Tried to plug in to three different monitors using both vga and hdmi hook ups on computer but still no video on computer startup
SOURCE: No Video Signal
If you can't use the onboard video and it does POST or the PCI-E video card does show anything, most likely the motherboard is toasted. Apparenty gateway uses real poor quality power supplie and motherboards.
I have the same system, it powers on, but nothing. All I can assume is that the motherboard is bad.
Try resetting the bios. On the motherboard there is a battery that looks like a watch battery. Remove the battery, then replace it again. (make sure the computer is unplugged from the wall socket when you do this)
Does this work?
SOURCE: Connecting Laptop to LCD
the following connections available to connect ur computer to an TV:
S-Video output: If you have video card(external u will have this), you require an s-video cable and you connect s-video out of your computer to the s-video int of our TV.
TV-OUT: if you have video card(external u wil have this) you you require an coxial cable and you have to connect TV-out of your computer to TV-IN of our TV(it is place where cable connection goes from your cable operator)
DVI-D: if you have video card(external u will have this) you require an DVI-D cable you haveto connect DVI-D out of your computer(a white 15-pin port which looks like VGA port) ....
VGA: it is the port on your computer which is only used to connect to your computer but not to your TV or LCD(strictly)
Thanking you,
M. Sridhar
SOURCE: Gateway sx2800-03 compatibility problems with Samsung 2494hm
you have the wrong video driver - go to gateway and redownload the video driver and install it reboot and presto...
SOURCE: I want to reset my Gateway LX6200-01 to factory settings
Hello!
If you computer can go to the system, few second or more, maybe you have trouble with heathing, and clear cmos isn´t solution for that.
Than you need good expert for repair you computer.
