Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Delayed Write Failure
My FreeAgent Pro drive has had problems from day 1.  When I try to copy a large file to/from it, I will usually receive an error from Windows stating "Delayed Write Failure".  Now I tried to do my homework before posting here, but am on the verge of throwing it out the window.
The information I found for this type of error and this type of drive indicates that there are issues with using the drive with a USB 1.0 port.  I decided that maybe it was possible that my home computer had the older type USB ports since I bought it used from a friend and it was a few years old.  So I decided to give it a try with a new Dell Latitude D620 that I know for a fact has USB 2.0 ports.  I still have the same issues with the drive on my laptop.
Is Seagate known for flaky products or what?  I had only heard of good things about them up till this point.  I can certainly say that I am not pleased with this purchase,
  • margo_b Nov 05, 2007
    Yes, I had delayed write failure from day one. I purchased the hard drive in Aug 2007. Unable to correct, even after following instruction from microsft web help. I am ready to dump this hard drive. Problem doe not occur with other hard or flash drive connections
  • VedderNation Nov 08, 2007
    This problem is not solved afterall. I thought it was working better, but that is not the case. Has anyone else found a solution for this dumpy hard drive?
Can you please say with fix in the KB article you actually used? I've got the same problem with my FreeAgent Pro. My system settings already match the recommended settings except for the registry change to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Memory Management. But I'm hesitant to modify that - not that I don't know how, but rather I'm a bit concerned about the statement: "Note The FFFFFFFF value is okay to use. However, a value that is more than the default value but less than the maximum value may provide better results."
Posted on Nov 26, 2007
Http:// Suggested by eagle338 fixed the problem
Posted on Nov 21, 2007
  • 4,889 Answers
Before you throw it i advice that you go through this link...Read it carefully..It is not a problem with your drive..If you find something thats hard to grasp let me know and i will be here to offer further support.
Posted on Oct 30, 2007
Hiii... I am having a 500 G.B. external hard disk. whenever i want to perform any operation on it such as "Copy to PC" or "Copy From PC"... it displays an error message after some time...
This is Microsoft's answer to this problem.
This error typically occurs when the "Enable write caching on the disk" feature for your hard disk is turned on.
However, if the "Enable write caching on the disk" feature is turned off, this error can occur because the Ultra Direct Memory Access (UDMA) hard disk controller may be configured in either of the following ways:
  • You are using a 40-wire connector cable to connect the UDMA drive to the controller instead of the required 80-wire, 40-pin cable.
  • The BIOS settings are configured to force faster UDMA modes.
For more information about the delayed write failure, go to the "Delayed Write Failure information" section.
Jan 21, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Getting delayed write failure error
Problem with connection - try changing USB cord and try different port. for better performance - connect to USB2.0 port
Nov 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have Seagate FreeAgent Desk 1 TB. I am getting this popup Windows Delayed Write Failed. Windows was unable to save all the data for the file. The has been lost.
Either the disk-drive is "full", or the disk-drive has become defective.
If the former, then delete some files.
If the latter, buy another external drive, and copy all the files from the "old" drive to the "new" drive, before the drive COMPLETELY "fails".
If the warranty for the Seagate still is active, then exercise the warranty to get a free replacement.
Sep 01, 2010 | Seagate Computers & Internet
I/o error in external hard
make sure all the connections USB, sata and electrical are secure and working properly
Jul 20, 2010 | Seagate FreeAgent Pro 1TB External USB...
Error msg
try to format the drive
Feb 25, 2010 | Western Digital Computers & Internet
My Seagate FreeAgent Desk 1 TB worked for several days but is now telling me it has an error:1013 on every file it backed up. The icon is showing red. What does this error:1013 mean??
There is about a 40% failure rate on these drives which is extremely high. The problem is a error in the onboard bios. If it is still working you can apply a update that will fix it. If it has "bricked" or locked up then you are out of luck. You can try to return it under warrenty. If you have important data on the drive then you may need the services of a data recovery company to get it off ie $$$ to do.
Dec 30, 2009 | Seagate FreeAgent Pro 1TB External USB...
I have a 500 gig Seagate Free Agent external hard drive that I am having problems with. The problem is that the amber light on the hard drive comes on solid (bright) at initial start up, but then goes dim...
windows - delayed write failed
Windows was unable to save all the data for the file I:\$mft.
The data has been lost. This errors may be caused by failure of
your computer hardware or network connection. Plese try to save elseware.
Aug 03, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
WD External Hard Drive 320GB Cyclic Error
Windows Delayed write file error
Read this
since your talking about the External drives, a lot of reasons makes this happen. if the resolution above link cant help you, then try this:
Make sure that update the driver of your PC hard drive. Usually, this errors appear if your moving from one hard drive brand to another ex: seagate to samsung etc....
updated hard drive driver resolve this.
Make sure the cables are alright. Or at least have the latest service pack. USB drivers causes issues as well. I updated mine and the problem did not crop up anymore. hope this would help.
Feb 22, 2009 | Western Digital Elements powered by WD 320...
Seagate FreeAgent 320 GB usb 2.0
sounds like maybe it's packed?
Mar 08, 2008 | Computers & Internet
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
461 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
