Question about E-Machines -T1840-CELERON-1.8GHz,40GB Desktop Computer System (1000000127)
Power problem was browsing the net then pc hang. reboot it, cpu fan turns son, power supply turns on, front led lights, then power trips or pc turns off
    Habit-Forming:
  • 188 Answers
U r problem looks big man...........go to any computer mechnic ....only he can ix this problem........i can give u some clue----u r ram may be ded......
best regards
Posted on Oct 30, 2007
  • SHIVAJI YADAV
    SHIVAJI YADAV Nov 04, 2007
    if u r problem is solved now....pls vote for me
    best regards man
  • SHIVAJI YADAV
    SHIVAJI YADAV Nov 05, 2007
    hey dude.....u did not make any repley....for u r problem solution ...
    hope it is solved.......
    Was this solution helpful? Show your Appreciation by rating it:
    pls vote for me man..
    best regards & best of luck..
My HP G60-230us was shutt down during my son was playing game,no power at all(LED light under charger connector is on,Power light LED/Battery light/Hard disk light are off,Please help?
OverheatingWhen the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jul 10, 2012 | HP Computers & Internet
My dell xps 400 was shutting off and all i was getting was a solid amber light in front. I was able to hold it in for a bit and then press it and turn it back on for about 2 weeks now. It finally shut off...
You more likely had a temperature issue with the CPU.
Had the CPU fan started to sound like an airplane warming up?
If so, you may have finally burned out the CPU.
Yes it's possible that it was reporting a problem with the power supply, but the only way to know for sure is to replace it.
In the meantime, eliminate everything else.
Disconnect power from EVERYTHING except the motherboard.
If it powers up, then it's possible that either your motherboard is failing (and now works under the decreased load), or one of the things you unplugged has failed.
If the unit springs to life, turn it off, and start reconnecting things.
If it fails constantly whenever 1 specific thing is plugged in, that thing or the motherboard chip that controls it is the problem.
Mar 12, 2011 | Dell XPS 400 PC Desktop
The yellow power led light blinks on front of the emachine w2646. The CPU Fan works. The power button will not turn the PC on or off, you just have to plug in the power cord to turn it on. The monitor just...
Did you flash the main board ??
1.) remove battery
2.) press and hold the power button for 10 - 30 seconds
3.) replace battery.
4.) when the system boots it will say press XX (e.g F2) to load defaults and continue ,, press that key.
It could also be the power button is stuck!.
find were it connects to the main boad and unplug it
bridge the 2 pins it jacks into to turn the computer on. if it works u will need to replace that button or the case.
Feb 26, 2010 | E-Machines eMachines Desktop PC
Power PC G5 Dual 2.5 sudden shutdown and no reboot
In G5 always the cover should be closed properly if not it will start the fan very fast like a blower and the red leds will be on showing that the heat is over so please check that the cover is closed and locked from behind so itworks smooth and the power supply is standard or normal
u should always use genune parts with mac..
thanks
Dec 19, 2008 | Apple Power Mac G5 Desktop
DFI Infinity NF4 SLI won't start
Hi steve, PC repair is trial & error. I suggest you replace the power supply or test the power supply in another PC that also uses 4 SATA drives & two PCI-E slots for starters. Two boards with the same problem is odd. You must have the CPU & fan connected, memory installed, ATA 24_pin main power plugg connected (Page 17 in manual). 4-pin_12v power connected which is located (Just to the left of DDR1 memory slot). Looking at you're board the power supply should be no less than 500w.
CPU must have thermal grease between CPU & heat sink.
Even though you have fans running & LED's on & flashing, the power supply seems to be the first item to check. Make sure the bottom of the motherboard is not touching the PC case.
Try the above & post you're finding here.
Good Luck!
Mike
Jun 28, 2008 | DFI Computers & Internet
Power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Jan 24, 2008 | Computers & Internet
Pc is not starting up
I'm sorry to tell you but your cpu has probably fried. Your pc hanging a lot probably meant something was overheating and the fact that you say your cpu is not hot when you have the cooling fan off of it means it is probably the cpu. When you first turn your system on without a cpu cooling fan, the cpu should be slightly warm, although I do not recommended running a cpu at all without a cooling fan or even touching it when it has power.
Aug 18, 2007 | Intel Pentium 4 1.7G, 1.7 GHz...
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
New Computer Wont Boot!
when you say "the fan makes a noise like its getting ready to spin", which fan...power supply's or cpu? if you answer power supply, then the POWER OK signal is not returning to power supply and it then quickly shuts down to prevent further damage. double check a firm connection to mother board. If you answer CPU, then it becomes far more complicated. Try re-seating the memory chips.
Jun 05, 2007 | Systemax Venture PC Desktop
Computers & Internet Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
