2001 Buick Century Logo
b
brad Posted on Mar 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2001 buick century runs fine when in park and nutral i can put it in drive and sometime i can go 10k sometimes only get 1k the it starts spudering and wont rev up but will idle fine put it in nutral and will rev fine but when put in gear idles but wont rev turn car off and then works good for a bit then dose it again stumped on what it could be
  • 3 more comments
  • brad
    brad Mar 16, 2014
    the only code that comes up is for the TCC PWM could that be whats causing it?
  • brad
    brad Mar 16, 2014
    also for got to mention when its doin this the speedometer rapidly gose up and down
  •  Russ Hill
    Russ Hill Mar 17, 2014
    if speedo is going up and down that is down to the abs sensor it used for both speed and braking on the abs.
  •  Russ Hill
    Torque Converter Clutch Circuit Malfunction. TCC PWM Solenoid Circuit Electrical. this is also used by the abs system speed to ratio for the traction control.
  • brad
    brad Mar 17, 2014
    so is it the tcc solenoid that would make it do this or the abs sensor
Russ Hill
Level 3:
  • Buick Master 4,057 Answers
  • Posted on Mar 16, 2014
 Russ Hill
Buick Master
Level 3:
Answers
4057
Questions
10
Helped
1175844
Points
12696
I think you have an engine speed sensor fault. its not reading the engine speed or the motion speed. needs these two to change speed and ( gear). one is connected to the abs unit and the other is on the engine. usually if they both go its down to the gear box ecu. you can check if you have it on a ecu reader. will have fault codes or not be read at all.
  • 2 more comments
  •  Russ Hill
    it would be a fault some were with the abs not reading a sensor properly. jumping speedo it getting then losing the signal as the sensor reads a cog and the cog has like teeth on it if they get blocked grease muck etc the senor will not read properly. so would say the main problem is the sensor not reading. have you been driving in mud or something like that been to the beach. even drove through a flood..... or even had some work done with that wheel.
  •  Russ Hill
    could even be brake dust build up.
  • brad
    brad Mar 18, 2014
    the plug is riped off driver side front hub now that you mention it i think thats what it is because it was acting like the tracktion control was ingaging just never thought of it the plug has been broke for over a year and its just started acting up ill fix that and hopefully that the problem . thanks for your help!!
  •  Russ Hill
    Russ Hill Mar 18, 2014
    the plug could off been working well connecting but now its not glade you need this sensor to work. controls a lot
5 Related Answers
Anonymous
  • 625 Answers
  • Posted on Jun 09, 2008
SOURCE: 1995 buick regal custom missing
you might have bad plug wires replace wires and saprk plugs
Anonymous
  • 335 Answers
  • Posted on Aug 18, 2008
SOURCE: transmission ?
The TCC solonoid is bad I have changed hundred of these there is a square coector of the front side of the transmission, this is the connector for the TCC ( torque converter Clutch) it has a tab lock put your finger nale under the tab or a smal screwdriver and lift gently and pull the connector off the car will now drive when you put it in gear but NOT have 4th gear and theck engine light may come on you should get this fixed as soon as possible you have to take off the side transmission cover the TCC is in there only buy one directly from the GM dealer no one else trust me on this, and also change te transmissin filter and gasket while your there.
if this information is good plese give me a fixya!
Thanks and if you need more help contact me but here look at my website go to the BLOG and FAQ you will see the TCC jobs I hve done and the outcome
www.aceautomotive1.com
Anonymous
  • 10 Answers
  • Posted on Feb 13, 2009
SOURCE: buick 94 century custome reving and irratic stumbling etc.
I've had this problem. It's most likely a large fail in one, or series of small problems in all, of these:
IAC (Idle Air Control) Valve - Will cause erratic idle
ERG (Exhaust Gas Return) Valve - Will cause irregular acceleration
*TPS (Throttle Position Sensor) - Most likely the culprit. It was my major problem. It'll cause exactly what you described.
And if you did not know this, your car is equipped with an OBD (On Board Diagnostic) system. Next time the service light comes on, whether the car is running or not, push [OFF] and [TEMP UP] on your climate control and hold for about 3 seconds. All the dash lights will come on and any error codes will be displayed where your odometer is.
Other controls are:
[FAN UP] -OK
[FAN DOWN] - Next
[OFF] - Rescan
[BI LEV] - Quit
Anonymous
  • 2004 Answers
  • Posted on Mar 21, 2009
SOURCE: Sometimes car doesn't start up with a immediate fast idle.
Bad transmission, plugs, fuel pumps. That is all I think will definately give u such results.
Rate please.
Anonymous
  • 61 Answers
  • Posted on Jul 25, 2009
SOURCE: My 1999 Century gives me difficulty staying started after fueling
Sounds like a fuel pressure issue. When you release the pressure in the fuel tank, the pump may have difficulty re-pressurising the system. Another possibility is the the one-way check valve in the fuel pump is faulty, and fuel drains back to the tank while you are fueling. There also exists the possibility that the tank is being overfilled, and the fuel return line is being blocked, causing an OVERpressure situation in your fuel rail, which might explain why the engine runs when you hold the accelerator pedal down. How about your fuel filter; when was it last replaced? Is the check engine light on? Take it into a qualified garage and have the codes read. Maybe the mechanic will be able to point you in the right direction.
Hope this helps!
I have a 2005 Buick Century and the key is in the ignition it is not stuck but the ignition switch will not turn in the car will not come out of park was working fine yesterday
you have shift interlock on this vehicle? My first thought was to set parking brake, then bypass the shift interlock, shift into neutral, then see if it will start and drive? Your owners manual should have info on the shift interlock.
Sometimes a steering wheel lock mechanism, puts a bind on the key cylinder. Pulling the steering wheel, one way or the other may take the bind off the lock cylinder and let it turn?
There could be other issues?
97 park ave ultra is hesitatating when I start using the gas as I start an incline mostly but sometimes just randomly an it's getting worse
Engine Stalling Due to Mass Air Flow/Crankshift Position ...
repairpal.com > Problems > Buick > Park Avenue
Buick Park Avenue Engine Stalling Due to Mass Air Flow/Crankshift Position Sensor Failure. This is a verified ... 1997 Buick Park Avenue- 3.8L V6160,000Visitor. Engine stalls ... car runs then stalls and won't start for thirty minutes. Upvote (36).
Buick stuttering Questions & Answers - Fixya
www.fixya.com > Forum > Tags > stuttering
94 Buick Park Avenue that stutters under a light load I have a 94 Buick Park Avenuethat ... Buick Century 97 runs rough and stutters when cold and gas applie Engine runs rough ... I have a 1994 buick lesabre it starts ok but stutters and stalls.
I have a 98 Buick Century. It will crank and run fine until I get out on the road and it changes gears, then it goes to missing. I park it and the next time I drive it, it runs just fine. Is it the
YOUR TCC Solenoid and one other Shift Solenoid in this Transmission HEAT UP and Fail,
Purchase all new Solenoids and a new Trans Filter
Drop the Pan and change all the Solenoids and refill the Trans and there goes your problem
Happend on my 98 Park Avenue and fixed the same exact problem. Mil also had a very hard shift when it got hot... Felt like it was a Motor Mount that went bad...
1996 Buick century station Wagon
I would have the ignition switch checked, and replaced if that is the problem.
Cold Start and TRanny issues.
A neutral park switch keeps you from activating the starter in drive or reverse. It also turns the reverse lights on. Its on top of the transmission at the end of the shift cable . If it does not turn over in park try it in neutral, Clean battery cables. Check fuel pressure. Is check engine light on?
1994 Buick Century Won't Start
no most likely have another problem u might have pushed another fuse out of socket check that then look for a power fuse check battery it may have drained whike the door was open or ing switch left on . u can clean battery post untill they shine and the battery cable ends toomake sure it is in park and for good measure turn key on foot on brake move into drive and back to park in case nutral safty switch was jammed
4helpful
98 Ford Explorer won't move in reverse
Sometimes it may just be the fluid level, if you have drive , drive it around the block a few times, then park it on level ground and hold the brake and go through all the gears slowley, two times. put it in park, open the hood and check the fluid level, the dip stick in the back by the fire wall, take it out and clean it, read the stick. SOME need to be checked in Nutral, if this is the case do so but be carefull that the truck has stopped moving when put in nutral!!! if it is low only put in the right fluid, and a little at a time, while it is still running DO NOT OVER FILL !!!!!!!! Also sometimes it is a SENSOR problem, and in most cases not to hard or costly to replace.
Top Buick Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
