Kenmore km 911 9368310 324686 Thermostat Control, Oven Range Logo
Jeff Posted on Mar 15, 2014
Installing heat sensor - Kenmore km 911 9368310 324686 Thermostat Control, Oven Range
buddywa
Level 1:
Problem Solver:
  • Contributor 14 Answers
  • Posted on May 19, 2014
buddywa
Contributor
Level 1:
Problem Solver:
Answers
14
Questions
0
Helped
15129
Points
18
Take the back off and simply replace the old with the new. Its pretty straight forward,
My mechanic read the trouble code on my 2003 Subaru Impreza as "heated O2 Sensor Control Circuit Bank 1 Sensor 1 P0030 .
did you install a O2 sensor or a heated O2 sensor
they are different items and do different jobs
The heated oxygen sensor (HO2S) reads the exhaust gas composition and reports to the ECM to adjust the air /fuel mixture to obtain maximum economy and performance
It is found in the exhaust manifold or before the cat converter
the oxygen sensor (O2 ) is found after the cat converter and reports on the cat converter operation
after installing the correct sensor use a scan tool to reset the ECM
1helpful
Where is the o2 sensor on a 2004 blazer located
Removal & Installation
Raise and support the vehicle.
Support rear of the powertrain frame.
Remove four rear frame bolts.
Lower the frame no more than 73.2 mm (3 inches).
Disconnect the rear oxygen sensor electrical connector.
Remove the rear oxygen sensor from the rear exhaust manifold.
To install:
Install the rear oxygen sensor in the rear exhaust manifold. Tighten the rear heated oxygen sensor (HO2S) sensor to 41 Nm (30 ft. lbs.).
Connect the rear oxygen sensor connector.
Raise the frame.
Install the four rear frame bolts. Tighten the frame bolts to 100 Nm (74 ft. lbs.).
Lower the vehicle.
Heated Oxygen Sensor Bank 1 Sensor 1 (HO2S 1/1)
WARNING: Handle the oxygen sensors carefully in order to prevent damage to the component. Keep the electrical connector and the exhaust inlet end free of contaminants. Do not use cleaning solvents on the sensor. Do not drop or mishandle the sensor.
CAUTION: Remove oxygen sensors with the engine temperature above 48C (120F). Otherwise the oxygen sensors may be difficult to remove.
A special anti-seize compound is used on the oxygen sensor threads. New service sensors should already have the compound applied to the threads. Coat the threads of a reused sensor with anti-seize compound P/N 5613695 or equivalent.
Fig. Showing the location of the HO2S Bank 1 Sensor 1
Heated Oxygen Sensor Bank 1 Sensor 2 (HO2S 1/2)
CAUTION
WARNING: A special anti-seize compound is used on the oxygen sensor threads. New service sensors should already have the compound applied to the threads. Coat the threads of a reused sensor with anti-seize compound P/N 5613695 or equivalent.
Fig. Showing the location of the HO2S Bank 1 Sensor 2
Remove the heat shield.
Disconnect the heated oxygen sensor electrical connector.
Remove the heated oxygen sensor.
To install:
Install the heated oxygen sensor. Tighten the heated oxygen sensor (HO2S) to 41 Nm (30 ft. lbs.).
Connect the heated oxygen sensor electrical connector. CAUTION
Ensure connectors are securely installed beneath harness heat shield to prevent damage.
Install the heat shield.
Lower the vehicle.
Heated Oxygen Sensor Bank 2 Sensor 1 (HO2S 2/1)
CAUTION: Handle the oxygen sensors carefully in order to prevent damage to the component. Keep the electrical connector and the exhaust inlet end free of contaminants. Do not use cleaning solvents on the sensor. Do not drop or mishandle the sensor.
Remove the air deflector.
Disconnect the front oxygen sensor electrical connector.
Remove the front oxygen sensor from the front exhaust manifold.
Fig. Showing the location of the HO2S Bank 2 Sensor 1
To install:
Install the front oxygen sensor in the front exhaust manifold. Tighten the front HO2S sensor to 41 Nm (30 ft. lbs.).
Connect the front oxygen sensor electrical connector.
Install the air deflector.
Lower the vehicle.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Location of oxygen sensor on 2004 blazer check engine light keeps coming on. Replaced sensor no change. At bank 1 sensor is not connected when tested.
To install:
Raise the frame.
Lower the vehicle.
CAUTION
To install:
Lower the vehicle.
To install:
Lower the vehicle.
3helpful
2answers
Where is the bank 1 sensor 1 o2 sensor located in a 2006 hyundai sontata gls v6?
The bank has to do with which side of the engine. The 'Sensor 1' indicates that it is upstream of the catalytic converter.
Heated Oxygen Sensor Removal & Installation Heated Oxygen Sensor (Front) (2.4L) hyundai-04-24-5822.gif
Heated Oxygen Sensor (Bank 1/Sensor 1) (3.3L) kia-04-00-5213.gif
Heated Oxygen Sensor (Bank 1/Sensor 2) (3.3L) kia-04-00-5214.gif
Heated Oxygen Sensor (Bank 2/Sensor 1) (3.3L) kia-04-00-5215.gif
Heated Oxygen Sensor (Bank 2/Sensor 2) (3.3L) hyundai-04-33-5855.gif
I have a 07 f150 4.6L V8 and I need to replace the Bank 1 sensor 1 oxygen sensor but cant figure out which sensor it is since there are 4 sensors. Where can I find a picture of the location?
Heated Oxygen Sensor (HO2S)- The Bank 1 Sensor 1 tells me that it's an upstream O2 sensor. The larger the number the further down the line of the exhaust it is. Removal & Installation 4.2L Engine ford-04-42-2750.gif
To Remove:
  1. Raise and safely support vehicle.
  2. Disconnect battery ground cable.
  3. Detach electrical connector from right inner fender splash shield (if necessary).
  4. Remove right inner fender splash shield (if necessary).
  5. Disconnect heated oxygen sensor electrical connector.
  6. Remove heated oxygen sensor.
To Install:
  1. Apply anti-seize lubricant to heated oxygen sensor threads.
  2. Install heated oxygen sensor. Torque to: 34 ft-lbs (46 Nm)
  3. Connect heated oxygen sensor electrical connector.
  4. Install right inner fender splash shield (if necessary).
  5. Attach electrical connector to right inner fender splash shield (if necessary).
  6. Connect battery ground cable.
  7. Lower vehicle.
To Remove:
  3. Disconnect heated oxygen sensor electrical connector.
  4. Remove heated oxygen sensor.
To Install:
  4. Connect battery ground cable.
  5. Lower vehicle.
Need a new po135 - 02 heater circuit
UPSTREAM OXYGEN SENSOR
The oxygen sensor is installed in the exhaust manifold Upstream Heated Oxygen Sensor - 2.4L. or Upstream Heated Oxygen Sensor - 3.0L. or Upstream Heated Oxygen Sensor - 3.3/3.8L .
CAUTION: Do not pull on the oxygen sensor wire when unplugging the electrical connector.
WARNING: THE EXHAUST MANIFOLD AND CATALYTIC CONVERTER MAY BE EXTREMELY HOT. USE CARE WHEN SERVICING THE OXYGEN SENSOR.
REMOVAL
Raise and support vehicle.
Unplug oxygen sensor electrical connector.
Use a socket such as Snap-On YA8875 or equivalent to remove sensor.
When the sensor is removed, the exhaust manifold threads must be cleaned with an 18 mm X 1.5 + 6E tap. If using original sensor, coat the threads with Loctite 771-64 anti-seize compound or equivalent.
INSTALLATION
Reverse removal procedure to install a new sensor
New sensors are packaged with compound on the threads and no additional compound is required. The sensor must be tightened to 27 N·m (20 ft. lbs.) torque
1helpful
Install heated oxygen sensor number 1 in volswagen jetta
Hi:
The Number 1 Heated Oxygen sensor is located in front of the catalytic converter. You would need to get the car up in the air, and then disconnect the electrical connector, and possibly need a special socket to remove the sensor. Also remember to purchase and use Oxygen sensor safe anti sieze compound on the threads of the new sensor, if you do this your self
1helpful
Oxygen sensor
you need to borrow the oxygen sensor wrench from autozone or whereever you bought the sensor. Section 03-14: Engine Controls, Electronic 1996 Taurus, Sable Workshop Manual REMOVAL AND INSTALLATION -------------------------------------------------------------------------------- Heated Oxygen Sensor (HO2S) SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Oxygen Sensor Wrench T94P-9472-A Removal and Installation Disconnect battery ground cable (14301). Refer to Section 14-01 . On 3.0L (4V) engine remove cowl extension and right side of leaf screen. Disconnect engine control sensor wiring (12A581) from heated oxygen sensors (HO2S) (9F472). Do not remove harness connectors from the brackets. Raise vehicle on hoist. Refer to Section 00-02 . NOTE: If excessive force is needed to remove a heated oxygen sensor, lubricate the heated oxygen sensor with penetrating oil prior to removal. Remove heated oxygen sensors from exhaust manifolds (9430) using Oxygen Sensor Wrench T94P-9472-A. To install, reverse Removal procedure. Apply a coating of anti-sieze compound to threads of heated oxygen sensor. Tighten heated oxygen sensors to 34-46 Nm (26-34 lb-ft).
1helpful
How do you replace the oxygen sensors on a 1995 merc sable with a 3.0 ltr motor
they just unscrew from the exhaust pipe.
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. On 3.0L (4V) engine remove cowl extension and right side of leaf screen.
  1. Disconnect engine control sensor wiring (12A581) from heated oxygen sensors (HO2S) (9F472). Do not remove harness connectors from the brackets.
  1. Raise vehicle on hoist. Refer to Section 00-02 .
  1. NOTE: If excessive force is needed to remove a heated oxygen sensor, lubricate the heated oxygen sensor with penetrating oil prior to removal.
  1. To install, reverse Removal procedure. Apply a coating of anti-sieze compound to threads of heated oxygen sensor. Tighten heated oxygen sensors to 34-46 Nm (26-34 lb-ft).
    Heated Oxygen Sensors—3.0L (4V) Engine
Where's my O2 sensor located
Heated Oxygen Sensor (HO2S) SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Oxygen Sensor Wrench T94L-9472-A
NOTE: If excessive force is needed to remove heated oxygen sensor (HO2S) (9F472) , lubricate heated oxygen sensor with penetrating oil prior to removal.
  1. Disconnect battery ground cable (14301) .
  1. Disconnect heated oxygen sensors from engine control sensor wiring (12A581) .
  1. Remove heated oxygen sensors from dual converter Y pipe (5F250) using Oxygen Sensor Wrench T94L-9472-A.
  1. To install, reverse Removal procedure. Tighten heated oxygen sensors to 36-46 Nm (26-34 lb-ft).
Top Kenmore Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
