Question about Baby Jogger 2 Stroller
Remove rear wheels
How to remove rear wheel
Where the hell can I get a FREE PDF download for my Ford fusion 2 for the removal and replacement of the rear wheel bearings as well as the torque settings for the final nut after replacement.All the so...
Rear Suspension - Rear Wheel Bearing Fusion 2002.75 (06/2002-)
-Removal and Installation
Special Tool(s)
Installer, Differential Bearing
205-062
Installer, Input Shaft Seal
307-210 (17-041)
General Equipment
Soft faced hammerWooden block
Removal
CAUTION: The brake drum and hub assembly removal in this procedure is for installing a new wheel bearing, not for access to brake system components.
-All vehicles
Remove the dust cap.
Remove the wheel and tire.
For additional information, refer to: Wheel and Tire (204-04 Wheels and Tires, Removal and Installation).
-Vehicles with rear drum brakes
Release the parking brake.
Remove the brake drum and hub assembly.
Remove and discard the wheel hub retaining nut.
-Vehicles with rear disc brakes
Remove the brake disc.
For additional information, refer to in this section.
Remove the wheel hub.
-All vehicles
Remove and discard the wheel speed sensor ring (brake disc shown).
Remove the circlip (brake disc shown).
Using the special tool, remove and discard the wheel bearing (brake disc shown).
-Installation
-All vehicles
CAUTION: Support the wheel hub assembly on the wheel mounting face and not on the wheel nut studs.
Using the special tool, install the new wheel bearing (brake disc shown).
Install the circlip (brake disc shown).
CAUTIONS:
Make sure the wheel speed sensor ring is not knocked, damaged and kept free from metal fragments.
Protect the face of the wheel speed sensor ring with a non-ferrous flat block to prevent damage.
Make sure the wheel hub or brake drum is adequately supported and do not allow it to rest on the wheel studs..
Make sure the wheel speed sensor ring is pressed on slowly and squarely until fully seated.
Do not exceed a maximum load of 10 kN.
Using the special tool, install a new wheel speed sensor ring (brake disc shown).
CAUTIONS:
Avoid impact on the wheel speed sensor ring.
Make sure the wheel speed sensor ring is clean.
Avoid any contact between the wheel speed sensor ring and a magnetic surface.
Rotate the wheel hub assembly 10 times counter-clockwise when tightening the wheel hub retaining nut to prevent damage to the wheel bearing.
NOTE: Install a new wheel hub retaining nut.
Install the brake drum and hub assembly.
Apply the parking brake.
CAUTIONS:
Install the wheel hub retaining nut.
Install the brake disc.
-All vehicles
Install the wheel and tire.
NOTE: If the dust cap is damaged a new dust cap must be installed.
Using a soft faced hammer and a wooden block, install the dust cap.
There is no real torque settings for the rear wheels, except to say, do not over tighten or you will stretch the lugs and the will loosen over time.
May 28, 2011 | Ford Fusion Cars & Trucks
Procedure for replacing rear whl brgs on a 2003 escape awd
4-Wheel Drive
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Rear wheel
    • Rear brake shoes
    • Rear halfshaft nut and loosen the halfshaft from the hub
    • Wheel hub and place it in a vise
    • Inner wheel bearing race from the hub
    • Antilock Brake System (ABS) sensor bracket and move the sensor aside, if equipped
    • Parking brake cable from the steering knuckle
    • Brake line from the wheel cylinder and support the knuckle
    • Lower shock absorber nut
    • Lower ball joint by holding the ball joint stud
    • Upper ball joint
    • Coil spring while noting the location of the insulator
    • Steering knuckle cam
    • Steering knuckle
    • Snapring and press out the outer wheel bearing race from the knuckle
      Rear hub and bearing
      Click to Enlarge
To install:
  1. Install or connect the following:
    • New wheel bearing into the steering knuckle
    • Snapring to the knuckle
    • Wheel hub
    • Steering knuckle cam and hand tighten the bolt
    • Coil spring
    • Shock absorber lower nut. Torque the nut to 85 ft. lbs. (115 Nm) for 2002-04 models; 129 ft. lbs. (175 Nm).
    • Upper ball joint. Torque the nut to 76 ft. lbs. (103 Nm).
    • Lower ball joint. Torque the nut to 76 ft. lbs. (103 Nm). Align the steering knuckle cam and torque the bolt to 85 ft. lbs. (115 Nm).
    • Brake line to the wheel cylinder. Torque the brake line bracket bolt to 15 ft. lbs. (20 Nm) and the brake line fastener to 11 ft. lbs. (15 Nm).
    • Parking brake cable to the backing plate. Torque the bolt to 16 ft. lbs. (22 Nm).
    • ABS sensor bracket. Torque the bolt to 80 inch lbs. (9 Nm), if equipped
    • Halfshaft nut. Torque the nut to 214 ft. lbs. (290 Nm).
    • Brake shoes
    • Rear wheel
  2. Fill and bleed the brake system.
  3. Check and adjust the wheel alignment as needed.
2-Wheel Drive
    • Rear wheel
    • Rear brake drum
    • Wheel hub nut
    • Wheel hub
    • Snapring
    • Wheel bearing outer race from the knuckle
      Rear hub removal
      Inner wheel bearing removal-rear hub/bearing
      Rear wheel bearing removal-2wd
      Rear wheel bearing removal-4wd
To install:
  • Wheel bearing in to the knuckle
  • Snapring
  • Wheel hub into the wheel bearing
  • Wheel hub nut. Torque the nut to 214 ft. lbs. (290 Nm).
  • Brake drum
  • Rear wheel
    Rear wheel bearing installation
    hope this helps if so send testimonial comment or even any other questions you have
Jan 16, 2011 | Ford Escape Cars & Trucks
Removal of rear wheel on Suzuki VL800 to repair puncture
In order to remove the rear wheel assembly, you are going to need a motorcycle lifting jack stand or similar device.
1. Stand the bike on the side stand
On the left side of the rear wheel:
2. Remove the 2 froward facing bolts.
3. Remove the allen head bolt with the wide head.
On the right side of the rear wheel:
4. Remove the brake adjuster nut on the end of the actuating lever.
5. Remove the Toque link nut at the bottom of the wheel assembly.
6. Remove the axle nut (castle nut and cotter pin).
7. Place the motorcycle jack under the swing arm or chassis tubes to stabilize the rear end.
8. Remove the axle.
9. Remove the axle from the splined drive gear and place the wheel assembly on the ground.
10. Pull the wheel assembly rearward.
Reverse the process to replace the wheel.
Jan 03, 2011 | Suzuki VL 800 Volusia Motorcycles
Removal of rear wheel to repair puncture
8. Remove the axle.
Jan 03, 2011 | 2001 Suzuki VL 800 Volusia
What is the proper procedure to remove the rear wheel from the 2002 Intruder 800 without damage to the driveline?
2. Remove the two forward facing bolts.
7. Place the motorcycle jack under the swing arm or chassis tubes to stabilize the rear end. Lift the motorcycle until the rear tire is just off the ground.
8. Remove the axle.
9. Remove the wheel from the splined drive gear and place the wheel assembly on the ground.
Sep 03, 2010 | Suzuki VS 800 Intruder Motorcycles
Rear wheel removal
8. Remove the axle.
Aug 10, 2010 | 2003 Suzuki VL 800 Volusia
How to removal the shaft from the rear end to
In order to remove the rear wheel, it is not necessary to remove the drive shaft. The first step is to get your rear wheel off the ground. The easiest way to do this is to put your bike on its center stand. However, not all bikes have center stands. If your bike does not have a center stand, you may want to buy a motorcycle lift (available from Pep-boys, or Harbor Freight). Once the rear wheel is off the ground, you can disconnect the brake linkage, and then remove the rear axle.
At this point there is nothing holding your rear wheel to the bike except for some meshing gears. Now you must lift and maneuver the rear wheel back and forth a little and eventually the final drive will work free. You will be able to slide the wheel toward the right side of the bike and then lower it to the ground.
In theory removing the rear wheel is that simple. In practice, the gears in the final drive can sometimes hold on quite tightly. This is particularly true if the rear wheel has not been removed for a long time or if your final drive is very worn. Usually being patient and persistent will pay off and you will be able to remove the rear wheel.
Sometimes it may prove easier to remove the entire wheel / final drive / drive shaft assembly first, and then separate them. In this case, the order of operations is different. Once you have the rear wheel off the ground, you can disconnect the rear brake linkage just as before. Next you can remove the four bolts that hold the drive shaft housing to the back of your crank case. Finally you can remove the rear axle and slide the wheel backwards the unmesh the drive shaft.
Regardless of which way you remove the rear wheel, it will be easier to put it back together by first attaching the drive shaft and final drive to the crank case, and then reinstall the wheel as described in the first method above.
Good Luck,
-Josh
Mar 27, 2010 | 1985 Yamaha XJ 700 X Maxim
How to replace rear wheel bearings
don't have topaz. maybe escort will help guide you.
Section 04-02: Suspension and Wheel Hubs, Rear 1996 Escort, Tracer Workshop Manual
REMOVAL AND INSTALLATION Wheel Bearing and Hub Assembly NOTE: Wheel bearings are not serviceable and should therefore be replaced as an assembly with the wheel hub (1104).
Removal
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
  1. Remove the hub grease cap (1131) from the wheel hub.
  1. If equipped with disc brakes, remove the rear disc brake caliper (2552) and rear disc brake rotor (2C026). Refer to Section 06-04 for the removal procedure.
  1. If equipped with drum brakes, remove the two brake drum screws and the brake drum (1126).
  1. Unstake the rear axle wheel hub retainer (4B477) securing the wheel hub to the rear wheel spindle (4A013). Remove and discard the rear axle wheel hub retainer.
  2. Remove the wheel hub from the rear wheel spindle.
Feb 06, 2010 | 1990 Mercury Topaz
How to install wheel bearing hub assemble (front)1998 on a ford escort
front or rear?
Assuming rear, on the brake drum:
Hub Removal
  1. If equipped, remove the brake drum (1126) ; refer to Section 206-02 . If equipped, remove the rear disc brake rotor (2C026) ; refer to Section 206-04 .
  1. Remove the wheel hub.
    1. Unstake the rear axle wheel hub retainer.
    1. Remove the rear axle wheel hub retainer and discard.
    1. Remove the wheel hub (1104).
Nov 05, 2009 | 1998 Ford Escort
How to change a rear wheel bearing on a 1994 toyota camry
The rear wheel bearing on a toyota camry is replaced by replacing the wheel bearing and hub as a unit. this is a design change as compare to older models with two piece wheel bearings. Scotch drive wheels. Remove rear wheel. Remove rear brake drum. (note: if emergency brakes are applied you will not be able to remove brake drum) Remove dust cap and hub retaining nut. Hub should slide off as unit. Replace hub with new unit. Installation is reverse of removal.
May 30, 2009 | 1994 Toyota Camry
Baby Jogger 2 Stroller Logo
70 people viewed this question
Top Baby Jogger Baby Gear Experts
Marvin
Marvin
john h
Roger Paull III
Are you a Baby Jogger Baby Gear Expert? Answer questions, earn points and help others
