Covercraft UltraTech Custom PWC Jet Ski Cover Blue Fits - YAMAHA Wave Runner FX Cruiser 2002 2003 2004 2005 FX Cruiser High Output 2004 2005 Logo
a
alan farris Posted on Mar 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
Last time out it ran great. Now, its hard to start, and wont go above 6 mph. Won't idle.
Larry
Level 2:
Sergeant:
  • Expert 288 Answers
  • Posted on Apr 17, 2014
Larry
Expert
Level 2:
Sergeant:
Answers
288
Questions
0
Helped
55643
Points
528
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
I own a 2004 yamaha roadstar 1700. 15,000 miles. always ran perfectly. i would say i ride 4 days a week and mostly scenic drives low speeds. last week i took it out and drove it pretty hard. high speeds...
remove the carbs and have them professionally overhauled
indicates a problem in the high speed circuit , probably a blockage
might also be an incorrect float level that is not allowing enough fuel into the bowl for hgfh speed operation
It Runs but has very little power,quits often,if you give it to much throttle it bogs down
Robert, First try new plugs, check fuel filter, sounds like it could be carburetor/injector issue, dirt,plugged jet, etc. Remove and clean/rebuild carb./injector.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
XLT1200 Bogs down
Thread 2004 FX HO ECU Problem
Waverunner Loses Power and Wont go Above 35 mph Solution
https://answers.yahoo.com/question/index?qid=20080525091900AATkgJh
Starts and runs and RPMs are good but it won't go above 5 MPH. Checked intake and I have the rooster tail of water but no speed
you may have to check the pump unit for obstruction
the impellers are known to wear from abrasion from sand in the water and not operate efficiently.
2helpful
Yamaha waverunner fx cruiser sho
check impellor blades not bent ! scoop grate not bent ? wear ring not badly worn ?not got some rope or debrise on impellor ?
May 26, 2014 • Boating
Waverunner is abnormally slow accelerating initially, but will finally get up to normal speed
Pull your air filter out and also replace plugs. Overtime the filter will become saturated with oil and believe it or not the plugs can cause about a 10 mph drop if there going bad. But make sure your pump and impeller are not damaged also
2005 yamaha fx cruiser
is it running on all 4 cyls ? did you drain the water out of exhaust system then fog the engine properly before storage ? if not then valves stick open due to damp air coming back from exhaust ! head strip etc !!
Jun 26, 2013 • Boating
Got my 2009 Yamaha FX sho waverunner under water, drained the water from the hull and tried to start it. Turned over 5 or 6 times and stopped. Pulled the air filter out and of course had water in it....
remove all sparkplugs and hold full throttle and crank over several times to get water out of cylinders ! have a jump pack ready as battery will die ! use carb cleaner on the plugs each time you try to run after this , hope this has only just happened as internal damage might already started ! if all ok check the engine oil also as water normally gets in after this problem ! if oil is milky then change oil several times , run for 15min on hose each change until oil normal colour ! then you must take for a run for an hour to help dry it out !
1helpful
2009 Yamaha vx cruiser waverunner used to do 55mph now won't pass 35 mph
Nevermind those other answers, if its running on all 4the cylinders but just real sluggish and missing top speed then listen up, let's first rule out the possibility of a damaged impeller, now locate your airfilter box and remove the filter, just throw it away because last I checked dirt really doesn't settle on top of water, now locate your throttle body and remove the intake tube from it, now take out the 4 bolts that hold it on and find your flame arrestor element. I've dealt with this problem many times only to find out that the geniuses at Yamaha had installed this screen right after the butterfly which accumulates airfilter material and clogs
2004 fx CRUISER ho WAVERUNNER DOESNT WANT TO IDLE OR RUN AT TOP S
did you mean 900 cause 9000 is overrived and the engine may be blown
Jul 08, 2010 • Boating
Top Covercraft Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Covercraft Boating Expert? Answer questions, earn points and help others
