Question about Pride Mobility Victory 3 Wheel Electric Scooter
Scooter won't budge
Flywheel stuck, new batteries in and fuilly charged, getting excess heat on flywheel side
Please, help ASAP...URGENT, can't push scooter or drive it and I need this device...
  • Robin Hill
    Robin Hill May 11, 2010
    Sorry but I need more information, what are you calling the flywheel ? have you taken the motor apart ?
  • Pride Master
  • 1,271 Answers
it not a flywheel, it's sounds like the brake either seized on or the controller is activating it ,
Now you will need to remove the brake mech on the side of the electric motor , and now you should be able to drive the scooter.
Please let me know how you get on.
Regards
GeWiz.
Posted on Dec 28, 2009
Why won't my toro zx starter disengage flywheel
Hi Randy, from the top of your mower engine you should be able to see the "flywheel" (large circular cover, next to oil fill). Disclaimer - Before attempting anything by hand, ensure mower is off, blade disengaged, mower in park, key removed, battery disconnected, starter disengaged or not stuck in flywheel, etc... Now, if you can see/access the flywheel from the top, remove the spark plug and try to turn by hand, this is the same thing your starter is trying to turn, it should turn "fairly easy" by hand with spark plug removed. If you can't access the flywheel you'll have to try turning the main pulley from the crank shaft below/under your motor.
I don't want to overstate the obvious, but make sure your Battery is "fully charged" when trying to start by key.
If you can't budge the flywheel by hand with spark plug removed, the motor is likely seized. To what extent is unknown, I have often been able to remedy "seasonal seizing" by placing a pipe wrench on the lower shaft and gently applying pressure to "free" it. Doesn't work all the time, but has worked.
If you can turn the flywheel, time to look at the starter (see Bill Walsh Solution above). Let me know if this helped.
May 25, 2014 | Toro Garden
1965 mustang starter fires but won't engage flywheel. it is a brand new starter
Doesn't matter. The forks inside the starter may be missing or broke off or bad spring in starter that pushes the gear out. Try new started. Starter may have to be shimmed to make contact with flywheel. Starter may be kicking out but not engaging flywheel.
Jan 17, 2013 | 1965 Ford Mustang
Yzf r1 2006 flywheel won't come out
Hi, Rustanic for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Stator Rotor Removal
DIY 2006 Yamaha YZF R1 Stator Flywheel Replacement
Yamaha YZF R1 1998 Service Manual
OEM parts for Yamaha
Yamaha YZF R1M Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Dec 30, 2012 | 2000 Yamaha YZF-R1
Clutch judder & vibrates, toyota corolla.
The problem is the clutch and the engine flywheel are heat damaged, this is called clutch "chatter" You must have the entire clutch replaced and the flywheel machined smooth again. The damage is caused by excessive slipping of the clutch on take off. Release the clutch asap when you start off, do not slip it for long periods this turns it nearly read hot.
Oct 11, 2012 | 2004 Toyota Corolla 1.4
How do I remove a flywheel from an echo pb-413t? I bought a flywheel puller but it still won't budge?
It was pretty hard to get a flywheel puller on there wasnt it?
Use a brass hammer and a large flathead screwdriver. being carefull not to pry on anything but the crankcase and flywheel insert the screwdriver under the flywheel. With the hammer tap on the short cooling fins (These are tougher than the longer ones- you dont want to break off any fins) while prying up on the flywheel with the screwdriver. A few taps and it should pop loose. It doesnt require a lot of force but you need to be decisive with your blows.
Oct 04, 2012 | Echo Pb - 413t Backpack Blower
2007 grand prix won't start but lights and horn work
Your battery is to low on power it needs a good charge, or replace it is the best option for a brand new one!
Feb 27, 2012 | 2007 Pontiac Grand Prix
My audi doesnt start
Hello and welcome to FixYa!
As a first course of action please charge the battery fully. If the battery is weak, the starter can't kick the flywheel. It takes an amount of force to kick the flywheel that's why the battery must be strong.
If battery is fully charged and vehicle still won't start, the problem can be on the starter itself or on the ignition switch. I strongly suggest that you have it looked at by an expert auto electrician just to be sure on what to replace.
Hope this helps and thank you for using FixYa! Have a good one!
May 02, 2011 | 1996 Audi A4
Engine not charging battery engine dies when battery is removed
When you remove the battery it will break the circuit and die and if your battery dosen't have at least 5v in it it won't charge and you will have to replace it.
Apr 10, 2011 | Kohler CH25 PA-CH730-0040 Command Gasoline...
My battery is not properly charging..i'm getting
Ck the regulator and make sure battery connections a clean on both ends of both cables. Good luck
May 28, 2010 | 2005 Qianjiang QJ150-C
Pride Mobility Victory 3 Wheel Electric Scooter Logo
212 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
