Sure, I can help you with that. Here are the instructions to assemble the pergola sun shelter from Uberhaus:
Step 1: Prepare the area.
- Clear the area where you will be assembling the pergola.
- Make sure the ground is level.
- If you are assembling the pergola on grass, you may want to put down a tarp or other protective covering.
Step 2: Assemble the frame.
- Follow the instructions in the diagram to assemble the frame.
- Make sure all of the bolts are tightened securely.
Step 3: Attach the canopy.
- The canopy is made up of two pieces.
- Attach the first piece to the frame, following the instructions in the diagram.
- Attach the second piece to the frame, overlapping the first piece by a few inches.
Step 4: Secure the pergola.
- If you are assembling the pergola on grass, you may want to drive stakes into the ground to secure the pergola.
- If you are assembling the pergola on concrete, you may want to use concrete anchors to secure the pergola.
Here are some additional tips:
- Use a level to make sure the frame is level before you attach the canopy.
- Use a torque wrench to tighten the bolts to the correct torque.
- If you are assembling the pergola on grass, make sure the stakes are long enough to reach the hard ground.
- If you are assembling the pergola on concrete, make sure the concrete anchors are the correct size for the holes in the frame.
I hope these instructions help!
