It is a whirlpool duet ht model# gwh9400plo. I did check the belt and it is on. It will not tumble(during wash) or spin. Everything else is working it will fill and drain. I ran diagnostic load and did not give any error codes. It did skip c:04 c:07 c:08 because they esquire tumbling or spining.It is a whirlpool duet ht model# gwh9400plo. I did check the belt and it is on. It will not tumble(during wash) or spin. Everything else is working it will fill and drain. I ran diagnostic load and did not give any error codes. It did skip c:04 c:07 c:08 because they esquire tumbling or spining.
Chances are the MCU is not faulty. Check the wiring from the motor to the MCUChances are the MCU is not faulty. Check the wiring from the motor to the MCU
Front load washers don't "agitate". Did you mean it doesn't tumble during the wash cycle? I need more information. Complete model # and a more detailed description of the issue.
It is a whirlpool duet ht model# gwh940plo. I did check the belt and it is on. It will not tumble( during wash cycle) or spin.I ran diagnostic load and no errors. It did skip c:04 c:07 c:08 because it requires spining or tumbling. Thanks for your helpIt is a whirlpool duet ht model# gwh940plo. I did check the belt and it is on. It will not tumble( during wash cycle) or spin.I ran diagnostic load and no errors. It did skip c:04 c:07 c:08 because it requires spining or tumbling. Thanks for your help
If you take the bottom kick plate off the machine you will find the tech sheet inside. This will tell you everything you need to know about you appliance.
First check your washer plug to see if the connections are tightly
screwed. Next check your filter if you haven't for long.
Remove
the 3 screws at the bottom of the front panel under the
washer door. Your filter door will be light brown. If you find a hose
there it is to drain out excess water (water that could not be drained
by your pump) After you hv drained unscrew the cap and
remove all the junk inside. Have a large plastic bag to catch junk and
water. Refit carefully after cleaning out. If not solved, something
shd be blocking your pump, check this out
Do you hear a "click" from the MCU at any point?
Check the motor winding resistance also
Im currently having the same problem .Was there a solution
