Question about Broan-NuTone Allure® I WS136BC Kitchen Hood
Broan allure fan and light
Why doesn't my  light and fan work when I turn them on?
  • 1 more comment
  • Anonymous Jan 19, 2008
    yes! fan doesnt work
  • belost Feb 16, 2008
    Preessed the light switch on,one bulb flashed brightly,now fan and other good bulb does not operate.LED indicators on panel lite when pressed.
  • Anonymous Feb 25, 2008
    Went to turn on the light and out of the blue no lights, tried the fan no fan. The indicator lights above the fan speed buttons work, but not the ones above the light buttons. No previous problems or indications of something going wrong.
    Scholar:
  • 146 Answers
Check that you have not accidentaly switched the wall socket off in the cupboard above the rangehood. The slide switch could also be faulty.
Posted on Nov 04, 2007
Fan turns on and off since turning hood light on a few days ago
If it is a Broan, there is a delay button that was also depressed. It will turn the fans off after a few minutes. If not, then you're shorted out either in the control panel or the wiring in the range hood.
Sep 23, 2009 | Broan-NuTone Allure II QS230SS Kitchen...
Lights won't turn off - everything else works fine
I have a NuTone Allure WS2 range hood. The fan works fine, so does the control board seem ok, but the lights work only intermittently. NuTone tech support said to replace the control board, which I suspect is its kneejerk response. The board costs almost $200--and for two lights???
My problem is similar to the one whose lights work, fan doesn't, but I have a feeling my problem is different.I hope simpler.
Thanks in advance for help (light) on the problem anyone can offer.
Larry R
Apr 23, 2009 | Broan-NuTone Allure III QS330SS Kitchen...
My broan allure turns on by itself
Isn't it suppose to turn on automatically? The broan has a heat sensor!
Jan 08, 2009 | Broan-NuTone Broan Range Hoods Allure II...
Nutone Allure fan has disco lights.
Its definetly the control board!!!
Part #R111632
Price $110.00
Definetly not cheap...
Dec 22, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Broan Allure QS2 Range Hood
Had same problem & fuse fixed it.
Before buying a new control board (approx $160), check the 3 amp fuse located on the inside of the vent on the control board. You have to take the light/bottom housing & black plastic air chute off to see control board/fuse.
Feb 21, 2008 | Broan-NuTone Allure II QS230SS Kitchen...
Broan Nutone Allure lll light problem
The problem is the little lever in the socket. Turn breaker of fan off, grab a flat head screw driver and lift the little lever slighty like a 45 deg angle. If not the replacement socket assembly is
part # R111630 comes in a pair. I do service calls for broan & Nutone
We have the part: www.inventex.com
Jean-Marc
Feb 11, 2008 | Broan-NuTone Allure III QS330SS Kitchen...
Broan Allure QS3
The Problem is the wiring. Take the 2 screws retaining the metal plaque off underneath the filters. You will see the wires leaving the motor going into a "molex" plastic connector which connects two another set of wires going to the control board. Check to see if the wiring colors match from side to side of plastic connector. Ive only seen it happen once but it was exactly that. I do service calls for broan & Nutone
Jean-Marc
Apr 29, 2007 | Broan-NuTone Allure III QS330SS Kitchen...
Broan Allure II
I called Broan technical support. They said that they had heard of this issue before, but that there was no recall. I suggested that it was a frequent enough problem for it to come up 3 times in 12 mo. on one website. She was underimpressed with this statistic and said that they sell millions of them. She would not disclose the name of their supplier so that I could get some information on the actual controller unit. She did not seemed as pained as I was by having to part with $130 for a new controller.
Jan 30, 2007 | Broan-NuTone Allure II QS230SS Kitchen...
Broan-NuTone Allure® I WS136BC Kitchen Hood Logo
681 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
