Washing Machine Wont Fill and cycles unresponsive, Help :/
I have a fisher & paykel smart drive 603, which wont fill or start cycles, i checked the filters on the back of the machine which were clean. Any idea's?
  • Rondog Dec 18, 2007
    I have a Fisher Paykel 7 series Smart Drive 9 washer. You can select the type of wash you want. When I press start, nothing happens. It just sits there. Its intermittant though but getting progressivly worse. Control board sounds right. How much can I expect to pay for a replacement? Also where can i get one?
  • 100 Answers
Sounds like your control board is shot. Do you have 120VAC going into it?
Posted on Oct 30, 2007
My comment is generic to all washing machines in which there is a fill problem. Finally I remembered that when we did an upgrade on our basement I installed the type of fill hose that will prevent flooding. Sure enough, when I interchanged the hoses the problem switched from no hot to no cold. A flood prevention mechanism had malfunctioned on one hose and the reset feature did not work. A return to Home Depot will complete the solution to my problem - but I feel humbled to have overlooked the possibility that this simple malfunction had caused the grief.
Posted on Dec 07, 2009
Smart drive 085
the buzzing noise is the pump trying to work, but it cannot due to a blockage. unplug the washer and you can lean the washer backwards and remove the pump to unblock. the fill error is probably unrelated, and is an inlet valve issue.
Sep 25, 2013 | Fisher and Paykel (IWL12)
Fisher and Paaykel Smart Drive 708 not working once filled with water.
You need to check your lid switch & out of balance switch for
corrosion and replace if faulty.
Your out of balance switch is under the big yellow motor controller
OOB switch Is where the grey plate is on this picture.
Mar 03, 2013 | Fisher and Paykel Washing Machines
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
Our F & P GW508 Smart Drive starts to fill at
Sounds like your out of balance switch is corroded. It is located underneath your gold motor controller board.
May 27, 2017 | Fisher and Paykel Fisher Paykel Intuitive...
Is there a filter on the smart drive 051- my washing is coming out with dirty black marks
if the black marks come out then it is lint. put 2 pkts bicarb soda into empty bowl, select hot fill, select high water, start cycle. let it wash for 10 min"s , turn machine off, leave overnight. restart cycle in the morning, that should clean tank and bowl. please reply 4 more help.
Apr 23, 2010 | Fisher and Paykel Fisher & Paykel Washer
Our Fisher and Paykel 603 smart drive has stopped
most likely your problem is your lid switch visit your local spare parts dealer and purchase a new one
Feb 06, 2010 | Fisher Washing Machines
Water not coming with force in Fisher & Paykel SmartDrive Top-loa
Try taking the cold hose of at the tap and check to see if has a little mesh filter in there. This could be blocked up with gunk.
Jan 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Pykel Smart Drive 9
Spin the fan on water pump (you can acess with difficulty from bottom of washer) if it has a little sand in it, it may clear. It is possible to remove water pump if mechanically minded and see if something small eg staple or 5c coin is stuck in it if this dosn't work or you may find you need to replace water pump.
Aug 19, 2008 | Fisher and Paykel Fisher & Paykel Washer
Fisher & Paykel smart drive 708 filter
my machine swiches on but wont let it fill with water.
Any ideas?
adrian
Mar 17, 2008 | Fisher and Paykel Fisher & Paykel Washer
Washing Machines Logo
514 people viewed this question
Top Washing Machines Experts
