One of the most common things is that your interior lights are staying on, check and clean the door switches and make sure they are springing back into position easily with your finger. Also check your rear door latch for the same. Another thing is, if you have lighted vanity mirrors in your visors, those switches can become gummed up as well. One last thing to check is your interior light switches, ie. dome lights, overhead lights etc.
2000 Chevrolet Tahoe 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2000 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium.
2001 Chevrolet Tahoe 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2001 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium.
2002 Chevrolet Tahoe 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium.
2002 Chevrolet Tahoe 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2002 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium.
2003 Chevrolet Tahoe 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium.
2003 Chevrolet Tahoe 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2003 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium.
2004 Chevrolet Tahoe 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium.
2004 Chevrolet Tahoe 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2004 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium.
2005 Chevrolet Tahoe LS 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium.
2005 Chevrolet Tahoe LS 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2005 Chevrolet Tahoe LS 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium.
2005 Chevrolet Tahoe LT 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium.
2005 Chevrolet Tahoe LT 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2005 Chevrolet Tahoe Z71 5.3L 323CID V8 FLEX FI Z - GAP=0.040"; Original equipment is iridium.
2005 Chevrolet Tahoe Z71 5.3L 323CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe 5.3L 5328CC 325CID V8 FLEX FI Z L59 - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe 5.3L 325CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe LS 5.3L 5328CC 325CID V8 FLEX FI Z L59 - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe LS 5.3L 325CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe LS 4.8L 294CID V8 GAS FI V - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe LT 5.3L 5328CC 325CID V8 FLEX FI Z L59 - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe LT 5.3L 325CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe Z71 5.3L 5328CC 325CID V8 FLEX FI Z L59 - GAP=0.040"; Original equipment is iridium.
2006 Chevrolet Tahoe Z71 5.3L 325CID V8 GAS FI T - GAP=0.040"; Original equipment is iridium.
2007 Chevrolet Tahoe LS 4.8L 294CID V8 GAS FI C - GAP=0.040"; Original equipment is iridium.
2007 Chevrolet Tahoe LS 5.3L 5328CC 325CID V8 GAS FI J LY5 - GAP=0.040"; Original equipment is iridium.
2007 Chevrolet Tahoe LT 5.3L 5328CC 325CID V8 GAS FI J LY5 - GAP=0.040"; Original equipment is iridium.
2007 Chevrolet Tahoe LTZ 5.3L 5328CC 325CID V8 GAS FI J LY5 - GAP=0.040"; Original equipment is iridium
the dome lights may be good and have power but do they have a good ground if no this is an easy fix. just run a new ground wire or if you can find the broken wire repair the wire. as for the floor and courtsey lights check and make sure the dimmer switch on the head light switch is not turned up all the way if they are not then unplug the door triggers (the little buttons your door hits to turn the inside lights on and off
Turn your key to the on position(do not start), then push the throttle pedal to the floor three times, turn of the ignition, wait a second or twothen start the engine, this should reset it. Works on the 2000 Tahoe LT 4WD
