I just bought a 1996 ford explorer with a factory radio in it that has just a tape deck. I have the radio from a 2002 ford explorer and was wondering if it was possible to swap them out so I can have a cd player?
SOURCE: Cd player removal
here you go hope this helps you
http://www.carstereohelp.com/stereoremovalMercuryMountaineer1StR.htm
SOURCE: wiring diagram 1996 ford explorer premium sound radio f57f-19b165-ag
Here it is.
1996 Ford Explorer Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet
Car Radio Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: Orange/Blue
Car Stereo Amp Trigger Wire: Blue (If Equipped)
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
SOURCE: 2002 ford explorer radio removal and installation procedure
You have to have special ford radio tools. they look like two horse shoes. they clip into the two holes on either side of the radio and then you push outwards and pull on the clips at the same time and the radio slides right out. the tools are usually inexpensive and can probably be found at local auto parts store
SOURCE: I have a 1996 Ford Explorer XLT V8 and I want to
You cannot wire through the jbl amps you need to go to the amp and can only wire in the speakers
SOURCE: Installing an aftermarket stereo in 1996 explorer...sound issues.
You may have a factory amplifier in the rear of the explorer in the right cargo panel. You need to supply power to it by connecting the amp power on (Blue/White I think) in the dash to a power source (such as red on your stereo harness) so it comes on with the key. If you do have the amplifier, that's why you have no sound.
