Question about Whirlpool Duet GHW9150P Front Load Washer
Is there a filter for duet sport front washer- 8300SW00?
  • 5,911 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Are you having a FILL problem, or a DRAIN problem?
If you are having problems with the washer FILLING, there are sediment screens in the water inlet valve. They are located in the connections on the back of the washer where the fill hoses attach. Some hoses also have screens in the ends that need to be checked periodically too. If you live in an area that has hard water, or if you use well water, it is common for these screens to become clogged with debris from time to time. Cleaning with distilled vinegar and cotton swabs can help dissolve rust, sediment and remove any debris. Simply turn off the water supply and remove the hoses form the back of the washer to check.
If you are having problems with the washer DRAINING, there is a clean out trap on the drain pump. You will need to remove the lower panel under to door to access. The drain pump is located directly under the wash tub in the front of the washer. Before you remove the cap on the pump reservoir you will need to place some towels down to catch residual water that will drain from the drain lines (this is normal). If you own a wet/dry shop vac, you can minimize this mess by taking the drain hose form the standpipe at the wall and pulling a vacuum on the line to drain all the water. There's about a gallon of water that remains in the lower tub and drain lines. A shop vac can help prevent you from having to mop up a mess of water. Unscrew the drain cap and pull the trap out and clean. With the trap removed, look inside the pump and make sure you also check the pump impeller. It is common from small items to get lodged in the impeller and restrict water flow.
If this is not what you are talking about, please post back and elaborate a little more so I can understand your problem. If you have any further questions, please let me know. I hope this helps you.
Posted on Jun 14, 2009
How to remove filter on Whirlpool duet sport front loading washer
Whirlpool Duet Washer is a front-loading washing machine.
  1. Remove the lower kick plate. Unscrew the two screws holding the kick plate in place, and gently pull off to remove. ...
  2. Place a small bucket under the white hose. ...
  3. Look inside the white hose. ...
  4. Look inside the hose cap. ...
  5. Twist the cap back onto the white hose.
How to remove filter on Whirlpool duet Google Search
Jan 02, 2018 | Whirlpool Washing Machines
What is code message F02?
Repairing the F02 error code can usually be done without ordering parts. Tools needed to repair your whirlpool Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out.
With the filter out clean and install it back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back, it may require you to clean the drain pump filter again.
If you require a new drain pump motor, you can purchase the part from the link below.
- See more at: http://www.appliancerepairlesson.com/2011/03/12/how-to-fix-whirlpool-duet-error-code-f02-duet-sport-error-f02-fix/#sthash.PuGd0iuQ.dpuf
Sep 09, 2014 | Whirlpool Duet Sport HT WFW8400TW 3.7 Cu....
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
What is error code f 21 on a whirlpool duet sport wfw8300 3.8 cubic washer?
This means that the drain pump is clogged. Tip the machine back and remove the three screws on the bottom panel. The pump has a filter inside. Pull the filter out and clean it, it will fix the issue for sure!
Apr 13, 2011 | Whirlpool Duet 3.8 cu. ft. Front Load...
F21 clogged line on a new Duet Sport less than a year old???
Hi, regarding the F21 Error on the Front End Whirlpool Duet, I was able to resolve the problem with the instructions from here, just want to stress cleaning out the filter by removing the front panel. Very easy and the error code is now gone. (screws are underneath front panel at bottom, remove stacker drawer for easy access, remove screws, pull panel off, remove the filter cap, turn to the left and pull out-that's where you will locate the clog.
Oct 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
How do you clean out the filter on a whirlpool duet sport washer?
Prop up the lower front edge of the washer or cushion the rear top edge with cloth and lean the washer against the wall for easy access to the three screws securing the lower front access panel to the cabinet. Remove the screws and pull down the lower front access panel to remove it from the cabinet.
Place a shallow pan or lay a towel under the filter to catch the water from the pump. Unscrew the filter from the pump assembly and drain the water. Clean the filter and screw it back into the pump assembly. Slide the lower front access panel up back into the cabinet and secure it with the three mounting screws.
Feb 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front loader is making funny noises. It was
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leak from my washer underneath i have a Whirlpool Duet Sport® HT 3.7 I.E.C. cu
Check the filter, as it may be leaking. To do so, take white panel off the front, put a bucket in front of the unit, unseat the rubber feet holding in the white plug and pull the white plug out, unscrew it, allowing water to run into the bucket, clean filter, check the gasket, as it may need replacement (if so, replace it), then screw white plug back in, push plug back into unit, secure the rubber feet, and replace the front panel.
Apr 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport HT front load washer keeps having F21 Error
remove the lower access panel (3 screws along the bottom of unit) behind htere you will see the pump and an access to clean the pump filter, probably filled with assorted debris. be aware when you unscrew there will be water behind it,
Nov 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
95 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
