Im unable to find the ohms resistance values at 32 degrees Fahrenheit for the bin t.mister
Degree Format
The oven has been preset to the Fahrenheit temperature scale.
With this feature, users can switch to the Celsius temperature
scale.
To change degree format to Celsius:
1. Press "SETTINGS." Settings menu will appear in display.
2. Press the up or down arrows until "DEGREES:
FAHRENHEIT" appears in the display.
3. Press "ENTER" to change degree format. Current value
will flash.
4. Use arrow keys to select "CELSIUS."
5. Press "ENTER" again to set degree format.
6. To exit the Settings menu, press "SETTINGS."
You will need to press the up or down button after pressing settings until you see Celsius appear then press ENTER and the Celsius flashes then use the arrow key to select Fahrenheit (still flashing) and once again press enter (saves) and it stops flashing. then press settings to exit the settings menu.
Thanks for choosing FixYa,
Kelly
