Home | Ryobi | Multi-Volt Battery Charger | I lent my battery and...
Ryobi Multi-Volt Battery Charger
Problem for Ryobi Multi-Volt Battery Charger
I lent my battery and flashlight to a friend
By bcrosby348 on Jun 14, 2009
I lent my Ryobi 18 V batteries and flashlight to a friend during a power failure. When they were returned, both batteries would not take a charge and the green yellow lights show on the charger. Are the batteries toast, and is the problem that they were charged before they had a total discharge?
Comments:
Jun 29, 2009
- Thank you for the answer, jdyoder32. They are the older type, black with yellow posts. They appeared dry.
However, the problem seems over. I bought a new set, and, with the instructions supplied, found that in some cases the Green/Yellow lights on only indicated that they were fully discharged. They recommended that the batteries be kept in the charger to test this out.
I did, and after about 20 minutes, the red light came on, and in about 1 hour, the green light – full charge.
I now have 4 batteries, which should last me! Sure wish I knew that before ($60 for the replacement set) – wasn’t in the original instructions that came with the charger.
FYI – you may be able to use this tip for the next guy.
Again, appreciate your help.
Clarification Request
Posted by jdyoder32 on Jun 27, 2009
Are these the older style batteries (black with yellow posts or the newer lithium ion type? In either case, if they got wet and we recharged before they were totally dry they could be permanetly damaged.
Popular Solutions for Ryobi Multi-Volt Battery
Questions and Unsolved Problems for Ryobi Multi-Volt Battery
Do you recommend Ryobi Multi-Volt Battery Charger?
Answer
Answer
both green and yellow light stay on and batteries will not charge 18v
Answer
The Yellow and Green light both come on and stay on when I put in a battery to charge !!! This is a... (More)
Answer
Yellow & Green Lights stay on. battery is fully discharged.
Answer
One of the front power jacks will not work. The motor side works great. The orthe side the gear on... (More)
Answer
Both green and yellow lights come on and stay on.
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ryobi Multi-Volt Battery...:
Top Drills / Driver Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Drills / Driver Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
