unless it needs special formatting like TIVO drives.
As for the first solution - why do you think a PC hard drive needs -5v? The PC drive power connector has four pins - two grounds, 5v and 12v.
Mar 30, 2009 | Tascam DP01FX All-In-One Recording Package...
I HAVE A TASCAM DIGITAL MIXER TYPE DM-4800. I NEED IT TO CONTROL MY TASCAM HARD DISC RECORDER TYPE X-48. I NEED CABLE CONNECTION AND SETUP INFORMATION
http://www.manualnguide.com/download/manual-guide/tascam-dm-24-digital-mixer-automation-manual.html
setup information in manual above-i think cable will be found in a music equipment store near you.
Jul 18, 2008 | Tascam Audio Players & Recorders
About the DLP TV you helped with.
Brandon. Locate CN110 on the DMD its a wire plug. Pin 2 is gorund pin 4 is voltage for the color wheel. When the color wheel is off pin 4 should have 5V on it when power is pressed it should have 7v for the color wheel to start. If the voltages on pin 4 is 5V your DM is ok and Color wheel would be indicated as faulty, But if pin 4 is anything less than 5V its the DM which is faulty.
Jun 22, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Tascam DM-24 Digital Mixer Problem
I purchased a used Tascam DM-24 mixer about 2 years ago, and it 's been running great. Just about 2 months, it frequently shut itself off with a message:
" Power Supply voltage (+5V) is too low for stable operation. Please restart DM-24".
Of course, many attempts of restarting the board, but it won't turn back on after several hours later, and only lasts about half a day work only. Very frustrating. Any idea I could get help or fixed? million thanks for suggestions. Brian
Dec 31, 2007 | Tascam Quantegy 120 Minute Digital Audio...
Electronics - Others Logo
982 people viewed this question
Top Tascam Electronics - Others Experts
Glenn Mayer
Glenn Mayer
Ben Armstrong
Computer Links
Are you a Tascam Electronics - Other Expert? Answer questions, earn points and help others
