Question about Denon AVR-987 Receiver
Durabrand 2.0 CH USB Powered Speaker System
I plugged in everything that needed to be plugged in... BUT why does the background music sound louder than the artist singing???????
  • 1 more comment
  • 23keke Dec 09, 2008
    everything is hooked up right but i have no sound, the speakers are not working
  • keanna_baby_ Jan 21, 2009
    well i plugged up all the things i need to and well sound dont come out of it. agin its a 2.0 ch usb powered speaker system
  • seuldebout Jan 25, 2009
    I just bought this speakers and the computer is not detecting any new hardware..
The speaker will not let any sound come out except static, a noise saying they are are on. What is wrong?
Posted on Jan 28, 2008
  • 979 Answers
Balance needs to be set up; ie, the individual channels need to be adjusted to properly hear your tunes.....accordianman
Posted on Oct 31, 2007
  • Michael Borelli Oct 31, 2007
    Need to know your OS, and what media player you use....accordianman
Durabrand 2.0 CH USB Speaker System
Try this, go to control panel and double click Sounds and Audio Devices. Then click advanced, under speaker settings and make sure your settings are desktop speakers. Also, in control panel, click Sound Effect Manager and do a speaker test. This should help.
Jan 20, 2009 | Audio Players & Recorders
2.0 CH USB Powered speaker System
yes.. in those types of speaker systems the usb is for just power.. and the "banana plug" is the audio jack.. there should be some kind of audio outpu on your computer .. it is usually located in the back near the middle or bottom.
Jan 09, 2009 | Durabrand DUR7 Portable DVD Player
No audio device detected
Ok when you plugged in the USB sound did it "see" it... did it ask for "Drivers" Because this device MUST have drivers.. also ya may have to disable any onboard sound device ya may have via the BIOS setup menu. Generally these USB sound devices are real easy to install and use.. try it on another PC to be sure it is OK.. GL
Jun 05, 2008 | Durabrand 5.1 Surround Sound Computer...
Emerson dvd player - background sound lauder than dialogue
Greetings surfjax,
If you will allow me to make an assumption, you do not have a 5.1 surround system connected to your DVD player. This is a common experience with users of a standard TV or stereo receiver if a movie is being presented in 5.1.
In a surround sound system the center channel speaker provides almost all the vocal tracks while the side channels will provide music and some background noises. You'll still be able to hear the voices in your side speakers, but it will be muted and over powered by music or sound effects.
Some DVD players allow you to "Downmix" the surround signal to stereo. You might want to look around your sound setup on the DVD player or check your owners manual.
Hope this helps.
Jon
Go Ahead. Use Us.
May 22, 2008 | Emerson EWD7003 DVD Player
Can't get my durabrand uc-280 computer spreakers to work
Returned the durabrand uc-280 to Walmart! Plugged the existing speaker into the correct hole in my new sound card. Problem solved!
Feb 16, 2008 | Audio Players & Recorders
Speaker won't work
Sija
First things First:
1) check your connectors back on the PC, I presume you use windows XP and sound drivers installed **
2) plug the speakers cable on back or front of your PC in the green (usually) connector.
3) see if sound is NOT mute on mixer , multimedia in control panel.**
4) If you can Enter your BIOS, try to enable sound, for onboard sound, if apply**
good Luck
Jan 20, 2008 | Audio Players & Recorders
There is no sound
Have you recently used headphones in this device? I have a portable DVD player that had a similar problem. It thought that headphones were plugged in and that turned the sound in the external speakers off. If i plugged in headphones the sound worked in them. So I jiggled the headphone plug in while in the jack and removed it and the sound came back on.
Dec 10, 2007 | Durabrand DUR7 Portable DVD Player
Problem with speakers
if you have done a system recovery, then disconnect it, reconnect and reinstall everything of speaker. drivers, reconfigure it, will be as new again.
Dec 09, 2007 | Audio Players & Recorders
Hi, Based on your post/description, the Durabrand 2.0 CH USB Speaker System is a basic external speaker that plugs into your PC's speaker/headset output (green jack). It is supposed to get its power from the +5VDC supplied by the USB port. Some USB port have current limiting therefore it can be anywhere from 10 - 500 mA. The power requirement of your external Durabrand speaker maybe beyond what the PC's USB ports can supply. It does not need to be recognized by the OS since it only connects to the USB to get power but there is no data interaction. Perhaps what you can do is get an external +5VDC power supply whose output is in USB type connector. The current rating would depend on the requirement of your speaker. Offhand, if the speakers are not that big, probably a 1 Amp would do. This is of course assuming that the Durabrand speaker system is fully functional. If with an external power supply it is still a no go and you have verified that sound do come out of your green jack (with the use of an ordinary headset), then the Durabrand is defective. Hope this be of help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 22, 2007 | Denon AVR-987 Receiver
Denon AVR-987 Receiver Logo
335 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
