Question about General Electric Microwave Oven
GE Microwave Model HVM1540 Renter says can't get anything to work Has unplugged for a minute Can't set clock it is as if the keypad is inoperative I'm the owner getting this via telephone from the renter
  • aev_1975 Jun 14, 2009
    Renter says after it was unplugged - he was unable to reset clock or anything - light is on
    GE Microwave HVM 1540
    Unplugged - one minute - replugged - can't set clock or anything
  • 952 Answers
Sounds like a touch pad circuit board problem. There is no easy way to solve the problem. If your microwave still has warranty better phone GE right away. If its out of warranty, bring it to a local appliance repair shop. sorry mate.
Posted on Jun 14, 2009
  • 378 Answers
Make sure the 3-prong plug on the
into wall outlet. oven is fully inserted into wall outlet.
Door not securely closed. • Open the door and close securely.
Press TIME COOK.
2 Enter cooking time.
3 Change power level
if you don’t want full
power. (Press POWER
LEVEL. Select a
desired power level
1–10.)
4 Press START.
Or maybe the button stuck, tell them to push all the button while its unplug.
GE microwave display f3 I set clock every thing works for a time then it starts by it self
"F3" means you have a shorting membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open, and of course one should never leave a microwave unattended while cooking.
For some models, you can order the keypad separately and replace it.
We can do that for you, but if you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
For some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors may have a lock.
positivelock.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Dec 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE JVM1540 microwave keypad does not work. There is power to the unit, the display reads "press start" but the keypad does not work
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
If it still fails, you would probably have a bad door switch or mount or a bad "start" pad on your membrane keypad.
See these files first:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Once you look those over, if you still need help, please reply back with the full model number from the tag in or on your unit.
Dec 16, 2010 | Microwave Ovens
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The touch pad on the microwave lights up, but will not respond when any of the keys are touched.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still will not accept key input, your membrane keypad has failed.
Depending on your specific model number, the membrane keypad may be available separately, or you may have to order the control panel frame, which comes with a new keypad.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Let me know if I can help further.
Aug 20, 2010 | GE Profile Spacemaker Over-the-Range...
The display says Reset but none of the buttons will work.
If it still won't work, you probably have a bad keypad.
Aug 19, 2010 | GE JE1540 Microwave Oven
The 'turntable on' feature does not work it reverts to 'turntable off' each times it is set. Please advise
If the display is changing by itself despite your pressing the turntable pad, i would say the turntable pad is failing on the keypad.
Then if it still fails, you may have a failing keypad.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't heat
you will need the magnetron replaced $150-$180 price range part and labor
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave displaying --F3--
F3 on a GE / Hotpoint microwave means you have a shorting keypad / controls.
There's a chance it can come on by itself and run unattended, which can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open.
On this model, the keypad is not available as a separate part, so you would have to replace the entire controller assembly.
Then you disconnect the wires and install the new controller.
You can order part number WB07X10903 here for $114.37 (compare that to $174.75 direct from GE!).
Jun 24, 2009 | GE Microwave Ovens
Seems like microwave is locked on clock
You have to set a time (any time) to use.
Press CLOCK, press number 2 then 2 then 2 again and then press CLOCK again. Does it say 2:22?
Everything should now work.
Do not run Empty, do not use any metal in there and do not use alot (MW kills all the vitamins and nutrition in food - like eating MUD for your body) .... and don't forget to reset the CLOCK ;-)
Mar 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Keys on the GE microwave are not working
If that doesn't work, leave it unplugged for maybe an hour.
If that doesn't fix it, you have a failing keypad.
That part is not available separately, so you would have to order the control panel assembly, which includes the plastic frame with the keypad already mounted on it.
While GE charges $175.25 for this, you can get it for only $109.26 here.
moz-screenshot.jpgWe're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 28, 2008 | Microwave Ovens
General Electric Microwave Oven Logo
188 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
