Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
My lawn mower starts uo then shuts right back off
  • 24 Answers
The three most common causes (IMHO) of your problem are: 1.) Carb (dirty or gunked up) 2.) Gas (old, maybe has water in it, or wrong octane/type. ie., no e-85 in mower) 3.) Spark plug (worn may need replacement, or gap checked) Lawn mowers are simple internal combustion engines. Like any other, all they need is spark, air/fuel, and compression to run. Think about those three things as you trouble-shoot. I hope this helps.
Posted on Jun 14, 2009
Why after using my Kubota b2601 tractor I shut it off and when I went to start it all I get is one click
Hi Wilbur, The links below are YouTube videos that might get you out of trouble... Also there's videos down the right side of the links that may help as well....... I hope they help......... CHEERS....
How to test a lawn mower Key switch....
How to test lawn mower key switch
How to test a solenoid....
How to test lawn mower solenoid
How small engine governors work....
How Small Engine Governors Work any governor setup
How to test lawn mower electrical safety switches....
Shows all safety switches disabled....
Disable all lawnmower safety switches
Apr 28, 2016 | Kubota Garden
The lawn mower blades lock up and will not start
Did you pull the safety handle back all the way. or has it slipped so it doesn't work right.That is what the little safety handle is made to do not only to shut the engine off but stop the blades.
Has the engine seized up? Just ideas.
Is there junk that is holding the blades from turning.
Mar 14, 2015 | Garden
How can I override the auto shut down for a cub cadet?
There is a switch under the seat that has to make contact for the mower to start. I would not advise bypassing it though. A little WD-40 on the switch while working it uo and down will usually clean up the corrosion and get the switch working. If not then replace the switch. It should only cost five or six dollars.
Apr 18, 2014 | Cub Cadet Garden
Cub Cadet LT1042 PTO keeps shutting off after mowing several feet, will turn right back on but keeps shutting off
I have a Cub Cadet 1605 and it does the same exact thing. Try the PTO switch on the dash. I replaced mine and it works fine. Hope this helps.
Oct 12, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Steiner lawn mower
Might be Coil Breaking down under heat. Not sure best way to diagnose other the cross your fingers and buy a new coil. Sounds like you did everything you could do Fuel -wise.
Oct 02, 2012 | kawasaki Garden
Keeps shutting off. Do riding Lawn Mowers have alternators?
sort of they have a stator under flywheel that charges battery. if your carb has an electric solinoid on it it need voltage to stay open but that is supplied by battery. solinoid works by key switch.switch could be bad ,solinoid could be bad ,could have fuel feed problem or spark problem need more info how long does run? does it start right back up?ect hope this helps
Jul 17, 2010 | Ariens 48" Riding Lawn Mower Blade ...
Lawn mower idling up and down until it shuts off.
clean or replace your air cleaner that will fix it,I hope this helps you?
Oct 10, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
514 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
