Question about RCA F27442 27" TV
No Sound I had Direct TV satellite receiver but i switched to antenna and now i have no sound.when hook the satellite receiver back up i get sound.i checked the menu to make sure sound is on,sap is off.appreciate any help. thanks
  • rayjay44 Jun 03, 2008
    i have alreadt tried that. thanks anyway.
  • 84 Answers
You must re-program the tv tuner for air and not cable.
Posted on Feb 10, 2008
ViewSonic 37" Wide (N3733W) TV Set that is connected to Direct TV has picture but no sound.
Based on your description, it is possible that the power supply is starting to go. Before doing anything, first check to see if it is the TV or the source. Use a few different sources to narrow down the problem. You didn't mention what type of hookup you used from the receiver to the TV. Assuming you are using HDMI, it is possible that the cable is intermittent. Try using a different one. Also try as below.
1. Once the TV is working with sound, what happens if you turn the TV off and then back on, is the sound still there?
2. Use the TV antenna input to see if you can replicate the problem using an antenna. If the problem is indeed the TV, it should do the same with the antenna.
Feb 17, 2013 | ViewSonic Televison & Video
Just switched cable companies and now I have no sound. My old system was with Dish and now I am with Direct my old system was not hdmi and the new system is
Here's what I would do first. Unplug the satellite receiver and TV from the wall outlet, then plug them both back in and allow them to reboot. Once they have rebooted, see if you have sound. If not, you may have to call the satellite provider for furthur troubleshooting. Also,do you have anything else hooked to your TV with HDMI? (DVD or Blu-Ray player for instance?) Do these work properly? If so, I would assume you have a problem in your satellite receiver. If not, you have a problem in the TV.
Sep 25, 2011 | Mitsubishi WD62628 62" Projection HDTV
Vizio 37" tv. sound loud enough on satellite and antenna. when hooked to dvd or blue ray, can hardly hear it even at maximum sound
I have a similar problem with my new 37 inch vizio. Watching on cable and the sounds gets lower and lower until i can hardly hear it. Must switch channels back and forth to restore the sound level of a particular channel. Does anybody have a solution ?
Feb 13, 2010 | Vizio VW37L 37 in. LCD HDTV
Direct tv came with apartment. has never worked says NO Signal on the screen I had cable put in but why pay for somethiing that is already included? I have tried everything but since it is not in my...
Try calibrating the antenna to the nearest satellite. The DirecTV box has in the installation menu instructions on how to do this. You'll need some tools like a socket wrench to unlock and adjust the antenna. Put in the menu your global position or your city and select the transponder that gives better signal. If all satellites are out of signal, move the dish until you receive at least one.
To calibrate the dish from the ceiling or wherever it's installed, put the TV volume up until you hear the short "BOOP" sound from the dish location. When you get signal, the "BOOP" will turn to a continuous "beep" with a higher pitch when higher the signal you're receiving. After getting the best signal, switch transponders to see if there's another with better signal, after that, lock the antenna and try watching a channel.
Nov 04, 2009 | Philips DIRECTV H20 DTV Receiver
Digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Sep 16, 2009 | Technics SA-DX930 Receiver
I can't get past the ''searching for Sattellite'' display
Doublecheck your connections. The connection from the dish should be on "Satellite in", NOT "In from antenna." That is the most common mistake that is made.
Mar 19, 2009 | Directv D12-300/100 DTV Receiver
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Connecting to projector and direct tv
seems like your directv video is direct to your tv. which directv receiver?
Oct 31, 2007 | Sony DAV-HDX500 System
RCA F27442 27" TV Logo
50 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
