Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite Catalyst Mod. 22052
Moved washer out of storage, laid it on back in truck, and oil leaked from somwhere.  Not gallons, but maybe two tablespoons worth or more.  Plugged washer in, no power evidenced in unit.  Totally no response or evidence that power is connected.  Is there some sort of shutoff switch or sensor I should be aware of?
  • 146 Answers
Oil is no problem. The door switch/interlock is faulty. Replace door interlock. Try closing the door firmly with an extra little shove on the door handle. Sometimes this works.
Posted on Nov 03, 2007
I just moved and all of a sudden it won't drain completely
In the move, the removal men tipped it over and have split one of the hoses. First off check the discharge hose at the back for cracks, kinks or crushing..
Dec 30, 2015 | Kenmore Elite 45986 Front Load Washer
I replaced the tub/motor coupling on my Kenmore model # 110.26912690 washer. I laid the machine on its back, while waiting for the parts, which came 3 days later. I noticed some thick oil had leaked...
Your oil is more than likely from the washer's "transmission". like your car, the washer employs a similar set up in order to change from "agitate' to "spin", etc. the oil is necessary to the operation, and the extended time (3days) on its side allowed some to leak out. Unfortunately, the only sure-fire way to tell if you still have enough oil will be to have a repair tech look it over and add if necessary. for future reference, if you ever think you need to tip your unit over, you'll have to be very quick about it, and if it needs parts, stand it back upright while you wait.
Jan 18, 2012 | Kenmore Washing Machines
Kenmore catalyst elite washer fills but does not
the reset is to unplug the washer for 5 minutes, if that doesn't reset it u may have a defective motor controller circuit board
Aug 02, 2010 | Kenmore Elite HE4 Electric Dryer
Have Kenmore Elite Catalyst Washer showing F3.
I have a top load Kenmore Gold Catalyst Cleaning Action washer that is stuck on permanent press mode. The digital display reads 8 min. and will not turn off or clear.When it is turned on the, the timer goes to 37 minutes and beeps repeatedly through all cycles. It will not clear even when I unplug it. How do I fix this annoying thing!!? Thoughts please.
May 22, 2010 | Kenmore Washing Machines
My washer is leaking from the detergent tray.
There is a hose to the tray so it can rinse the detergent inside the machine. The hose can leak, sometimes there is a seal on the tray that can leak also
May 04, 2010 | Kenmore 45981 Washer
We have a kenmore elite washer mod. 970-c40062-00 ser. xc11700832. the washer leaks, and is very noisy. It is 10 years old
Your Stainless Steel drum is supported inside of the washer tub by a spider assembly. The assemply, which is made of cast aluminum, has corroded (steel and aluminum and detegent don't mix) and the spider assembly has broken. The drum has likely wobbled enough to wear a hole through the tub. You need to replace the drum and spider assembly, and tub.
Mar 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore side by side not cooling
First off how far did it get leaned when moved and second it might just need to be cleaned.
If you laid it down when it was moved it should have been left unplugged for 12 hrs before plugging in because the refridgerant used is also a lubricant and it needs time to settle.
As far as cleaning it you will need to take off the back panel and use a vac to clean out the dust.There is also a kickplate on the front that needs to come off and clean the cooling grates that are under there.If you have a dryer brush it works great for cleaning the grates.You can get between them with it.
Unplug it before you do any of this.
Oct 22, 2009 | Refrigerators
Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
Aug 01, 2009 | Kenmore Washing Machines
Washer will not go to the rinse cycel.
check cold water line...onthejob,,,im assuming no rinse cycle only..onthejob,,,no mater the cycle
Jan 31, 2009 | Kenmore Elite 45986 Front Load Washer
Kemore 70 series
Its possible that your trans. is going to need replaced. Maybe have some bad seals on the trans. As far as the water leak goes. Could be a tub seal, maybe some worn inlet hoses, maybe a leaky inlet valve.
We hope this gives you a start on your appliance repair. Anymore questions please feel free to reply back.
Mar 26, 2008 | Kenmore 22422 Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
262 people viewed this question
Sal De
 Brian Main
Brian Main
