Where can i find serial number. new the boot that attaches to head of trolling motor
SOURCE: Wring for trolling motor
just hook the two batteries up in series. To do this buy one short cable and use it to hook the positive of one of the batteries to the negative pole of the other. Then use the two remaining poles, one positive and one negative to hook up to the motor. good luck
SOURCE: my 12/24 volt trolling motor only runs on 12 volts
Did you connect 2 batteries to try the 24 volt version? You have to link them together like a flashlight, positive to neg and then out the other side, for 24 volts, like a golf car.
SOURCE: The switch keeps burning out and the motor turns
i think its time to strip this motor out,, it sounds like its has a short in the field coil winding,,as its pulling far to many amps,,,,
SOURCE: 24 volt trolling motor (motorguide) not working.
Loose /corroded connection at the batteries will do this. Likewise loose connections between batteries and plug.
SOURCE: I have a Motor Guide
How does the prop rotate? Is it hard to turn? Have you checked behind the prop for fishing line? Are you getting 24 volts to the motor?
