Question about Audiovox Vehicle Parts & Accessories
Radio navigation code acura 3.5rl 1997 and how to enter it
  • 93 Answers
You usually Use the 1-5 or 1-6 programable keys on your stereo you push each one until you get it on the number for the number thats in the place of the code.
Posted on Jun 14, 2009
How to reset the transponder honda pilot?
I presume you want to initialize or"sync" up your navigation
system to the satellite. You will need the 4 digit navigation
code and the 5 digit audio code. Make sure your vehicle is
parked out in the open where there are no trees over it. Turn it
on and the nav screen should be asking for 4 digit code.That
is the navigation code.If entered correctly the display should change to the disclaimer screen. For the radio to work turn
that on and you should see in the space where the station
frequency appears,the words ENTER CODE.When the 5 digit
radio code is entered correctly the radio should start working.
I hope this helps as it is as short as I can make it. If you don't
have those codes then you will have to get them from a Honda
dealer. Good luck
Jul 18, 2014 | 2005 Honda Pilot
2004 tl acura radio reset code - if number on glove box higher than preset numbers what do I do
The numbers on the radio screen after pressing 1 & 6 are the serial number to retrieve the radio code!
The 4 digit number on the glovebox is probably the radio code, keep pressing preset number 1 until the first number is on the screen, then press preset number 2 until the second number is on the screen, then press preset number 3 until the third number is on the screen, then press preset number 4 until the fourth number is on the screen!
Feb 18, 2018 | 2004 Acura TL
I have a 97 acura 2.2cl how do i put codes in radio
If you have the proper codes the owner's manual will explain the sequence for entering them. If no owner's manual or if you don't have the codes you will need to take it to a dealership where they can look up the codes and enter them for a fee. The only other alternative is to go the the vehicle or radio brand manufacturers website and search for a usable code.
Apr 01, 2011 | 1997 Acura CL
I just got a new battery for my 2006 Acura TL. I ...
If you have jumped or replaced the battery at anytime this will happen. You have to get the serial number off the radio by removing it or partially taking it out to see the numbers on it try not to remove any cords. With the stereo out (to make sure you get the right number off of it) call an Acura dealership with the number and they will give you the another number to enter into the stereo and directions on how to punch the numbers in. Make sure while you have the stereo out you write the serial number down and keep it in a safe place also the number that the Acura dealership gives you because if you sell the car or if it happens again its easily accessible. Good Luck!
May 19, 2010 | 2006 Acura TSX
Unlocking Radio Code
Turn your key to accessory until you see code on the unit. You simply push the radio station selection buttons, there should be 6 buttons. After you push the last button it should automatically come back on.
Jun 17, 2009 | 1997 Acura TL Series
Radio code needed for radio in '97 acura 2.5 tl
you need to get serial # ON RADIO and then call dealer they can look up code with correct serial #
May 02, 2009 | 1997 Acura TL Series
Can get the radio to come on don't know the code and I'm getting an error message
This happened to me. You have to call Acura and fax them a copy of your driver's license & the vehicle registration. You then call them back in 24 hours and they will release the code for your radio. It's a bit of a hassle, but at least you'll know the code!
Apr 13, 2009 | 1997 Acura CL
I need the code radio for acura integra ls 1997
.If you do not have radio code you can most of the time find the code card tucked away in the owners manual pouch.(looks like a bussiness card)If you are unable to find card you would have to pull radio from dash and retrive stereo serial number,which is on bottom side of radio.once you have s/n you can take s/n to any acura dealership(has to be a dealer)and they can get radio code for that stereo through Honda Corp.once you have correct radio code you will need to first unplug radio,or disconnect battery to reset radio memory,then type in radio code.again if entered incorrectly 3x ,radio would need to be reset again too clear error codes.good luck!
Mar 26, 2009 | 2001 Acura Integra
Radio error on Acura
you need to take the neg (-) battery cable off to reset the radio. you can only enter the radio code 3 times incorrectly than it will lock up. i think you can pull the back up fuse from the under hood fuse box for 10 seconds and that will also reset it.
Dec 02, 2008 | 1997 Acura CL
2005 Acura TL Radio/Nav code
Your navigation code and radio codes writed on stikers on glovebox. Just open your glovebox and look on left side of gloivebox, not inside but outside. Open glovebox and look on left side. On my 2005 Acura RL NAV and Radio codes is different but it both on glove box. Sometime you even need to remove your glovebox cover to see those codes.
Jul 17, 2008 | 2005 Acura TL
Vehicle Parts & Accessories Logo
173 people viewed this question
Top Audiovox Vehicle Parts & Accessories Experts
Jim Goldsmith
Jim Goldsmith
xxxxxx xxx
Are you an Audiovox Vehicle Part and Accessory Expert? Answer questions, earn points and help others
