Question about Zenith B32A24Z 32" TV
Zenith "Fav Channels" question
I have a Zenith TV which has the Menu selection "Fav Channels". One can choose channels to 'skip' or 'save'. I chose to skip Channel #2 at one time, so when I am flipping channels #2 did not show up. Now, I can't figure out how to get it back. Can anyone help?
  • 50 Answers
You should be able to the keypad 2 and enter it should show up, otherwise turn off the fav channels/ or maybe called surf button
Posted on Nov 28, 2007
How do I set my TV channel to 3 without the remote?
Hi John,
If channel 3 is skipping by the unit when pressing the channel button key at the front panel, it might be accidentally deleted on the channel selection. If you don't have a remote control, there's no way to add it on the selection. All you have to do is to re-scan the channel by entering to Set-up Menu. Press the Menu button key repeatedly at the front panel to show the "On Screen Menu". Select " EZ Program" to automatically finds and store the channels available at your area. Once the scan is finished, you can now watch all the channels available including channel 3.
Please let me know if you need further assistance.
Kind Regards,
Jdvillanueva
Nov 24, 2011 | Zenith C27A25 27" TV
CANT GET THE TV OFF AUX AND HAVE A CABLEONE REMOTE HOW CAN I CHANGE IT
I suspect you have a dish or direct tv hookup.If so press your menu button on the tv then select favorite channels.change the channel to your preset for your system.save the channel and it should bring the tv up.
Oct 16, 2010 | Zenith C13A05LG 13" TV
I have a Zenith B25A242 TV. Can't get cable channels
Select cable, then with your remote, go to menu and perform channel scan.
Oct 31, 2009 | Televison & Video
I can not find all the tv shows what do i do
Channel Edit makes it easy for you to save or delete channels in the list of channels in the TV?s memory. 1. Using the Number buttons, select the channel you wish to save or delete. 2. Press MENU to see the menu. 3. Press upper or lower key to scroll through the menu until SETUP is highlighted. 4. Press right key to enter the SETUP menu. 5. Press upper or lower key to scroll through the SETUP menu until CHANNEL EDIT is highlighted. 6. Press right key to choose SAVED or DELETED. Choose SAVED to add the channel to the TV?s memory. It will be available using the CH +/? buttons. Choose DELETED to remove the present channel from the TV memory. To clear the menu press STATUS/EXIT. Or, wait a few seconds after you finish your adjustment; the menu will disappear automatically. Please do rate this solution as FixYa and revert for further assistance. Thanks Rylee
Jun 13, 2009 | Philips Magnavox 20MT133S 20" TV
Hotel TV
check in preset under menu the channels 30 above maybe skip, set this channels to skip off. or just do the auto tuning.
Jun 11, 2009 | Zenith C27A24T 27" TV
Zenith dtv converter, favorite channel button
Found the solution in the user manual. You have to go to the 'edit channel' section of the on screen menu.
Dec 30, 2008 | Zenith C27A24T 27" TV
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
Quasar tv remote.
Sounds like you need to go to the main menu and run the automatic channel selector again. It will take note note of which channels are not in use and then skip over them when you use the channel advance. Use your remote to get into the main menu and select the "TV" submenu. Then run the auto channel select. After that's done, you can also manually choose to skip channels you don't like. I believe the channel numbers appear in green if they're to be included, and yellow if they're to be skipped. Even if a channel is skipped, you should be able to get to it anytime by punching in the number on your remote.
Jul 08, 2008 | Quasar VV-2002 20 in. TV/VCR Combo
Can't access channels 3 and 4
Open main menu and select manual program. In this option check skip on/off option is there. Otherwise select autoprogram the channels are automatically stored, after completing autoprogram TV displays program edit option. In that you can choose your needs.
Sep 09, 2007 | Zenith SY2751Y TV
RCA TV won't change channels
Your set uses the 195 series chassis and you have something set wrong in your guide plus. Go into the TV's menu and do a complete set-up. Take the remote and press MENU, then "8" to enter setup, then press "1" for "begin setup now" and then press "1" for English, and so on. You must enter "set up guide plus+", then press OK on the remote to choose "setup", select "USA", enter your zip code, and then if you choose "yes" for "do you have cable?" you MUST then choose "no" for "do you have a cable box" If you choose "yes" for that choice, your tuner will lock on one channel no matter what channel you try entering. After choosing "no" for "do you have a cable box", choose "no" for "do you have a VCR?", exit the guide plus menu and then skip the rest of the steps by pressing "2", and then exit the main menu by pressing "0". Your channels will then work normally.
Aug 29, 2007 | RCA P52937 52" Rear Projection Television
Open Questions:
See all Zenith B32A24Z 32" TV Questions
Zenith B32A24Z 32" TV Logo
61 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
