If your LCD is cracked, you will need to unfortunately replace the entire LCD. Simply putting a screen protector (which is just a thin film) will not stop the crack from getting worse. There is unfortunately no magical way to fix your screen other than simply replacing the LCD panel itself, which is totally doable. Many electronics repair shops can fix your TV pretty easily. In some cases, you can even mail it into Toshiba.
Thank you for writing in regard to your concern about the crack scree on your phone. Let me help you with this.
First, I want to know the severity of the crack and if the crack is just outside the housing or casing, or is it on the LCD scree of your phone?
If the crack is on the LCD of your phone, then, the best thing that you can do is to bring the phone to the nearest service centre to replace the LCD. Cracked LCD can no longer be fixed because it is a hardware problem already.
Hope I was able to resolve your concern.
Your LCD/monitor is cracked from the inside. There are several things that can
cause a screen to crack from the inside. The two most common are
pressure on the screen or dropping the
machine. Sorry, but it is irreparable. You need to buy a replacement.
The set needs a new LCD if it looks cracked and swirly, the colors all run together in the area of the crack don't they! If it is cracked it can't be fixed. you can replace the lcd but I am not sure if a warranty will cover a cracked screen or not. You will need to contact LG and be very nice to them and see if they will honer the warranty on this.
YOU CAN'T!
This is from another website, I thought you might like a second oppion too!
"For your information no one can repair cracked LCD Screen. In order to solve the LCD panel cracked problem, the best is to replace with a known good LCD panel."
if LCD cracked,then you have to replace it.
go to [email protected]
to find GPS LCD,PDA LCD,PSP LCD,mobile phone parts,notebook LCD.Car LCD,CAR DVD LCD and other touch screens.
I don't have a listing for your model, but it is not unusual for the panel to cost more than a replacement set. As another example, the replacement tube (CRT) for a 27" Sony set can easily be $700. This was when these sets were being sold for $350!! Parts is where these companies rake in big profits. Don't blame the servicer for this one.
If you're willing to take the risk of tearing thin flexible circuits and are familiar with electronics, you can do it yourself. A new LCD is $55 and labor for us to install is $45. http://www.crystalcamera.com
