Question about Kenwood DDX-6019 Car DVD Player
THE BATTERY DIED ON MY VEHICLE AND NOW MY SUBS WONT WORK BUT THE AMP TURNS ON
  • 39 Answers
Check the head unit settings.
They have probably been reset.
If it has a subwoofer setting make sure it is on.
Failing that, disconnect the subs completely from the amp and put a "test" speaker on the terminals to see if the amp has output.
Posted on Jun 14, 2009
SOURCE:
When my sub hits hard the amp dies
You probably have a voltage sag. When amp needs more power than the battery can give it, it will not stay within the acceptable limits (voltagewise) for the amp. You are probably gonna need to get a capacitor
Mar 13, 2012 | Alpine Car Audio & Video
Wont start when key in ing. and turning on than cutting off if battery dead
factory alarm, when manually unlocking the door the lights flash & horn usually go off & the car will start & shut off within a second or 2. Have 2 96 jeeps that do it the panic button on the keyless entry is the only way to shut it off. If the battery has died & a new one is installed it trips the panic mode as well. If the battery is dead but vehicle starts with a jump but shuts off soon after jumper cables are removed, the alternator is bad & cant keep the computer powered up & will shut down the vehicle. A little more specific with symptoms will make diagnosing much easier.
Sep 23, 2010 | 1997 Chrysler Sebring
I have a Pioneer 5400t amp hooked up to a 10" 400w sub of unknown brand. The system was working perfectly for about a week, then I noticed the sub wasnt working. I blew both 30a fuses on the amp. I...
Your best bet is to buy a cap. A capacitor is an external battery booster like device. It boost power to amp. The thicker the wire the better. Power and ground. Shorter thicker ground wire the better. Make sure it is not on a painted surface. Scrape down to metal surface!!!!
Nov 12, 2009 | Cars & Trucks
Csa300.1 bazooka 500 watts
sounds like you may have blown your sub...sheck the spyder inside of it and see if it is stiff..if the speaker doesnt seem too responsive when you press on it, its probably blown...
Aug 01, 2009 | Bazooka ELA300.1 Car Audio Amplifier
SUBS WONT TRUN ON
Hello fresttadefjm,
There are no subwoofer settings on the Pioneer DEH-2800MP.
You need to check the external power amplifier and the connections from the Pioneer and from the sub(s). If everything is plugged in and wired correctly, check the amp fuses, both on-board and the main power fuse (located in the amp positive lead usually near the vehicle battery).
Hope this helps.
Jul 21, 2009 | Pioneer DEH-2800MP CD Player
Subwoofers won't work and they are brand new
I've got a pair of these MTX's subs powered from a Fusion 450 watt 2-channel amp. For the price, they are great. By the way, they are 4-ohm.
My first suspicion would be that something in the first incorrect wiring damaged either the amp or the subs. Can you explain specifically what the "installing the subs incorrectly" means? Was the amp output shorted out at any time or was it operated without a load? Either of these conditions will fry an amp and sometimes, the protection circuitry doesn't work either.
First make sure that your amp is still working. Check both the primary power fuse, usually located near the vehicle battery, and the fuses on both sides of the amp. Make sure that when you turn the system on, the power light comes on steady (blinking is protection mode). Test your subs one at a time on a speaker output.
Mar 29, 2009 | MTX Thunder 4500 T4510-04 Car Subwoofer
Battery died, Now subwoofer and Amp dont work
on some sterio head units when they lose power u have go into the menw setup and turn the sub controls and adj. back on. this may help if u have not did it all ready /
Mar 15, 2009 | Car Audio & Video
THUNDER 5601 WHEN VEHICLE TURNED ON, SUBS BOOM, THEN WORKS OK. ALSO WHEN RADIO TURNED OFF
If the amp produces no boom with no signal input cables connected, I'd suggest using an LOC.
Let me know if you have any other questions.
Sep 30, 2008 | MTX Thunder 3401 Car Audio Amplifier
My amp
Check your speakers with an ohm meter. They should have some resistance but not totally shorted. Its prob the amp that got fried. Connect the amp to the battery with no speakers attached to it if the protection light still comes on then the amp is blown.
If the amp is blown you can send it to people on ebay and get it fixed pretty cheap. Good luck!
Aug 18, 2008 | JBL GTO75.4 Car Audio Amplifier
One amp dies.. then revives
I'm no expert, but the two most obious problems that come to mind would be the power supply or amp over heating.  Test your battery and alternator..
Oct 28, 2007 | Kenwood KAC-X650D Car Audio Amplifier
Kenwood DDX-6019 Car DVD Player Logo
103 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
