My Sony HDR SR-12 had the same problem. The issue is most likely a broken flexible circuit board which runs from the display through the hinge to the main camera body. After seeing the repair costing from $250.00 to $400.00, I determined the camera wasn't worth fixing. Then I found i could buy the circuit board on Ebay for about $30.00. I ordered a circuit board, actually it came with a second board and instructions. It is a fairly tedious repair and took me about 1.5 hours. You need to be fairly mechanically inclined to attempt this repair. Basically you have to disassemble the camera and touch screen, replace the circuit board and reassemble. The cicuir board has to be folded and wrapped around the hinge correctly. I guess the reason they sell two cicuit boards together is to allow you to ruin one on your first try. The boards i ordered had good instructions on how to complete the repair and fold the cicuit boards. I got mine done on th efirst try, so I have another board for when it breaks again. Due to the time required, I can see whay the repair is expensive.
I have the same model and problems. Do you mind sharing the part # of the circuit board and the seller information. Thanks
