Question about Samsung DLP HL-P5663W 56" TV
Is there a set of steps needed to do after replacing a bulb
I replaced the bulb in my 56 in samsung and now i can't get it to come back on the lamp light and temp light just flash. Is there something I am missing?
    New Friend:
  • 58 Answers
Make sure the lamp door is completely closed and the lamp is all the way in
Posted on Jun 15, 2009
Have a dlp samsung HLT6176S no picture already replaced the bulb still no picture what gives
Remove the lamp and look at the color wheel that faces it.
If wheel is shattered or missing pieces set will know it is not moving or moving too slow and shut set and lamp off.
Not all color wheels when fail make a sound
May 06, 2012 | Samsung DLP HL-P5663W 56" TV
My hlt4675sx/xaa won't power up. The Stand by/ temp light and the lamp light flash. The bulb id brand new.
First thing to do is look from back of set or area when lamp is: do you see the lamp come on for even a few seconds?
Also is the problem the exact same as before lamp Replaced?
Before set failed did you hear unusual fan like, high pitched whine or even grinding sound?
Depending on how you answer I will assist you.
SD TECH
Aug 22, 2010 | Samsung DLP HL-P5663W 56" TV
I have a samsung 56" pedestal DLP HLP5685, and it keeps turning off and on, on it's own. The bulb is only a few months old. Any suggestions?
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is BP9600677A you can find it here: http://www.discount-merchant.com/Samsung-BP96-00677A-OEM-Replacement-LAMP-BULB-p/samsung-bp96-00677a-lamp-oem.htm?Click=48173.Have a blessed one!
Apr 26, 2010 | Samsung HLP5685W 56" Rear Projection...
My screen is black but sound is good
You need a new lamp for your tv.
A new lamp is around $100 and your tv will be like new again!
here is a link:
http://www.discount-merchant.com/Samsung-HLM437W1X-OEM-Replacement-LAMP-BULB-p/samsung-hlp5663w-lamp-sm.htm
once you get a replacement lamp, have someone with a knowledge of electronics replace it for you. It is not complex, there may even be info about lamp replacement in the manual, so take a stab at it!
Also, never touch the lamp with bare hands, oil from your hands can shorten the lamp life or make it burst.
thanks for asking!
Mar 03, 2010 | Samsung DLP HL-P5663W 56" TV
Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
Jan 12, 2010 | Samsung DLP HL-P5663W 56" TV
I jest replaced the bulb of my Samsung Projection TV about a week ago and today it blew again. What is wrong? I am thinking of using it for target practice.
easy. take out lamp. put it in freezer for 5 minutes. reinstall. when unit comes on, go in menu to lamp setting. reset lamp setting to zero hours. the tv still thinks it has old lamp. easy
Nov 13, 2009 | Samsung DLP HL-P5663W 56" TV
My 56 inch Samsung DLP keeps shutting off. I have
Once before I had this same problem and FixYa gave me the solution. When you replace the lamp door, there is a switch inside so be sure the door is put in at an angle so to hold the switch up. It solved my problem after numerous repairmen missed it.
Sep 02, 2009 | Samsung DLP HL-P5663W 56" TV
Bulk Life
Identifying the correct lamp code
Before placing an order online, you must identify which lamp code you need. The lamp code is located usually on the left side of the TV
http://fixyourdlp.com/blog/?cat=4
Jan 16, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5663W 56" TV Logo
154 people viewed this question
Jerry Greenberg
Jerry Greenberg
