Question about Sony Playstation 3 (PS3) Console
Controlers will not connect to ps3
Four lights flash
    Problem Solver:
  • 17 Answers
Connect them by the cord if this doesnt work than try connecting them to another ps3 to find out if its the controllers or the ps3. i have only encountered one instance where the controller just died and wouldn't work. it is rare but possible. hope this helps.
Posted on Jun 14, 2009
PS3 Controller Keeps Flashing
Does the controller actually turn on and if not you have to connect it to the ps3 or whatever your connecting it to
Oct 16, 2013 | Sony PS3 DualShock3 Wireless Controller...
If i press the ps button on dualshock 3 controller all four lights on it are supposed to flash but it doesn't therefore the ps3 system cannot be turned on using it
Have you charged it? If you have plugged it in and no lights blink you may have a defective controller. If so check with Sony support/
Oct 05, 2012 | Sony Ps3 Sixaxis Wireless Dual Shock...
I have a type c wireless controller how to connect it to the ps3 it dont indacate
From the Manual:
1. With your Playstation 3 game Console on and the ON/OFF switch on the bottom of the controller set to on. Plug in the USB receiver into a USB port in the Playstation 3. The LED will flash slowly.
2. Press the "connect" button on the receiver. The LED will flash rapidly.
3. Press the "menu" button on the controller. The four channel lights will flash rapidly until the sync process is done. When the sync process is done one of the channel lights will remain solidly lit.
The manual can be found here in PDF format. http://assets.dreamgear.net/manuals/DGPS3-1324.pdf
Jan 07, 2011 | DreamGear TYPE 6 2.4 GHz Wireless...
Hi i need help on connecting my orb controller to my ps3 if u could tell me what to do that would be great
hit connect on the dongle.
Once you've done that, hit the 'PS' button on the controller and it should sync up.
Aug 06, 2010 | Video Game Consoles & Games
Controller not working
Either it's a new controller or it needs re-registered to your system. Turn your PS3 on and connect the controller to the PS3 via power cable. On the top of the controller if you're looking at it from the back, you'll see a tiny pinhole in front of the 4 lights. Hit your PS button to make the red lights flash, then with something tiny, like a toothpick, press in the button for a second. This will register your controller.
Good luck and if i've helped to resolve your problem please give me the applicable rating.
Respectfully,
Don
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
YT-9014A1 will not sync
i just sync both of mine to my ps3 it was giving me difficult at first, but i noticed the when u first put in ur usb wireless thing it starts to blink really fast and when u push the p3 button on the controller twice it flashes really fast. so i took out the wireless usb thing then put it back in so the light on it would be flashing really fast like it was searching for somthing, then press the p3 button twice to make the lights flash really fast aswell so it will sync with it. Thats how i got both of my controllers synced we my ps3. the lights on on the wireless usb thing and the controller lights must be flashing fast at the same time to sync.
Mar 06, 2010 | Sony Wireless Controller for PS3
I had the same problem, so I called customer service and had me do this:
1) with the USB cable plugged into the controller, power down the ps3 and turn the on/off switch in the back to "off".
2) hold your thumb down on the front button (where you normally can turn it on) while turning the switch on the back to "on" again. keep your thumb or finger on the front switch.
3) You will hear the normal "beep" that you usually hear when the PS3 boots up, but after a few seconds later, you will hear a secondary beep. Remove your thumb or finger after this second beep and the PS3 will reset itself after a few seconds. I have a projector connected to it, so I had to set the display screen back to HDMI afterwards, but when I disconnected the USB cable the controller worked wirelessly again. The customer service rep said that this allowed the controller to pair with the PS3 again. Note: You probably do not have to have the controller plugged into the USB cable at all while doing this. I just happened to have it plugged in. Hope this helps.
Mar 29, 2009 | Sony Wireless Controller for PS3
Controller still wont work
Hmm. I think i'll need a bit more info please.
When you reset your PS3 and the system's light goes red and you hit the PS button your controller the four lights just flash? Is that right? The only time your controller will "connect is when you plug it in with USB?
Try this. Turn your PS3 on. Press the reset button on the back of your controller and hold it for a few seconds, then press the PS button to see if it connects then. If it doesn't you could try removing the internal battery from the controller and putting it back in. That might clear up any settings that were saved in it.
Let me know how it goes.
Jun 24, 2008 | Sony Playstation 3 (PS3) Console
Cant use ps3 controller wirelessly
it sounds like it has been droped you will have to get it looked at it could be a lose battery conneion or lose wire
Jan 03, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
115 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
