Makita DCS6401 20 20",64cc Chainsaw 2 Cycle Logo
A
Anonymous Posted on Mar 15, 2014
1995 corvette lt1 spark plug gap - Makita DCS6401 20 20",64cc Chainsaw 2 Cycle
2answers
Why does my 1994 c4 lt1 corvette stall
Have ODBII codes read and post here.
1helpful
2answers
My 1992 Chevy corvette lt1 is not starting is getting fuel to the jet by the intake what do i do?
This vehicle should be fuel injected and therefore have no jets. If you are referring to a schrader valve on the fuel rail having fuel then maybe I can offer some help.You need to pull a spark plug wire off and see if there is any spark from the wire if you are sure there is fuel supply.Check for spark and let me know
What arm the specs for 95 camaro lt1 350
Block and Basics
Displacement: 350 cubic inches, 5733 cubic centimeters, 5.7 liters
Block Material: Cast Iron
Main Bearings: 2-Bolt Centers and Ends (The Corvette LT1/LT4 had 4-bolt mains)
Stroke: 3.48"
Bore: 4.00"
Compression Ratio: 10.4:1
Combustion Chambers: 54 cubic centimeters
Factory Redline Rating: 5700 Rotations Per Minute
Bottom End
Piston Material: (10159437) Eutectic Aluminum/Silicon Alloy
Connecting Rod Material: (10108688) Powdered Metal
Crankshaft Material: (12556307) Cast Iron
Top End and Valvetrain
Cylinder Heads: (10168448) Cast Aluminum, 2 valves per cylinder/16 valves total, ~212 CFM flow (Impala SS and Caprice heads were made of cast iron*)
Valve Diameter: (intake- 10241743, exhaust- 12550909) 1.94 intake, 1.50 exhaust
Valve Overlap: 41*
Valvesprings: (10206040) 85 lbs, seated
Camshaft Specs (12551705): 205/207 duration @ 50*, .447/.459" lift, 117 Lobe Seperation Angle
Rocker Arms: (10089648) 1.5:1 Stamped Steel
Timing Chain: (10128485) Powdered metal link
Intake and Fuel Delivery
Fuel Delivery: Electronic Fuel Injection, sequential port
Injector Size: (17124248) 3.0gps, 22lbs/hr speed density (1992-1993), 24lbs/hr mass airflow (1994-1997)
Throttle Body: 48 millimeter twin butterfly
Intake Manifold: (12552137) Aluminum
Factory Power Ratings
92-96 LT1 Corvette: 300bhp, 330lb-ft
1996 LT4 Corvette: 330bhp, 340lb-ft
1992 LT5 Corvette: 375bhp, 370lb-ft
93-95 LT5 Corvette: 405bhp, 385lb-ft
93-95 LT1 F-Body: 275bhp, 325lb-ft
96-97 LT1 F-Body: 285bhp, 325lb-ft
96-97 WS6/SS: 305bhp, 335lb-ft
93-97 Firehawks: 315bhp, 340lb-ft
Factory LTX Camshaft Specifications**:
1992 Y-body: 205/207 0.451/0.450 lift 117 LSA
1993-1995 Y-body, F-body: 202/207 0.450/0.460 lift 116 LSA
1994-1996 B-bodies (including L99 4.3L): 191/196 0.418/0.430 lift 111 LSA
1996 Y-body, 1996-1997 F-body: 200/207 0.447/0.459 lift 117 LSA
1996 Y-body, F-body LT4: 203/210 0.476/0.479 lift 115 LSA
hope this helps
Spark plug gap settings chart
You should be using platinum or iridium plugs with the LT1, and you don't gap those, they are set at the factory. If for some reason you want to use copper, it's .050", but they are going to wear out faster so you aren't saving any money by using them. Also, it's not a very easy job, so you wouldn't want to have to do it two or three times when you could have done it once.
1995 corvette LT1 has very poor performance and
Start by checking the Timing of the valves.
2answers
No spark 1995 corvette
What have you checked so far ?
Power to the coil - cap and rotor - ignition module ?
Acceleration problem
Check to see if your water pump is leaking coolant from the weep hole. If it is, it may be causing to Opti Spark distributor to cut out.
Looking for a wiring schematic/diagram for a 1995 Corvette LT1 automatic.
Look for a factory service manual on eBay. I found one used for about $85.
Top Makita Garden Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Makita Garden Expert? Answer questions, earn points and help others
