Question about Harman Kardon Harmon Kardon SoundStick II Speaker System Computer Speakers
Taking apart harman/kardon subwoofer
I need to take apart the subwoofer of my harman/kardon soundsticks. but i can't figure out how to do it. helppp?!
    New Friend:
Turn the sub upsidedown, carefully remove the clear rubber feet (these are a dome fitted over a mushroom top), using the toothed gripper cutout of a pair of pliers (when closed it is the eye shaped opening visible on one side), grip the mushroom firmly but not so hard as to crush the mushroom and gently ease clockwise and anticlockwise (the mushroom is at one end of a clear plug blocking access to the four screws that hold the two parts together.
Be carefull to use the correct size screwdriver so as not to damage the screw heads as they are tight.
On reassembly, you may need to use glue to replace the rubber feet if the mushroom becames damages during removal.
Posted on Dec 11, 2009
  • 1 more comment
  • JenCluse Dec 02, 2010
    OK. You can come and get your 'Pass-out with Honours" Top-Apprentice-of-the-Year badge
    (This written Dec 2010, after buying a U/S set of these things, and not having yet worked out to remove that plug. It certainly is a weak point, and your advice is absolutely spot on.
    There are a lot of tricks to working on these things. So far I am just on refurb of the #1 stick.
    Would there be any value my posting other snippets as I find them regarding the HKs? Is it possible to post .jpg's?
    Thanks again
    5 ticks
  • Rosie P Aug 19, 2013
    Thanks for this post. I have just successfully released a butterfly from my subwoofer! She's flown to freedom. Thank you. And it all went back together again without any problems.
  • Kevin McKenna
    Kevin McKenna Dec 07, 2018
    ANYONE KNOW WHERE TO GET. A REPLACEMENT FOR THE AUDIO IN CABLE FOR THE WIRED SOUNDSTICKS?
    New Friend:
The subwoofer seems to make the perfect residence for a Daddy Longlegs spider. Mine has been in there for weeks and seems to be loving how the LED light attracts small moths. I just took mine apart [using the advice above], gave it a good clean, but given easy it was to take apart, didn't have the heart to remove the spider out. I left him in there, reassembled the unit without any hassle at all and the by next morning, he was back in business. :-)
Posted on Feb 05, 2012
  • Gary Cook Jun 15, 2014
    A metal coathanger turned into a hook also comes in handy for inanmiate objects
    New Friend:
My baby is rattling...what would be a good idea to do..??I've had her for almost 2 years now...
Posted on Sep 27, 2018
SOURCE:
Harman Kardon Soundsticks II with subwoofer
Check you volume control center and the likes it may have turned off by itself
Dec 24, 2013 | Harmon Kardon Harman Kardon Soundsticks...
My MacBook's audio still on even when harman Kardon speakers are connected to the computer.(Original version with USC connectors).
As I seem to recall the very first version was powered by the computer and as such may not be compatible with your Mac. I may be thinking of Apple's Clear speakers though? Do your HK Soundsticks have a power adapter or AC cord?
Oct 15, 2013 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
I have a leaf in my subwoofer. I'm very reluctant to take it apart. Any ideas? Thanks
How on earth did a leaf get in there?
If it is not affecting the sound quality, I'd leave it especially if you are not keen on taking the woofer apart, I'm afraid thats what you will need to do though if you want it out
Jan 01, 2011 | Harman Kardon Harmon Kardon SoundStick II...
I have a Harman Kardon SoundSticks (the orgiginal
yes it can....try to search in the internet what converter you will need...
Nov 06, 2009 | Harman Kardon SoundSticks Computer...
How do I disassemble + clean Harmon Kardon SoundStick subwoofer?
Check for a Fuse. Mine is an older model and has a Fuse right next to the power cord. It probably has a slot for a flathead screwdriver.
Apr 24, 2009 | Harman Kardon Harmon Kardon SoundStick II...
Lost the power cable from subwoofer of my harmon Kardon
If you go to the Harmon/Kardon website, you can find where to buy replacement parts.
http://www.harmankardon.com/
Select product support on the front page, then go to parts.
Then select your product as Harmaron/Kardon SoundsticksII and select your country.
Hope this helps,
Nathan.
Mar 05, 2009 | Harman Kardon SoundSticks Computer...
Harman kardon soundsticks II
use a clear silicone based sealant (similar to the type used for caulking and in fish tanks) I'm guessing you used CA or superglue, and thats what melted your plastic, you're using too much also most likely.
Sep 11, 2007 | Harman Kardon SoundSticks II Computer...
Subwoofer - no sound
Had the same problem when mine first arrived. Unplug and replug the power cord at the back of the woofer. Worked for me!
May 16, 2007 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
Harman Kardon Harmon Kardon SoundStick II Speaker System Computer Speakers Logo
14,898 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Don Hart
Laser Plus Computers...
Level 1 Expert
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
