Question about Engel MT60F-U1 Commercial Refrigerator
I have a 60L engel fridge freezer, it has power, but won't work. The fridge had been on and was working fine, but it was dirty insede, so I dragged it outside and tipped the fridge on its side to wash it out, then dragged it back inside and plugged it in. The green light is on but the fridge is not running. Can you help me please. The model is MT60F-G4C
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 211 Answers
Really really bad to tip a fridge on its side. You may have blown the compressor. I suggest a new one
Posted on Sep 23, 2017
  • 358 Answers
SOURCE: engel mt60f compr running not getting cold
If the compresor is running and the fan motor by the compresor too, I think there's not freon(gas) in the system beacause a leak,thst could hard to find it,could be in the copper pipes joints ,in the evaporator or in the condenser,to find it you need to presurase the system with freon and look for the leak with a leak detector(electronic,ultraviolet or bubles).Also it could be that the compresor isn't pumping in that case you need to replace it.
Posted on Apr 10, 2009
sodeep
  • 3267 Answers
SOURCE: My engel MT60F motor turns on for 1-2 seconds and
Looks either your thermostat is malfunctioning. If thermostat is OK then the problem might lie in loss of refrigerant gas, freon or CF4. Get these 2 items checked in the above sequence..sodeep
Posted on Jun 27, 2009
SOURCE: 12 volt power lead of
On your fridge freezer at the back there is a box that the fridge freezer 240 lead will go to lift up the box by following the instructions imprinted on the box. Then look at the melted lead and see if it has melted to the bare gold part. if it ant you are ok if it has then you have to take note of where all of the leads go Brown, blue, green/yellow then pull them out being careful to not to full out any over leads Ex. Now for the hard part find some one with a old fridge/freezer and ask them is you can take the lead of the back but make sure if your fridge freezer had an earth wire that there fridge/freezer has and has the same type of connection to plug it back into the part you pulled your lead out of. P.S the earth wire is the Green and yellow one. Then put them in your fridge and make sure the connections are not touching. Because that is probably why the over lead melted. Also get free stuff at: www.fastandfree.jimdo.com
Posted on Sep 28, 2010
  • 135 Answers
SOURCE: I am an electrical contractor
http://www.engel-usa.com/pdf/MR040F-U1%20UL%20Owner's%20Guide.pdf
Posted on Jan 13, 2011
SOURCE: Power supply for Engel
from your battery or power socket in the wall of a house
Posted on May 02, 2011
Why freezer not working on indesit fridge freezer
is your fridge working or is the compressor running.
May 27, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
I have a Whirlpool wbm46mw Fridge, the freezer is working ok but fridge not getting cold, any suggestions,Thanks
Empty fridge and if possible put steam down vent behind the cover in the freezer section. or hot water. it will com out in the fridge so be carefull. this unblocks the aif feed from the freezer to the fridge section. also make sure the fan is working.
Oct 04, 2013 | Engel Freezer 22 Qt. Fridge/Freezer
Can i replace the control panel on 60l engel?
yes you can replace the control panel
Feb 20, 2010 | Freezers
Zanussi fridge freezer not cooling
no, its probably weak capacitors which provide power to switch the relay. Take the control board out and ask a friendly TV repair tech to change the capacitors
Jan 22, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
12v &240v connections on an ENGEL COOLER
AUTOMATIC AC/DC CHANGEOVER: All Engel Fridge Freezers can be plugged into both AC and DC at the same time. The Engel is smart enough to use the AC while available and then automatically switch to DC when the AC is no longer working. It will also sense the resumption of AC power and automatically switch back to AC making it ideal for high hurricane areas and places where power disruption is common.
Read more: http://www.roadtrucker.com/engel/engel-12-volt-fridge-freezer-technical.html#ixzz2MvRL2xrC
Mar 29, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Engel MT60F-U1 Commercial Refrigerator Logo
122 people viewed this question
Top Engel Refrigerators Experts
Jaime Hernandez
christian nielsen
cwradio73
Are you an Engel Refrigerator Expert? Answer questions, earn points and help others
